Author Topic: Siglent SDS1104X-E and SDS1204X-E Mixed Signal Oscilloscopes  (Read 627340 times)
Online Martin72
  • Testfield Technician
Re: Siglent SDS1104X-E and SDS1204X-E Mixed Signal Oscilloscopes
« Reply #2350 on: March 12, 2023, 10:51:53 pm »
I borrowed the scope from work, just want it up to date. 8)
Offline nikitasius
« Reply #2351 on: March 23, 2023, 11:19:56 am »
Hi folks, are there are some teardowns from `SDS1204X-E` ?
Are they share the same front?
From Dave's videos (https://youtu.be/Kay4Jk2DHuE?t=565 & https://youtu.be/slBXLf4YKtA?t=1183)
Red is `SDS1202X-E`, green is `SDS1104X-E`. Why SDS1202X-E ? Cause it's used as en example in big (130+ pages) review here.
Also from a review (from eevblog "Siglent SDS1000X-E Bandwidth Discussion.pdf"): "It looks like the 100MHz SDS1104X-E not only uses essentially the same frontend as the 200MHz
models, there is also no physical bandwidth limit fitted.", while regarding the photos they are different.
There are idlers that want to have money without working and fools that are ready to work without becoming rich.
Offline BillyO
« Reply #2352 on: March 23, 2023, 01:46:41 pm »
The SDS1204X-E is exactly the same machine as the SDS1104X-E.  Exactly the same.  The only difference is the license code (and the sticker over the top of the screen).
You can take an SDS1104X-E, enter the right code, and it becomes an SDS1204X-E.  Many dozens here have done just that.
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
Offline Deso
  • Country: bg
« Reply #2353 on: March 23, 2023, 02:21:14 pm »
This may not be entirely true. SDS1104X-E is currently sold in 2 different HW versions - 01-05 and 09-06, so there will be some differences.
So far I can't find pictures of the newer HW version.
Also mine which is SDS1104X-e with HW 09-06 is showing very strange results with 200Mhz square wave signal (I know it is out of spec) and too much attenuation and I don't think that the frontend is capable of 200Mhz or is limited in the 09-06 version.
The following users thanked this post: nikitasius
Offline Mortymore
  • Country: pt
« Reply #2354 on: March 23, 2023, 02:50:48 pm »
Red is `SDS1202X-E`, green is `SDS1104X-E`. ...
SDS1202X-E > 2 channel scope (different from the other 4 channel scopes)
SDS1104X-E and SDS1204X-E > 4 channel scopes (the same hardware I assume)
Online bdunham7
« Reply #2355 on: March 23, 2023, 03:35:35 pm »
Have you upgraded it to 200MHz?  And where are you getting a 200MHz square wave?  If you want to test the front-end capabilites you'll need to use a clean sine wave or perhaps a fast edge at a much lower frequency.
Offline BillyO
« Reply #2356 on: March 23, 2023, 04:29:09 pm »
Mine is an 09-06.  I've done the license upgrade to 200MHz and it's within 3dB out past 230MHz as the 1.49 ns rise time will attest.  I believe others have even gotten a bit better.
Maybe you could take a screen shot and show us what you are seeing.
« Last Edit: March 23, 2023, 06:18:12 pm by BillyO »
Online 2N3055
  • Country: hr
« Reply #2357 on: March 23, 2023, 05:33:30 pm »
To look at 200MHz squarewave you need 1GHz + scope... 2GHz even better..
Explanation and reference please...?
Offline nikitasius
« Reply #2358 on: March 23, 2023, 10:13:47 pm »
Thank you for your answers!
Especially about different HW révisions.
Just a little about the purpose of the scope i'm looking for: to test pocket AB amps i wanna make for fun, check if power is clean also and do some fun with uart. Nothing professional, just a hobby fun.
In Siglent i appreciate features like 4 channels, 1GSa/s per group, pretty fast waveforms/s aaand FFT (which looks good after the reviews i've seen), slow on 1Mpts but it's 1Mpts, so noise is lower and more details. I say again, it's for audio freq & for "excited" AB chips (which could do 20MHz or 30MHz in theory if i screw the schematic).
