Author Topic: Hacking the Rigol MSO5000 series oscilloscopes  (Read 1755931 times)
0 Members and 39 Guests are viewing this topic.
Offline maginnovision
Re: Hacking the Rigol MSO5000 series oscilloscopes
« Reply #1050 on: May 06, 2019, 08:44:25 pm »
If it's not in the (your country here) user manual but it is on the scope, it's an unpublished hacked feature.
« Last Edit: May 06, 2019, 11:09:46 pm by maginnovision »
Offline angelo
« Reply #1051 on: May 06, 2019, 08:48:41 pm »
Reasonable, anyone care to investigate if TIE in jitter menu is non-functional as well?
Offline TK
« Reply #1052 on: May 06, 2019, 09:01:38 pm »
Isn't Jitter measurement part of the power analysis feature, opened by the hack?
Offline TopLoser
« Reply #1053 on: May 06, 2019, 09:11:49 pm »
Best to ask somebody who has purchased the power analysis feature, not hacked to enable all options.
Offline angelo
« Reply #1054 on: May 06, 2019, 09:48:40 pm »
Not according to Rigol, I thought the same though. Seems like it's a holdover from the code locked out on lower model numbers but available on the 7000.
Offline timber23
« Reply #1055 on: May 06, 2019, 09:54:19 pm »
This is how it looks like over here:
I don't have this jitter analysis.
Offline Frex
« Reply #1056 on: May 07, 2019, 04:24:27 pm »
Hello,
I think as for the DS7000 series], jitter measurement is done with histogram analysis (that you show on right side menu).
Frex
Offline timber23
« Reply #1057 on: May 07, 2019, 07:47:14 pm »
This is how histogram looks like:
There are two modes in Power-analysis: Ripple and Power-Quality.
I don't have the necessary current probe, hence the results are bogus:
Best regards
timber23
Offline 2N3055
  • Country: hr
« Reply #1058 on: May 07, 2019, 08:19:25 pm »
Why would jitter measurements be in power analysis?
Jitter measurements are clock/ timing related, for digital clocks and serial communications and such.
Not much to do with power measurements.
It makes sense to be connected with histograms though.
Dr. Richard W. Hamming
Offline TK
« Reply #1059 on: May 07, 2019, 09:03:58 pm »
Maybe to analyze switching power supplies?
Offline 2N3055
  • Country: hr
« Reply #1060 on: May 07, 2019, 09:18:15 pm »
In power applications you analyse PWM modulation and call it modulation analysis.
You can do it with built in measurements + stats.
Jitter analysis implies measurement of clock/edge stability of something that has to be very stable. It is basically noise analysis in time domain..
Both are timing analysis, but using different methods and for different purpose.
Offline Sighound36
« Reply #1061 on: May 08, 2019, 11:29:16 am »
If I go to measurement, analysis, and jitter analysis. In PLL mode with a 1MHz FM modulated 10MHz carrier my scope freezes.
I emailed rigol support and they said this feature is not available to North America. I don't understand why this would be the case.
Can anyone else replicate, confirm, or offer advice?
Hi Angelo
Mine to, however I am located in the UK, also purchased  power analysis option with the scope.
The hack worked fine thank you chaps  8)
Every time I use the jitter feature (tie mode) and switch in jitter spectrum it freezes, also when using the jitter trend mode it runs for around a couple of minutes then locks up
The scope locks up in normal and high res modes as well
All other features are fine more than likely a firmware issue that has missed the beta testers at Rigol?
« Last Edit: May 08, 2019, 11:35:47 am by Sighound36 »
Offline angelo
« Reply #1062 on: May 08, 2019, 11:55:37 am »
Hi Angelo
Thanks for the confirmation Sig.
To those above, the option is not under histogram but has a separate option in the analyze window after those in the unhacked option. I don't have access to the scope at the moment to screenshot.
I'd be interested to hear if anyone does get this feature operational, or can confirm that it is bugged, or that it is non functional but option is just enabled in the 5000 hack.
