Author Topic: Hacking the Rigol DHO800/900 Scope  (Read 2409259 times)
0 Members and 19 Guests are viewing this topic.
Offline mrisco
  • Country: pe
    • Github Profile
Re: Hacking the Rigol DHO800/900 Scope
« Reply #3475 on: February 08, 2025, 07:43:17 pm »
We are attempting to use the DHO814 for Transistor Curve Tracer utilizing the XY Mode. Really like the display that includes the X and Y numeric labels, but can't get the display to show enough brightness in XY mode (we have brightness set to max), it's fine in regular Time Domain mode tho.
The results are very faint as shown.
The setup is an AWG used to sweep (0-8V) the X Axis thru a Resistor (Collector 100Ω) and the DSO CH1 connects to Resistor, the AWG other channel is stair-stepped (8 Steps 0-10V) thru a Resistor (Base 50KΩ). Another Resistor (Emitter 10Ω) and DSO CH2 is connected across this resistor to display Current on the Y Axis.
You can see the Siglent DSO displays the result with good brightness while the DHO814 we can't get to display with sufficient brightness.
BTW wish the Siglent would include the XY display numerics like the Rigol, they are nice :-+
Any help is from the Rigol gurus is appreciated.
Best
Increase the number of samples/Mem Depth in the horizontal panel. Decrease the horizontal scale in the same panel.
Offline mrisco
  • Country: pe
    • Github Profile
« Reply #3476 on: February 08, 2025, 07:50:15 pm »
Honestly, I like the measurement panel on top of the signal window better. When it doesn't make the signal window shrink :)
I want to be able to see the channels, the XY window, and also some measurements while keeping the graph windows uncovered.
But a floating option that we can move around the screen might be the best option.
« Last Edit: February 08, 2025, 07:52:12 pm by mrisco »
Online mawyatt
« Reply #3477 on: February 08, 2025, 07:53:09 pm »
Thanks, that solved the issue :clap:
Now we have a nice looking IV Plot with axis numerics :)
Best
« Last Edit: February 08, 2025, 08:42:54 pm by mawyatt »
~Wyatt Labs by Mike~
The following users thanked this post: Fungus
Offline mrisco
  • Country: pe
    • Github Profile
« Reply #3478 on: February 08, 2025, 08:07:32 pm »
Best
Check this: https://www.innovatefpga.com/cgi-bin/innovate/teams2018.pl?Id=AS033
Online mawyatt
« Reply #3479 on: February 08, 2025, 09:18:15 pm »
We've seen your site before, very nice work :-+
We have a restored Tek 577 for any "serious" Curve Tracer work, and created a few custom fixtures including something for SMD components.
https://www.eevblog.com/forum/repair/old-tek-577-return-to-life-story/msg4479919/#msg4479919
https://www.eevblog.com/forum/projects/smd-test-fixture-for-the-tektronix-576-curve-tracer/msg4554053/#msg4554053
So our efforts are for more towards a "simple passive" Curve Tracer for use with standard DSO and AWGs which most folks should have available.
We are not that well versed (obviously!!) with the Rigol DHO814 and only use it occasionally, we have a couple Siglent DSOs as our "go too" DSOs.
Best
Offline AndyBig
  • Country: ru
« Reply #3480 on: February 09, 2025, 03:50:20 am »
It's convenient for me when I can expand the measurement window for a short time with one tap, look at the readings in it and collapse it back. And now, when 3-5 measurements take up a small part of the screen at the bottom right, they don't interfere with monitoring the signal that much :)
Yes, perhaps this would be the most convenient option.
Offline Chance
« Reply #3481 on: February 09, 2025, 06:15:11 am »
I just got a Rigol DHO804 and am having trouble using ADB to connect to it. When I use the command adb connect <IP>, it says it's connected on the command line, but a 'remote cmd error' pops up on the scope. I was wondering if any of you have encountered this problem before and know of a fix.
Offline cte
« Reply #3482 on: February 09, 2025, 10:21:14 am »
@Chance: Did you use the correct port number?
adb connect <IP>:55555
⚡ To avoid electric shock, ensure that your instrument is correctly grounded.
Offline iMo
  • Country: mu
« Reply #3483 on: February 09, 2025, 05:22:23 pm »
..So our efforts are for more towards a "simple passive" Curve Tracer for use with standard DSO and AWGs which most folks should have available..
Interestingly this has jumped off YT at me today (6 transistors + DUT):
https://www.eddybergman.com/2017/06/simple-but-effective-transistor-curve.html
1980:
https://archive.org/details/ElektorMagazine/Elektor%5Bnonlinear.ir%5D%201980-09/page/n37/mode/2up
« Last Edit: February 09, 2025, 05:44:58 pm by iMo »
The following users thanked this post: AndyBig, mawyatt, kbskn
Offline Chance
« Reply #3484 on: February 09, 2025, 05:28:24 pm »
I believe so, 5555 right?
