Author Topic: Hantek - Tekway - DSO hack - get 200MHz bw for free  (Read 2205286 times)
Tehnik and 8 Guests are viewing this topic.
Offline chsn
Re: Hantek - Tekway - DSO hack - get 200MHz bw for free
« Reply #3000 on: August 03, 2019, 07:35:53 am »
Received from Hantek for:
MSO5202D
sw 3.2.35 (131029.0)
hw 1010x55558340
sn t1g/012016xxx
new firmware
https://yadi.sk/d/Tm1Esxa9iyWm4w
The following users thanked this post: Input220v
Offline Microcheap
« Reply #3001 on: August 03, 2019, 04:32:51 pm »
I got a DSO4102C with a similar problem, pressing a button, the selected function won't work, the oscilloscope is too slow to respond or a completely different function is activated. After rebooting the device, it works normally for some time and then it start to showing the problem again.
I tried to restore the system and updated the FW but it did not work, Hantek's support said it might be a defective keyboard that need to be replaced.
If you have the option, return it to the seller and get a new one.
Offline tinheadTopic starter
« Reply #3002 on: August 03, 2019, 04:35:21 pm »
MSO5202D
hw 1010x55558340
sn t1g/012016xxx
new firmware
unpacked and renamed mso_bin to mso.exe does even runs on my hw1007 version (because i have all kind of libs manually copied to it).
It would be nice to know some kind of changelog from Hantek … @chsn, could you ask them?
« Last Edit: August 03, 2019, 04:37:01 pm by tinhead »
Offline aandrew
« Reply #3003 on: August 04, 2019, 03:13:50 pm »
@tinhead I think it was you who mentioned you had a pinout file for the FPGA and maybe a memory map of which buttons/controls were where... If this is true and you could share it perhaps we could take a crack at a first third-party UI for this thing. It's not bad hardware but the software is awful.
« Reply #3004 on: August 04, 2019, 08:10:49 pm »
i made complete schematics of DSTxxxxA, DSTXXXXB hw0, hw1007 DSO's (one can use hw1007 as well for hw1005 and partialy for other models). I should have somewhere as well some Memory map etc. description, i have to check in my archive files, have not touched Tekway/Hantek reversing since years anymore. More important is, for which model/series would you like to know more?
Offline wwoofbum
« Reply #3005 on: August 15, 2019, 11:51:24 pm »
Recent purchase of Hantek DSO5072P with the specific intention of implementing the 200MHz hack.  Having the same problem as Checksum47 on attempt to back up firmware: "Firmware update failed, error 0xfe, No upgrade files detected on USB device"
Model DSO5072P
sw version 3.40.0(180120.0)
hw version 1010xffff8108
UPDATE!
Okay, so maybe I'm not so bright...but...
Thought it might be my USB stick, so I tried another.  Same error.  So, I tried downloading the latest firmware from Hantek for the 5072P...got a new version 3.40.0(190125.0) and loaded it onto the USB stick.  Oscilloscope updated fine.  Deleted firmware update file and copied the update tool to the USB stick (as per tinhead's post).  This time it completed the update without error, my USB stick has the dump folder, and my timebase now goes down to 2.00ns.
« Last Edit: August 16, 2019, 02:51:14 am by wwoofbum »
Just because you can, doesn't mean you should.
Offline Zhenek
  • Country: ru
« Reply #3006 on: August 27, 2019, 07:42:17 am »
I've got a Hantek DSO4102C, all is OK, but I can't figure out how to make screenshots. It seems that DSO5102 series have a button named "Save to USB", but 4102C doesn't. Is there a way to capture screen to USB sticks?
Offline cliffyk
    • PaladinMicro
« Reply #3007 on: August 27, 2019, 01:20:52 pm »
According to the manual it is a sub-function of the Utility menu (when all else fails, read the manual):
-cliff knight-
paladinmicro.com
Offline Zhenek
  • Country: ru
« Reply #3008 on: August 27, 2019, 03:17:54 pm »
This one I've seen, but it don't help at all. This menu likes like in attached photo. I don't have any idea where to press. As I said, this scope doesn't have a dedicated "Save to USB" physical button.
Also I don't understand how can user "click on the icon" since the instrument don't have touch screen.
Offline Microcheap
« Reply #3009 on: August 27, 2019, 04:41:29 pm »
Not the most intuitive but it is possible: Press "Utility" button then, on page 1/3 of the menu use F3 do select the option "Save Waveform". Now use F1 to choose between "position" and "Screenshot" options. That will set the function of the position knob of CH1. With "Screenshot" selected, just press the knob to capture the screen to the USB stick.