Also for the other fun cases i've seen that with scope and some math you can check C, L and electronic components (but i have testers also). I wanna enjoy it in my 36.
So my fun budget is 500-600€, and i agree with Dave (from YouTube), that 1k will be overkill for my needs. Also, compared to "same" rigols siglent more sensitive.
Next about hacks: 100MHz is okey for me, i don't need 200MHz, also i don't need 16digit channels (just 4 analog) and don't need generator cause i can make my own (w/ scope) or buy any other brand. But i want 100MHz i'm paying for. So here we speak about the hack and the screenshot from the review.
Why the hek 100MHz have -1dB at 75MHz?.. i can't get in. 200MHz model is cool at 200MHz and you pay for 200MHz, but when you buy 100MHz you don't pay 50MHz scope or 75MHz scope. So if it's pure software crap, well, i will hack that FIR config and enjoy my 100MHz scope.
If the frontend is different and poor, well, i will enjoy nothing and lose factory calibration (seen these comments in topic) which was made for 100MHz scope.
So, did actual SDS1104X-E have poor front (or the other parts) compared to SDS1204X-E or it's just software "issues"? I've seen siglent folks in thread also, if they have no NDA, it could be good to know simple "no bruh, it's just software" or "yeah, don't even try to get real numbers with latest 1104 models at 80-90MHz".
Before i was targeting MSO5074, hacked, sure, to get 100MHz, but 8Gsa/s it's total overkill for me (again i'm agree w/ Dave).
Online 2N3055
  • Country: hr
« Reply #2359 on: March 24, 2023, 12:30:55 am »
You seem to be beginner in this, so here is a short explanation.
First you make conclusions based on several wrong information..
100 MHz scope means 100 MHz point is actually -3dB down...
That is industry standard way of specifying scope BW. True for any scope on planet.
Why so? Long story, already explained elsewhere many times..
Second, by "opening" scope to full bandwidth you don't "loose calibration". These scopes are fully 200MHz designs.
Different PCB revisions are simply that. Different revisions, that happens over product lifecycle..
For what you say is your intended use it should serve you very well..
Offline BillyO
« Reply #2360 on: March 24, 2023, 03:47:28 am »
-1dB is nothing but @ 75MHz that is very unusual for this scope.
Once again, can you provide some screen shots of what you are seeing?  We are blind right now.
Oh, BTW, the upgrade to 200MHz can be had for free .. just maybe 15-20 minutes of your time.  References to how are in this thread.  Read back ...
« Last Edit: March 24, 2023, 03:53:43 am by BillyO »
Online Performa01
  • Country: at
« Reply #2361 on: March 24, 2023, 09:46:05 am »
Traditionally, oscilloscope bandwidth is specified for 3 dB amplitude drop. For the usual Gaussian response in lower bandwidth scopes, the amplitude drop would be about 2 dB at 75 MHz for a 100 MHz scope. In the light of this, the Siglent SDS1104X-E is much better with only 1 dB drop at that frequency.
The reason is of course that the artificial bandwidth limit is accomplished by a FIR-filter that is not Gaussian. Those who ask why we don't choose a filter characteristics that has even less (ideally zero) drop up to the corner frequency should learn about the requirements for an oscilloscope frontend, especially group delay.
Online gf
« Reply #2362 on: March 24, 2023, 02:17:00 pm »
The reason is of course that the artificial bandwidth limit is accomplished by a FIR-filter that is not Gaussian. Those who ask why we don't choose a filter characteristics that has even less (ideally zero) drop up to the corner frequency should learn about the requirements for an oscilloscope frontend, ...
A "flat-top" frequency response comes at the cost of more overshoot in the step response. It's a trade-off.
An ideal Gaussian filter has the nice property of having no overshoot in the step response while minimizing the rise and fall time.
...especially group delay.
With a (symmetrical) FIR filter, frequency-dependent group delay is actually not an issue -- any symmetrical FIR filter is linear phase.
