Author Topic: Keithley 2000 / 2015 / 2016 / 2010 VFD to LED Display Conversion  (Read 14979 times)
0 Members and 11 Guests are viewing this topic.
Offline dimmogTopic starter
    • Hubequip
We've just started our second VFD to LED display conversion project!
This time it's for the Keithley 2000, 2015, 2016, and 2010 multimeters.
This display is also compatible with the Keithley 6485 / 6487 Picoammeters and Keithley 2182 / 2182A Nanovoltmeters.
It also appears that the display is only partially compatible with models like the 2700, 2701, and 2750, as they have slightly different annunciators.
The original VFD used is part number DD-52. If you know of any other Keithley instruments that use this display, please drop a comment.
Our goal is to have the new display ready by August September November 2025.
The display available here for $79: https://hubequip.net/products/keithley-2000-2015-2016-2010-vfd-display-replacement-led-display-conversion-kit
and on ebay for $89 https://www.ebay.com/itm/326836185343
« Last Edit: August 19, 2026, 06:52:26 pm by dimmog »
Hubequip.net :: test equipment parts and more
www.hubequip.net
The following users thanked this post: lowimpedance, croma641, wraper, yo0, coromonadalix, ch_scr, syau, KungFuJosh, w.v.s., PascalNE
Offline picburner
Re: Keithley 2000 / 2015 / 2016 / 2001 VFD to LED Display Conversion
« Reply #1 on: June 18, 2025, 06:39:51 pm »
The Keithley 2001 uses a different display, the DD-51 which is dual row.
You will have to do a later project for the K2001 and K2002 ;)
The following users thanked this post: dimmog
    • Hubequip
« Reply #2 on: June 18, 2025, 07:14:18 pm »
Good catch. I mixed it up with the 2010. Thanks
www.hubequip.net
Offline BennoG
Re: Keithley 2000 / 2015 / 2016 / 2010 VFD to LED Display Conversion
« Reply #3 on: June 18, 2025, 07:46:46 pm »
I was planning a oled conversion for my 2 units with dim display.
But your solution will save me a lot of time so I will be following this post.
Benno
Offline Smokey
  • Not An Expert
« Reply #4 on: June 18, 2025, 08:14:27 pm »
Marked for when my 2700 needs a new display.  Thanks for doing this work.
Offline kloetpatra
« Reply #5 on: June 18, 2025, 10:05:28 pm »
nice, i hope there will be a color that comes close to the original vfd and not this cheap standard blue
    • Hubequip
« Reply #6 on: June 19, 2025, 09:08:51 pm »
I think it'll be a nice surprise here.
It looks like we've got a better color option now.
Our supplier in China recently started offering new LEDs with a bluish-cyan hue that's much closer to the original VFD and a little better than the standard blue ones.
www.hubequip.net
Offline Kjelt
« Reply #7 on: June 19, 2025, 10:02:29 pm »
Also following for purchase  :-+
Offline AntoshC
« Reply #8 on: June 20, 2025, 05:35:53 pm »
I am also watching this for the Keithley 2001.
Nice job!
    • Hubequip
« Reply #9 on: June 20, 2025, 05:47:30 pm »
Nice job!
Thanks. Unfortunately, creating an LED replacement display for the Keithley 2001 isn't possible. It uses a dot-matrix style VFD with an integrated controller, making it extremely difficult to design a compatible LED-based alternative in terms of this LED display technology limitations.
www.hubequip.net
Offline artag
« Reply #10 on: June 27, 2025, 11:13:22 pm »
Is that the same dot-matrix VFD used for the 2410 source meter ?
    • Hubequip
« Reply #11 on: June 28, 2025, 04:32:02 am »
Yes, the Keithley 2410 uses the same display module as the 2001.
www.hubequip.net
Offline BennoG
« Reply #12 on: June 28, 2025, 06:39:06 am »
yes but we are talking about the 2000 and that uses a completely different display.
The 7001 uses the same display as the 2001 and 2400 only the pins are bent slightly different on the 2400 than the 7001.
the 7001 are cheap on eaby. (attached picture top one is 2400 bottom one is 7001 still in its housing)
Benno
« Last Edit: June 28, 2025, 07:25:15 am by BennoG »
Offline coromonadalix
« Reply #13 on: June 28, 2025, 05:37:23 pm »
for the VFD's  with integrated driver ic's in them,  you would need extensive debugging, data sniffing protocol decoding and create an MCU based interface board  and add your oled or led solution
IF it is doable,  and you need the place and ways to add it in the dmm
always easy to say i want one ... but doing so ...  takes time and dedication
some members here did miracles ... but they have their life too
    • Hubequip
« Reply #14 on: July 02, 2025, 04:23:09 am »
Project update.
We've selected the current-limiting resistors, and the display looks fantastic. Now it's time for some extended testing.
What do you think of the LEDs color?
www.hubequip.net
The following users thanked this post: kilobyte, Kean, yo0, nidlaX, Qw3rtzuiop, ch_scr, KungFuJosh, the Chris
Offline nidlaX
« Reply #15 on: July 02, 2025, 05:39:32 am »
Great choice of colors, better than the bright blue LEDs for the previous revision IMO.
The following users thanked this post: Qw3rtzuiop, dimmog
Offline the Chris
« Reply #16 on: July 02, 2025, 07:10:21 am »
Looks great and is probably better readable for many.
Offline Hydron
« Reply #17 on: July 02, 2025, 09:56:07 am »
Yep much easier for your eyes to focus on than pure blue. Now you're tempting me to grow my Keithley collection with one of these meters (won't need to worry as much about VFD issues)!
Offline Qw3rtzuiop
« Reply #18 on: July 02, 2025, 10:29:48 am »
The color looks great. The color of your 53131a LED display kept me from buying it.
« Reply #19 on: July 02, 2025, 03:58:13 pm »
yep nice color   :-+
Offline Kjelt
« Reply #20 on: July 02, 2025, 03:59:27 pm »
I also like the color  :-+
Offline KhronX
    • Khron's Cave - Electronics Blog
« Reply #21 on: July 03, 2025, 11:22:20 am »
Any idea about the ballpark cost of one of these?  ;D
My 2015 has a few dimmer segments / characters "already"...  :palm:
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
Offline Rubo
« Reply #22 on: July 03, 2025, 03:39:56 pm »
Just to make sure...
Are you going to be offering the new color for 53131A/53132A/53181A also or only for the Keithley line?
    • Hubequip
« Reply #23 on: July 03, 2025, 08:18:27 pm »
The pricing will stay the same as it was for our initial display.
www.hubequip.net
    • Hubequip
« Reply #24 on: July 03, 2025, 08:27:19 pm »
These are brand new LEDs that weren't available when the 53131A LED project began.
Honestly we need to sell the first batch of blue displays before we can offer the new color, assuming there's still demand.
www.hubequip.net
