Author Topic: Siglent SDS3000X HD and upgraded SDS1000X HD  (Read 584113 times)
Offline 2N3055
  • Country: hr
Re: Siglent SDS3000X HD and upgraded SDS1000X HD
« Reply #1025 on: October 07, 2024, 05:23:35 pm »
AFAIK, SDS7000A does but SDS3000xHD does not support USB decoding at this time...
240Mhz is recovered clock frequency and pulses are square wave so in order to be able to see at least 5th harmonic (so signal at least resembles something at least similar to square), 1.2 GHz BW would be needed.
Ah that's a shame - but yeah what you say makes sense...
I was trying to find where on earth I got the idea it did USB 2.0 decoding and it seems there is a PDF on the Siglent (EU) website here that, on page 25, shows a comparison of their various 12-bit scopes. The USB 2.0 decode option is clearly noted in both the SDS3000X-HD & the SDS7000A...
However checking the manuals it definitely seems only the 7000A has anything written here...
I'm wondering is @tautech may know more? I will send an email to Siglent EU anyhow... It reminds me of looking at the SHA850A spectrum analyser recently where they added some EMI features after and the manual still has no mention of them...
Anyway, ramble aside, I'll remain an optimistic fool and will report back if they give me a clear answer!
I personally can not confirm nor deny if that is in the cards or not. I simply do not have that information.
I know it does not have it now as we speak, and same for SDS6000A that is model up the chain.
6000A has 2GHz BW and it definitely should be able to sample fast enough. But there are other considerations so BW is not only choice maker.
And, in reference to your SA story, I am not quoting datasheet, I looked into scopes on their last FW.
Dr. Richard W. Hamming
The following users thanked this post: egonotto, seajayshore
Offline 2N3055
  • Country: hr
« Reply #1026 on: October 07, 2024, 05:38:21 pm »
]AFAIK, SDS7000A does but SDS3000xHD does not support USB decoding at this time...
Could just work... ;)
That's why I was surprised in the Magnova thread that it was said there that the USB protocol would be added later... at a maximum of 350Mhz bandwidth, that's a pretty ambitious thought, or they meant USB1.0.
That would also be possible for the 3000.
Like I said, 1GHz version of 3000xHD could marginally have enough BW to be able to decode but there are other considerations in addition to just BW alone. The future will show.
For Magnova, they meant USB 1.0 (Low speed & Full speed) probably.
My 1GHz Keysight MSOX3104T supports only USB PD.
Offline Martin72
« Reply #1027 on: October 07, 2024, 06:05:11 pm »
I also think that this is more of a nice-to-have, there are other more interesting things for me that I would like to see in 3000X.
Offline Dennis Frie
« Reply #1028 on: October 07, 2024, 06:21:59 pm »
I guess USB 2.0 decoding should work just fine, as long as you have a bandwidth around 240MHz (or better). Sure, you will not be able to validate signal integrity, but that's a completely different thing.
However, I've not seen any USB 2.0 decoding options for the SDS3000, guess they will keep that for the "pro" models.
Offline seajayshore
« Reply #1029 on: October 07, 2024, 07:19:29 pm »
Already got a reply from the Siglent EU person I've dealt with before!
And the winner is...........KungFuJosh
Exact reply from Siglent:
"It’s a copy paste error."
So R.I.P. this little feature - but at-least now we know!
The following users thanked this post: egonotto, KungFuJosh, Martin72
Offline 2N3055
  • Country: hr
« Reply #1030 on: October 07, 2024, 08:20:18 pm »
That is absolutely not enough BW for reliable decoding and triggering. This is not 240MHz sinewave.
Here are the scopes that have cca 270MHz, 370MHz, 650MHZ and slightly more than 1GHz BW:
With low bandwidth, eye starts to close vertically because of slow edges. Also, if BW is insufficient, DC bias starts to wonder, because not all PRBS combinations are DC balanced (exact point in testing with PRBS).
Looking at these results, I would say that in order to start decoding with any reliability, 500 MHz+ BW would be some start figure..
You could decode with less, but reliability might suffer. And even miniscule problems with probing and bus load will create all kinds of problems.
These are with PRBS signal that has edges risetime set at 1ns.