Offline iMo
  • Country: mu
« Reply #3485 on: February 09, 2025, 05:31:52 pm »
five fives..
Offline Chance
« Reply #3486 on: February 09, 2025, 05:34:41 pm »
Well I feel like an idiot thank you very much
Online mawyatt
« Reply #3487 on: February 09, 2025, 05:59:59 pm »
1980:
That's a very clever circuit, hats off to Eddy Bergman who apparently created it :clap:
The method we mentioned uses your DSO and AWG and 2 or 3 resistors for the simplest implementation. We can elaborate if anyone is interested, but better to start another thread or add to this thread about such.
https://www.eevblog.com/forum/testgear/fooln-around-with-dso-awg/msg4421209/#msg4421209
Best
« Last Edit: February 09, 2025, 06:07:32 pm by mawyatt »
Offline Purserje
« Reply #3488 on: February 10, 2025, 04:41:28 am »
I have a new 914 with firmware 1.03.  Are there any updated directions on making it identify as a 924?
Offline Fungus
« Reply #3489 on: February 10, 2025, 04:48:57 am »
No. The old ones still work.
Offline AndyBig
  • Country: ru
« Reply #3490 on: February 10, 2025, 10:14:49 pm »
Added a small bottom panel in full-screen mode with information about the channel scale and sampling mode/frequency. It can be inconvenient when you are in full-screen mode and do not see this information.
At the same time, I fixed a couple of small errors in the previous version :)
In the coming days, I will post a new release on GitHub.
The following users thanked this post: jundar, ebourg, dy008
Offline ebourg
« Reply #3491 on: February 11, 2025, 06:43:58 am »
Good idea, and maybe the full-screen buttton could be used to cycle through 3 modes: normal, full-screen, full-screen with bottom panel.
Offline Fungus
« Reply #3492 on: February 11, 2025, 07:27:26 am »
Nah, it would be annoying to have to press it twice to get out of fullscreen mode Every Single Time.
« Last Edit: February 11, 2025, 07:36:31 am by Fungus »
Offline AndyBig
  • Country: ru
« Reply #3493 on: February 11, 2025, 10:54:09 am »
I agree with Fungus - the triple action of the fullscreen icon will reduce the comfort of using fullscreen mode.
Instead, I would suggest something like a small icon in the window title to show and hide the information panel. Although in my opinion this panel is small enough as it is :)
Offline RAPo
« Reply #3494 on: February 11, 2025, 11:40:28 am »
Maybe I'm upping the ambition a bit too much, but could we tap into the rotary encoder? From the starting position, one click forward is fullscreen+panel, and one-click backwards is fullscreen?
That gives:
fullscreen            <-   start-screen          -> fullscreen + panel
fullscreen+panel  <-   full screen            -> startscreen
startscreen          <-  full screen + panel -> fullscreen
Offline AndyBig
  • Country: ru
« Reply #3495 on: February 11, 2025, 02:22:12 pm »
But all encoders are busy with other functions. Even encoder "2" is busy when cursors are active.
The following users thanked this post: RAPo
Offline AndyBig
  • Country: ru
« Reply #3496 on: February 11, 2025, 05:01:39 pm »
The new release a006 is published on GitHub :)
- the space between measurement points has been reduced
- saving and restoring the appearance of measurement points has been made - specifying channels by names or colors
- a bug has been fixed: the "Change item" item in the measurement points menu did not work
- a bug has been fixed: the signal window did not expand to full screen with the first click on the expansion icon
- in full-screen mode, a small panel has been added at the bottom with information about the sampling mode/frequency and channel scale
- when clicking on the scale value in the information panel in full-screen mode, the channel settings window opens
The following users thanked this post: TurboTom, Obiwantje, iMo, F14V, lownoise, ebourg, zelectronicauy
Offline AndyBig
  • Country: ru
« Reply #3497 on: February 13, 2025, 05:06:04 pm »
I added a small button to the window title, as I wrote earlier. When you click on it, the information panel below can be hidden and shown. Its state is saved even when you turn off the oscilloscope :)
This will appear in the next version.
The following users thanked this post: TurboTom, Obiwantje, RAPo, ebourg, zelectronicauy
Offline mrisco
  • Country: pe
    • Github Profile
« Reply #3498 on: February 14, 2025, 07:20:02 am »
This is a proof of concept of an editable button panel, the configuration file will be a simple text file in JSON format stored in the user storage space, the panel can have many buttons, it is scrollable and currently supports chained SCPI commands and launching applications.
Offline Fungus
« Reply #3499 on: February 14, 2025, 11:55:17 am »
Can the scrollable button panel at top right be edited? It would be cool to be able to just replace it with one or two items that don't have a physical button on the front (eg. "decode").
Or make it into one user-selectable button plus this popup.
(After that we'd want an app to configure the user interface options without editing those pesky JSON files.  ;) )
