Since the wave file format was modified a while ago, I finally got around to fixing it. Now, if there is a mismatch, a message about mishmash will be displayed. And additional information about the problem. At the same time, the file will not be deleted. With this idea, if necessary, it will be possible to repair old files to work with the new firmware.
v0.26s1+++++++++ actual timestamp, add fw version on waveform file, RTC buttons frst push, OTher set menu fix, baseline menu fix
