Author Topic: FNIRSI-1013D "100MHz" tablet oscilloscope  (Read 1483635 times)
indman, engineer.r152 and 78 Guests are viewing this topic.
Offline rhb
Re: FNIRSI-1013D "100MHz" tablet oscilloscope
« Reply #250 on: July 19, 2020, 03:55:23 pm »
When someone can post a disassembly I'll make tables of the caller:callee relationships among the functions and map the global variable addresses.  If we can get documentation for the JuTouch library we should have a pretty good grip on it.
https://www.jutouch.com/
They say to contact sales for the driver software.
« Last Edit: July 19, 2020, 03:58:58 pm by rhb »
Offline iscle
« Reply #251 on: July 19, 2020, 03:57:40 pm »
I think it's easier for somebody to just open the device up and tell us the which chip is the touchscreen using, then just writing the driver for it (which for sure is already available in GitHub)
Offline rhb
« Reply #252 on: July 19, 2020, 04:00:28 pm »
The JuTouch library will give important hints about what the rest of the code does.
Online tv84
  • Country: pt
« Reply #253 on: July 19, 2020, 04:03:54 pm »
My 20 years of experience in reverse engineering tells me that this is a table, not a code. But I will know for sure only when I reach that place.
My 5 minutes look at that part shows an incrementing pattern (with contiguous 0x400 bytes size blocks). That doesn't look like a unicode characters conversion table. I could be wrong...
Offline Fungus
« Reply #254 on: July 19, 2020, 04:09:21 pm »
It is still "as cute as a bug's ear", but it may be going back...
Imagine all the fun you'll miss out on.  :popcorn:
The following users thanked this post: iscle
Offline UniSoft
  • Country: kz
« Reply #255 on: July 19, 2020, 04:14:54 pm »
Maybe we talk about different places?
Because I don't see any 0x400 bytes size blocks... In that case I will asume that this is a memory mapping table...
But this is what I see
PS: This is a Little Endian...
« Last Edit: July 19, 2020, 04:18:05 pm by UniSoft »
Offline rhb
« Reply #256 on: July 19, 2020, 04:20:16 pm »
That section is broken up in  chunks of various sizes delimited by zeros.  This is strongly suggestive of a bitstream for the FPGA. If that's the case there will be a bit of assembly code that sits in  loop incrementing a pointer through that section reading and then writing the contents to the FPGA load address.
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #257 on: July 19, 2020, 04:43:34 pm »
But the fpga has another spi flash chip.
« Last Edit: July 19, 2020, 04:50:19 pm by GeorgeOfTheJungle »
Offline iscle
« Reply #258 on: July 19, 2020, 05:04:22 pm »
I think that's an I2C EEPROM, judging by the two pull-up resistors on two of the pins.
Offline cliffyk
    • PaladinMicro
« Reply #259 on: July 19, 2020, 05:25:23 pm »
It comes with a 2GB SDCard I think.
Might as well be booting from there, then, no?
I still don't have the scope with me, but I did read somewhere that the SDCard only contained the screenshots and saved data.
As originally designed and configured that is correct...
-cliff knight-
paladinmicro.com
Offline rhb
« Reply #260 on: July 19, 2020, 05:31:12 pm »
That is almost certainly wrong.  The Zynq at least has it's own facility for loading the bitstream from flash.
  • Country: tr
« Reply #261 on: July 19, 2020, 05:34:44 pm »
Well, maybe, but my point is/was, isn't that the eeprom that contains the fpga bitstream? And if so, it's not going to be in the other eeprom too, right?
Offline UniSoft
  • Country: kz
« Reply #262 on: July 19, 2020, 05:37:56 pm »
FPGA has another standalone chip... as wrote @GeorgeOfTheJungle
IC which you mark is I2C, name is erased...
and the IC a little bit left, is also SPI 25P16VP, and connectors on left (6pin top, and 4pin bottom is to program them)
Both of them connected to FPGA only...
By the way
Touch IC is GOODIX GT915
Offline iscle
« Reply #263 on: July 19, 2020, 05:42:47 pm »
Oh, the FPGA bitstream is definitely in the other SPI NOR located to the left of this misterious EEPROM. The Allwinner CPU does not send it.
  • Country: tr
« Reply #264 on: July 19, 2020, 05:47:41 pm »
Where will my glasses be?  :-DD
Offline UniSoft
  • Country: kz
« Reply #265 on: July 19, 2020, 06:24:59 pm »
Here is the dump of ST 25P16VP... (this is FPGA stream data and connected to dedicated FPGA pins)
I don't think that it is useful for anyone, just let it be for history...
