FW DSO, 1.00l8
Exactly according to the instructions, I enabled the serial port and dev mode in the menu.
- I turned the oscilloscope off and on again, and booted PECO.
- USB connected, the USB serial port was detected.
- I opened the terminal, but there was no data stream and no response to ENTER or to f3000.
Next, I tried AUTO SET several times in a row, and occasionally it set correctly.
When connecting the calibration signal from the oscilloscope’s output, the signal is displayed correctly
