Hi .
I have big problem with my RD6018 .
My RD6018 dead completly STM32 have go in short circuit and now i buy new STM32 circuit and short circuit is gone.
But now i need firmware to install on STM32 please let me know how i can do that and from where i can take firmware.
Thank you and please help me.
if the boodloader code is the same for 6018 and 6012 then flash this file and it should work.
Thank you for your help but i think not working.
I have change stm32 with another new one and i think no have bootloader .
I write your dump with STM32_ST_LINK_UTILITY is good ?
If i buy another device how i can back-up dump from STM32?
Thank you.
The file I have provided includes the bootloader+firmware, it is from the rd6012 with stm32f103 mcu.
In this cases i have more problems .
My processor is STM32F103RCT6 .
On the board have 25q32 and 24c04 i think one is flash and one is eeprom right ?
But i can write your dump with STM32_ST_LINK_UTILITY ? or need another software ?
Thank you for your help.
Yes, you can write the .bin file with st link or st prog (current st flash software) or openocd.
the 25q32 and 24c04 are used for storing settings and logging data i think.
It's been a while since i wrote code for this so am no sure.
darkspr1te
Hello.
Problem now is 24c04 i cant read with programer i think is faulty.
If remove chip from board can see on display Bootloader V1.10 fIRMWARE VERSION : V-,-- .
If i put back chip on board pwer up but nothing on screen.
Can hepl me with binary from 24c04 ?
Thank you again for help.
If you are seeing bootloader but not seeing the application version or even booting into applicaition you should do a firmware upgrade and see if it goes into the main app. if you are unable to read the 24c04 in a external programmer i would replace with a blank one, the factory firmware will write default value to this chip if blank, but if the system cannot read/write to a chip it will hang at that point while it retries.
darkspr1te