Offline cliffyk
    • PaladinMicro
« Reply #3010 on: August 27, 2019, 05:46:24 pm »
Microcheap is spot on... I had missed that you had a revision "C" 'scope. Even with the manual in front of you it is still less than clear how to save a waveform:
-cliff knight-
paladinmicro.com
Offline Zhenek
  • Country: ru
« Reply #3011 on: August 28, 2019, 07:16:00 am »
cliffyk, thanks!  Sorry for dumb questions.
In my defense:
  • Scope came without printed manual
  • Manual from the quick Google search turned out to be from DSO4000 series, which didn't help
  • Built-in manual has zero information on the subject
  • The method to take screenshots is at least counter-intuitive
Offline cliffyk
    • PaladinMicro
« Reply #3012 on: August 28, 2019, 10:44:43 am »
Hantek has the 4000C manual on their site (this is a download link)...
-cliff knight-
paladinmicro.com
Offline aandrew
« Reply #3013 on: August 31, 2019, 03:55:54 am »
My board is a "T55 00313" (sticker on the back is "T 1G/655 000313"). Status screen says the hardware version is "10020x540282051002". It's an MSO5074FG.
« Reply #3014 on: August 31, 2019, 02:02:06 pm »
MSO5074FG is not that different, sure it have 4 channels, some fancy mux for them, then an extra pcb with Signal Generator (typical Hantek design, changed only a bit to add LA channels).
Offline aandrew
« Reply #3015 on: August 31, 2019, 02:44:26 pm »
Yep, it's very, very similar to the 2-channel versions. It's a pity that some very basic things such as channel deskew and logic analyzer sync with analog weren't implemented, it really hinders what this otherwise quite capable little scope can do.
Were you able to dredge up your old notes (memory map, fpga notes, etc.)?
« Reply #3016 on: August 31, 2019, 02:58:00 pm »
no, unfrotunately can't read my backups from old Laptop :(
I remember that the most discovered part was based on debug executables (they still on my 1drv) and old Hantek/Tekway SDKs (they let by mistake i think some utils and Sources of them).
Offline aandrew
« Reply #3017 on: August 31, 2019, 03:24:09 pm »
I think I've grabbed your 1drv before, thank you for that.
Looking through it again, I see some @dcompiled_101_apps directory within an fpga.zip and some other goodies... gonna poke around here again.
Thank you again for all of your hard work.
« Reply #3018 on: August 31, 2019, 04:17:21 pm »
btw, if you have a chance, please dump the content of the 25L4006 from the DDS/LA addon board.
Offline coromonadalix
« Reply #3019 on: October 02, 2019, 05:40:08 am »
Hi  is there a repo  or a file hosting for the dso-usb-tool  file,  cant find it ?  The first OP thread has invalide links.
Thks
« Reply #3020 on: October 02, 2019, 12:24:52 pm »
thks @PeDre
Offline Appocalypse_br
« Reply #3021 on: October 02, 2019, 05:54:20 pm »
Hi is there any chance i can do this in the PC USB 6104bc series, mine seems to be dead, if anyone have some info how to write\hack into these models will be great.
Or if you have the same one and send me the firmware eeprom etc will be nice!
Thanks!
Offline BobGeorge976
  • Country: cs
« Reply #3022 on: October 03, 2019, 07:12:29 pm »
Hello! Today I've got my Hantek DSO5072p and I have crossed over this topic and to me is still unclear is it possible to upgrade this device ... or not? Thanks in forward!
If you want to rise - first you have to fall!
  • Country: cs
« Reply #3023 on: October 03, 2019, 07:41:51 pm »
 My Hantek 5072p already goes to 2ns but my sw is older. Any sugestions what should I do?  :-//
« Last Edit: October 03, 2019, 07:48:28 pm by BobGeorge976 »
Offline Slash200
« Reply #3024 on: October 07, 2019, 06:07:29 pm »
download from my 1drv, from firmware, version, model folder the proper/latest file.
There is even a way to run firmware from Feb 2018 on hw1007 platform (like i do on my old hw1007),
but it's bit tricky (one have to copy over ssh some libs first, updates can be done only over lan/uart by copying latest only executable file).
Is it possible to you provide a manual how to do the update to the Feb 2018 Firmware?
I have firmware 2.06.3(130425.0) installed at the moment.
