Hello everyone,
First of all, I would like to say that what you are doing here is really great. Please keep up the good work.
Unfortunately, I have a small problem. I have installed firmware 0.26V7. I can't seem to get 0.27 to work; it always starts the original firmware. Does it need to be renamed?
But that's not the real problem.
When I try to start a baseline calibration with firmware v0.26, it ends with an error message, see image. With the original firmware, it runs without any error messages.
The DC shift calibration also does not work. I am using a 4V, with 2V DC offset and 1KHz square wave signal, as shown in the video.
But I cannot get the signal to zero and the value stays at 200 and does not go any higher.
I also read here that there could be problems with the TL431/432 IC. I wrote down the voltages and resistance values as they are in my device.
Does anyone have any idea where the problem might lie?
Thanks in advance for your help.
Best regards,
Dirk