Online Performa01
  • Country: at
« Reply #2363 on: March 24, 2023, 08:28:57 pm »
Right. And knowing all this, how much overshoot do you think is acceptable so that we still can have a decent signal fidelity? It is - or at least should be - the goal for every serious oscilloscope to show the actual signal at its input, not the imperfections of its frontend.
There are many folks who complain loudly as soon as the overshoot with a clean squarewave input becomes even visible, let alone if it exceeds 3 %. And rightfully so.
Yes, there are situations where even a good (usually wideband) frontend might exceed 10 %, but these should be rare and limited to very unusual input signals.
Correct. The frontend has a certain frequency response itself, which we can see for the highest bandwidth model, such as the SDS1204X-E. Even the 200 MHz model will have more than 0 dB drop at 75 MHz, even with a perfectly flat FIR filter behind. Furthermore, there is no intention to have a vastly different frequency response characteristics for the lower bandwidth models, even when the bandwidth is limited by an FIR filter.
Offline nikitasius
« Reply #2364 on: March 24, 2023, 09:02:51 pm »
2N3055 yep, pretty new. Never had a scope before. Nice to know about -3dB certs 👍
BillyO which screenshots ? Here is the tread https://www.eevblog.com/forum/testgear/siglent-sds1104x-e-in-depth-review/
Performa01 & gf thanks for useful info!
Offline Deso
  • Country: bg
« Reply #2365 on: March 24, 2023, 09:11:01 pm »
It is not upgraded.
I don't have a sine source (yet :D) so I used my NanoVNA v2 (teardown here), which can be used as signal generator. It produces square wave signals. At 200Mhz I'm observing too much decreasing of the signal level and strange behavior of the offset while switching the vertical resolution.
I'll provide more information when I do more and proper measurements.
I was trying to find the limits of my new toy and noticed some strange behavior. But as I said - will provide more info when I'm sure in the results.
Offline BillyO
« Reply #2366 on: March 24, 2023, 09:45:54 pm »
Sorry, I thought you were actually seeing all this poor performance.  But I guess you are just imagining it?
As I said above, with the 200MHz enabled, you will not have any issues with bandwidth.
« Last Edit: March 24, 2023, 09:49:23 pm by BillyO »
Offline nikitasius
« Reply #2367 on: March 24, 2023, 10:26:47 pm »
Yep and my imagination could generate the pdfs and the screenshots. So who knows what could i imagine while answering you.
100MHz->200MHz not a problem. Good to know that it's a software issue and not a hardware (while visually thats different a bit)
Upd: 1104xe and 1202xe fronts at least.
Offline tony359
« Reply #2368 on: March 29, 2023, 08:30:33 pm »
Hi all
I don't seem to be able to update my 1104 to OS3. I tried with several USB sticks but nothing happens. OS is still listed at 8.2. Yes, I know there is probably little gain in going to 3 but that's another story!
Can anybody help me please?
Thanks
Tony
Offline tautech
« Reply #2369 on: March 29, 2023, 08:43:42 pm »
Hi all
Thanks
Tony
Check attached PDF to see if you actually need to install OS V3.
Avid Rabid Hobbyist
Offline tony359
« Reply #2370 on: March 30, 2023, 11:00:28 am »
Yeah, that was my comment about the little gain in updating. Still, why is it not updating?
Offline tautech
« Reply #2371 on: March 30, 2023, 11:06:25 am »
I had the same with my prerelease SDS1104X-E and OS V2 yet the features the new FW and OS supported did work.
Don't lose sleep about it.
Avid Rabid Hobbyist
Offline tony359
« Reply #2372 on: March 30, 2023, 11:09:56 am »
Not losing sleep and not expecting anything! :) I'm just curious and I'd like to know why it is not updating! :)
Online 2N3055
  • Country: hr
« Reply #2373 on: March 30, 2023, 12:08:52 pm »
Because you didn't check what hardware revision you have?
Is your scope System Status showing Hardware revision 09-xx ??
If number is less than 09 than you don't have new hardware revision and that update is not for you. That firmware has same functionality as previous one, but has added support for new MB in OS part.
Offline tony359
« Reply #2374 on: March 30, 2023, 03:38:57 pm »
It is
