Author Topic: Magnova oscilloscope  (Read 408263 times)
0 Members and 115 Guests are viewing this topic.
Offline woody
Re: Magnova oscillosc
« Reply #1025 on: July 07, 2025, 09:47:08 am »
Again, the magnova, as any other flex cable, can hardly be pulled out of the scope without pulling on the flex cable.
Although I do not see myself breaking these flatcables anytime soon this discussion could have been prevented if Batronix would have used these plastic (or fabric) loops under the strain relief that you can pull on to get the plug out. A cheap solution with the added advantage that the plug is pulled straight up out of the connector instead of being pulled slightly to one side which happens when you pull on the flatcable. This makes disconnection a bit easier. But I'll live with the current solution which will probably outlive me.
I find the cable identification used (print-on white shrink tube) a more worrying choice. I use this print-on material for some projects and in my experience the printed text comes off quite easily. And indeed, rubbing my fingers over the channel numbers did immediately make it smear a bit and make the text less legible. So I wonder how long this will survive my sweaty fingers. Apart from that the text is difficult to read when inserted in an EZ hook and hanging somewhere on a PCB.
Why not use resistor color coding (brown -> grey) for cable colors? That never comes off and is much easier to read / interpret. It might clash with the colors available for the digital channels in the scope but that would definitely be my preference.
The following users thanked this post: nctnico
Online KungFuJosh
  • TEAS is real.
« Reply #1026 on: July 07, 2025, 02:33:20 pm »
Color coded shrink wrap that matches the default digital channel colors would be the easiest thing.
Best Continuity Tester Ever
Offline Ulrich.G
Re: Magnova oscilloscope
« Reply #1027 on: July 08, 2025, 12:46:05 pm »
It was included in the delivery, so it's original.
Hello Martin,
which brand is this hardcase you are using to store the SPL2016?
Offline Martin72
« Reply #1028 on: July 08, 2025, 12:59:57 pm »
Hello Ulrich,
I got it for the logic probes and the deskew board, and I'm going to get it again for the Batronix logic probes:
Case
The following users thanked this post: Ulrich.G, Christian K
Offline woody
« Reply #1029 on: July 08, 2025, 01:19:15 pm »
As it is now the wire colors match the channels yet I had my first mix up between D0 and D4, both yellow, within 5 minutes of toying with the probes. To each their own, but I prefer that every wire coming out of one unit has its own unique color except for the GND wires that can be (and are) black.
Offline Martin72
« Reply #1030 on: July 08, 2025, 01:41:28 pm »
I don't think it's as bad as it was in the SPL2016, with two groups, even if they are the same colours.
(Incidentally, the grey ribbon cable has a coaxial structure.)
Offline egonotto
« Reply #1031 on: July 08, 2025, 03:38:49 pm »
Hello,
my Siglent SPL2016 came in a simple cardboard box, not in a nice case.
Best regards
egonotto
Offline Martin72
« Reply #1032 on: July 08, 2025, 03:49:56 pm »
Mine too. ;)
Online KungFuJosh
  • TEAS is real.
« Reply #1033 on: July 08, 2025, 04:04:35 pm »
Mine came in a plastic bag. 😅
Offline Martin72
« Reply #1034 on: July 09, 2025, 11:57:33 am »
Hello Ulrich,
Case
Arrived today and immediately prepared, looks good.
Better than in the ordinary cardboard box, for just over €20. 8)
Now I have three of the same cases, I'll have to ask Batronix if they can give me some stickers with the company logo... ;)
The following users thanked this post: KungFuJosh, Andre77, Christian K
Offline Sorama
« Reply #1035 on: July 09, 2025, 02:43:58 pm »
Someone likes cases  ;D
Offline MadTux
« Reply #1036 on: July 13, 2025, 02:42:00 pm »
What's the specs on logic analyzer btw?
Sample rate vs number of channels?
Memory vs number of channels?
Shared memory with DSO?
« Last Edit: July 13, 2025, 02:43:51 pm by MadTux »
Offline Sorama
« Reply #1037 on: July 13, 2025, 03:47:12 pm »
You can find most of that info in the datasheet of the scope.
Offline Martin72
« Reply #1038 on: July 13, 2025, 03:57:00 pm »
But it's a bit hidden, so I'll take the liberty of highlighting it a little....
In short, the maximum sample rate is 1.6GSa/s, and the maximum memory (which naturally comes from the scope itself) is 327.2Mpts.
« Last Edit: July 13, 2025, 03:59:14 pm by Martin72 »
Offline Sorama
« Reply #1039 on: July 13, 2025, 04:04:24 pm »
It’s not a matter of being hidden, but of being lazy  :horse:
« Last Edit: July 13, 2025, 07:19:32 pm by Sorama »
Offline Martin72
« Reply #1040 on: July 13, 2025, 06:35:13 pm »
I made it myself with a label printer...
Offline woody
« Reply #1041 on: July 14, 2025, 08:01:44 am »
Is that a Brother? If so can I get a copy of the .lbx file? I know, I'm lazy...
Offline Martin72
« Reply #1042 on: July 14, 2025, 11:36:54 am »
Hi Woody,
I created the label at home using my T50M Pro:
Supvan T50M Pro
Software as an app for your smartphone or PC.
We have Brother at work, so I could give you the file next week... ;)
Offline Sorama
« Reply #1043 on: July 14, 2025, 12:07:16 pm »
I would have put the label just in that square, but that is just me.
The following users thanked this post: Kean
Offline Martin72
« Reply #1044 on: July 14, 2025, 12:25:35 pm »
Not just you... ;)
I tried putting a label in the designated area yesterday, but failed because of the “bump” in the middle, which has to be sanded down first so that a label can stick there.
Until then, the label will remain where it is now.
Offline Sorama
« Reply #1045 on: July 14, 2025, 01:05:08 pm »
I wish I could sand off that bump in my middle :-)
The following users thanked this post: egonotto, tooki, KungFuJosh, Martin72
Offline Martin72
« Reply #1046 on: July 14, 2025, 01:14:41 pm »
 :-DD
Me too...
Offline egonotto
« Reply #1047 on: July 14, 2025, 02:57:33 pm »
Hello,
I think that would hurt a lot.
Best regards
egonotto
Offline Sorama
« Reply #1048 on: July 14, 2025, 04:03:29 pm »
Anyone remember this series on tv?
‘Such fun’
« Last Edit: July 14, 2025, 04:07:04 pm by Sorama »
Offline woody
« Reply #1049 on: July 14, 2025, 09:08:09 pm »
The Royle family! Can only be British 😀
