Dear atlan. I finally installed the firmware. It is actually easier DONE than said. It was easy thanks for the great I instruction and loader program.
Great job bro, excellent features specially low voltage detection and wave reading function. Bro you really put fnirsi to shame man. I now have a chance to detect noise at longer timebase.
Is there any chance someday you could add peak detect? I increased the sampling rate but wave length shown becomes smaller.i think it because of low memory of the device. Even now the device is working better man at least I have a chance of seeing the noise at lower time base for a moment which helps a lot but I hope you can add peak detect someday. You and pcprogrammer have clearly done excellent work man thanks a lot for making this device so good
I calibrated it according to the instructions two times. I didn't find DC offset calibration I only managed to calibrate the inputs .
Now my device reports DC way better and more precise than fnirsi original firmware but when I push auto, it all goes wrong and voltage is reported wrong. I have to press base line Calibration to get the DC voltage right. Is it normal or I have done something wrong?
Before calibration, there was a noise floor at around 24 to 29 mv p to p at 100mhz in channel 2 and with less voltage at channel one. After calibration there is still noise but around 6 to 9 mv.
Have I done something wrong or it is just the crap hardware of 1013d?
