Now that the new firmware is released, I have a release candidate (
V1.48) for the TestController driver definition for use with the Magnova.
ETA: Attachment updated to V1.49.If you don't already have
TestController,
download it here:
https://lygte-info.dk/pic/Projects/TestController/TestController.zipThe features in my driver file
require a minimum version of V2.8.6 of TestController, which you will probably need to
download separately here:
https://lygte-info.dk/pic/Projects/TestController/TestController.jarYou will have a Devices folder installed when you setup TestController. It will either go to your Documents folder, or stay in the TestController folder depending on how you set it up (and whatever OS you're on).
Copy the attached text file into the Devices folder.
Then load
V2.8.6 or later of TestController, and switch to the
Load devices tab. Select Batronix Magnova from the device list, and specify your IP address. Then you should be able to click Reconnect and the Magnova should be detected.
From the main Commands tab, Popups gives you a lot of options for displaying information after Setup is complete.
Open the Setup popup dialog to configure the Magnova and select Measurement options. Explore this, there's a TON of stuff.
The Other popup menu button (below Setup) has a button for screenshots; you can right-click the screenshot image to save locally.
Minimum Magnova firmware is the latest V1.6.9.
Please read the notes in the beginning of the file. Included is the mention of a performance related bug:
If you update
Measurement Types with the "
Current Values" tab open, it might cause TestController to crash.
This is a tricky performance bug with TestController, and hopefully we'll resolve it soon. It won't likely affect the driver file for the Magnova either way. In any case, you can switch to the main Commands tab, then adjust all the Measurement options in the Setup popup, and then switch back to Current Values if you want to monitor something there.
To view the
Chart, you will need to enable logging on the
Commands tab, set the
Scales for chart on that tab, and then view the
Chart tab.
If you're unfamiliar with TestController, you can get help and more info in the
TestController thread.
An insane amount of work went into this, and while I've tested everything, it's possible I may have missed something. If you see something odd besides the aforementioned performance bug, please let me know. That being said, please mess around plenty first. There's a learning curve to using TestController as it has a TON of features, and this driver I made for it is one of the craziest available.
I will update this with newer versions after new features are added to the Magnova in future firmwares.
Thanks,
Josh