Offline TK
« Reply #1063 on: May 08, 2019, 12:11:13 pm »
You can just remove the hack and verify it yourself
Offline angelo
« Reply #1064 on: May 08, 2019, 12:30:23 pm »
I'm sure that it will go away if disable the hack.
What I meant was, perhaps my settings/test is bugged and the feature works. Or, perhaps it just shows up but will never work.
Offline TK
« Reply #1065 on: May 08, 2019, 12:56:56 pm »
You are correct.  I misunderstood your question.
Offline Sighound36
« Reply #1066 on: May 08, 2019, 02:47:29 pm »
Hi Angelo
I also have a 'feature disabled' notice when I press the histogram function in the jitter measure menu which maybe a clue that TK was eluding to possibly?
A couple of images below of the 'new features'
« Last Edit: May 08, 2019, 03:12:29 pm by Sighound36 »
Offline stenbror
  • Country: no
  • Software developer / Electrical Engineer
« Reply #1067 on: May 12, 2019, 03:15:45 pm »
Hi. Got my Rigol MSO5074 may, 8th and by May 12th it is "upgraded" with all options. Thank you very much to everyone made this possible...... Smiling big!
Offline mrpackethead
  • D Size Cell
« Reply #1068 on: May 13, 2019, 02:45:07 am »
Loving your work everyine.
Offline swansonbroth
« Reply #1069 on: May 16, 2019, 05:58:51 am »
Good Morning everyone,
I got mine yesterday - MSO5354.
FW is 00.01.01.04.04.
Where I can find the file to get all the possible options?
And what are the right steps? only Upgrade the FW with the file from here?
Best regards
Offline core
« Reply #1070 on: May 16, 2019, 07:20:04 am »
Yesterday my MSO5074 has arrived. Factory installed firmware 00.01.01.04.04.  Hardware 01.00.000.
I've read the instructions and now is full option  :box:
It took about 5 minutes, I appreciate your work here  :clap:
Indeed, it's the best option to buy, and not only for a hobby work.
I was very close to order a Siglent because of somehow better included features (bode plot was one of them) and a better analog input stage for low signal but I really don't need 1mV/div, a true 4mV/div is fine.
I hope that bode plot will be included in the end, the sooner the better  :)
8GSamples, 200M deep memory, 9 inch display, included dual channel signal generator, etc. No competition for the price, of course with 'patch' applied.
Also, the mechanical power switch is way better than the "soft" one. Not only for environment friendly, but also for a long term power supply reliability.
The airflow noise it's there but it's not a big problem. The noise from the sleeve or ball bearing is more important.
Fan noise is like an old style PC power supply. For the moment is ok. In the future I will see if it worth to replace it.
Best regards !
« Last Edit: May 16, 2019, 08:51:17 am by core »
Offline core
« Reply #1071 on: May 16, 2019, 07:59:45 am »
@ swansonbroth
You can find all the informations here :
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopes/msg2251401/#msg2251401
It seems that you have the latest firmware (00.01.01.04.04), so just apply the backup and the 'update patch'
Succes !
« Last Edit: May 16, 2019, 08:49:05 am by core »
Online Martin72
« Reply #1072 on: May 16, 2019, 06:24:01 pm »
Why, when you already got the DS7014 ?
Online tv84
  • Country: pt
« Reply #1073 on: May 16, 2019, 08:38:23 pm »
Hack benchmarking...
Offline sbehnke
« Reply #1074 on: May 17, 2019, 04:43:03 pm »
I installed this and it seems to have worked perfectly, with one exception. I cannot get the probe to compensate correctly on channel 1. On the other 3 channels I can get the probe compensated, but Channel 1 has a hump above the peak of the square wave regardless of the probe I use. Is this something wrong with the scope, or something wrong with the hack? Should I roll back to the non-hacked version? I'm not entirely sure how to resolve this.
Thanks,
Steven