I2C I guess for store settings.
https://mega.nz/file/MGY3FI5b#wURGvOJB9Zb6dqilI2w5TRbJWrP3fHHG5muqNXtb-r4
« Last Edit: February 07, 2021, 02:47:13 pm by UniSoft »
Offline Fungus
« Reply #266 on: July 19, 2020, 06:31:59 pm »
Yes but that would mean two flash chips.
(ie. more expensive)
I2C EEPROM would be used for storing calibration, atc.
Offline UniSoft
  • Country: kz
« Reply #267 on: July 19, 2020, 07:16:53 pm »
Here is the input channel...
screenshot from here (made by St_dsk )
https://mysku.ru/blog/aliexpress/80036.html
quality of picture is not good  :(
« Last Edit: July 19, 2020, 07:18:45 pm by UniSoft »
Offline rhb
« Reply #268 on: July 19, 2020, 07:24:49 pm »
Well, I got Ghidra 9.1.2 to run, but it does not grok ARM V9.  So where to from here?
Reg
Online tv84
  • Country: pt
« Reply #269 on: July 19, 2020, 07:56:08 pm »
Also for history, here is the parsing of this dump (.RBF file) header:
WARNING: the .RBF file has the bytes bit-reversed!  Reversing...
FPGA - RBF/RPD (Raw Binary File) - Filesize: 16 777 216 bits (00200000 bytes)
00000000 - Start of File  (Type 1)
         [00000048                      00000021]
Bit 7  - 1111111111111111111111111111111111111111       FFFFFFFFFF
Bit 6  - 1111111111111111111111111111111111111111       FFFFFFFFFF
Bit 5  - 1111111111111111111111111111111111111111       FFFFFFFFFF
Bit 4  - 1111111111111111111111111111111111111111       FFFFFFFFFF
Bit 3  - 1111111111111111111111111110111010000000       FFFFFFEE80
Bit 2  - 0000011100110011001011111000000000111111       07332F803F
Bit 1  - 1100000000000111100011000000010111111111       C0078C05FF
Bit 0  - 0000000000010101000100010110110111111111       0015116DFF
Bits 0080 - EPCS/EPCQ ID check: Enabled
Bits 005F - Stream size: 943 711 bits  (0001CCCC bytes)  Compression Bit ON  (+1)       Size NOT OK
Bits 0056 - 0000 0000 : 0x56-0x5D
Bits 004C - Programming Mode: Active Serial (AS x1)
Bits 003B - IDCode (Version+Part Number only): 0x020F1  (-> 0x024F1)
Bits 0008 - Usercode: 0015116D
00000049 - Header CRC-16_MODBUS: 0033  [00000021-00000048]        CRC OK
0000004B - Data Framesize: 207  [0000004B-000000F1]
000000F2 - 4-byte words: 1260  [000000F2-000014A1]
00000000 - Stream Size (Uncompressed): 15 610 872 bits
000014A2 - CRC Framesize: 207+0     # Data Frames: 1727  [000014A2-00059D4F]
Start address: 00000000
00059D50 - Post-device bitstream pad bytes (0xFF): 1583407  [00059D50-001DC67E]
File Checksum: 1E469589
Online tv84
  • Country: pt
« Reply #270 on: July 19, 2020, 08:29:30 pm »
Blocks:  (UPDATE)
Offset:      Size:
00000000 00003400 - SPL (secondary bootloader)
00006000 00007400 - 1st executable (OS part that deals with the SD card)  (?)
00013000 0000E600 - bitmap
00027000 00193200 - 2nd executable (main app)  (?)
(the 1st 32 bytes of each block are its header) In the header, at offset 0x10, there is the size of the block (including header).
SPL has a Load Address = 0x00000000
The executables have a Load Address = 0x80000000
A teaser function in the attached file.
« Last Edit: July 19, 2020, 09:10:57 pm by tv84 »
Offline ace1903
  • Country: mk
« Reply #271 on: July 19, 2020, 08:32:42 pm »
@ rhb
ARM V9 != ARM9
ARM9 is old architecture and it should be supported in Ghidra.
The latest architecture from ARM when I checked a couple of years ago was ARM v8.
Not sure if v9 is released yet.
Also note that ARM9 is also older than Cortex A9.
Offline rhb
« Reply #272 on: July 19, 2020, 09:04:49 pm »
What's the architecture I should select?  ARM's nomenclature has driven me crazy for years and I'm the kind of person who bought processor manuals for new chips e.g. R2000, i860, 68000.
Online tv84
  • Country: pt
Online tv84
  • Country: pt
« Reply #274 on: July 19, 2020, 09:09:06 pm »
ARM Little endian with the load addresses that I've previously indicated, after stripping the 32 byte headers!