If we set signal to have 500ps risetime (with USB2.0 High speed you might have edges with 300ps risetimes), then 2000xHD starts getting confused with risetime being detected from 300ps to 4.7ns, very wide spread....
It is obvious is struggles, even with 650MHz BW.
But decoder might still work with this...
So I would say it is plausible that 500-600MHz scope might be able to decode USB2.0 High speed type of signal.
With caveat that this is with signal gen directly connected to scope with coax, X1 probe ratio. Spherical cow in vacuum scenario.
Any decrease in BW related to probing before scope input will contribute to decreased system BW and add noise.
For reliable signal integrity, you need 2-4GHz (110-250 ps risetime) scope because of cca 300ps edges in USB 2.0 High Speed. And matching active diff probe...
But thing is that USB is very busy protocol. Decoding it in scope would be very cumbersome. Scope is more useful here for exactly SI check and those lower BW scopes cannot do it right.  And decoding and triggering on the scope in this context is more meant for to be able to troubleshoot across electrical and software/protocol domains. Trying to figure out why specific message has problems and double checking it is not SI stuff. Or the other way around, seeing SI problem and figuring out where it will manifest itself..
But troubleshooting and debugging complex software by using scope to decode 10s of thousands USB datagrams  is not very efficient.
So manufacturers don't really press for decoding if scope can not also do proper SI...
The following users thanked this post: rf-loop, Performa01, egonotto, Andrew, mawyatt, seajayshore
Offline pasha
« Reply #1031 on: October 10, 2024, 10:20:31 pm »
Hi, I saved the sds3034x hd screen in csv format, then I recalled the saved file and it gave me the message "illegal file format".
I can open the saved csv file on the web page.
It can't load this format?
Can you save your own screen and try? Thanks.
Offline tautech
« Reply #1032 on: October 10, 2024, 10:46:45 pm »
No not supported.
Save as Ref file which can be recalled.
Edit to add
SigScopeLab Signal Analysis Software might do what your require....haven't had a real play with it.  :-[
https://www.siglenteu.com/service-and-support/firmware-software/pc-software/#sigscopelab
« Last Edit: October 10, 2024, 10:55:59 pm by tautech »
Offline pasha
« Reply #1033 on: October 10, 2024, 11:01:02 pm »
I tried with SigScopeLab, it still gives the same message
Offline tautech
« Reply #1034 on: October 11, 2024, 12:02:48 am »
Please share in detail your full requirements for a saved/captured CSV file.
Offline pasha
« Reply #1035 on: October 11, 2024, 08:08:58 am »
The file size is 60MB, uploading it here may be tiring, but you can save any screenshot in csv format and try it, there is no special situation.
Offline tautech
« Reply #1036 on: October 11, 2024, 09:00:49 am »
BIN files can also be saved and have the advantage of being much smaller than CSV.
In the Save/Recall menu and in the webserver there is a BIN to CSV convertor app for install to PC for doing these conversions.
Neither BIN or CSV can be uploaded/opened with the scope as they are intended for post capture PC analysis.
Offline pasha
« Reply #1037 on: October 11, 2024, 09:09:27 am »
I used Tektronix MDO4000 for a long time, you can use it by both saving and restoring.
Offline 2N3055
  • Country: hr
« Reply #1038 on: October 11, 2024, 09:38:48 am »
You are trying to load capture back in scope?
Why? What do you want to do with ?
Offline tautech
« Reply #1039 on: October 11, 2024, 09:49:54 am »
Reference files perform this without being of excessive size for this need.
Locally you can store IIRC 10 to the DSO memory and as many as you like remotely or to USB should you need multiple reference waveforms for comparison tasks.
Utility>Save/Recall is where you can select to save or recall a Ref waveform.
« Last Edit: October 11, 2024, 09:52:01 am by tautech »
Offline 2N3055
  • Country: hr
« Reply #1040 on: October 11, 2024, 11:16:38 am »
Reference is fine but exactly because it is not original data, it is limited what you can do with it. It has it's use and merits but original data it is not.
And yes, on 3000xHD you can save full waveform data to USB and load it back to scope.
That is why I want explanation what @pasha wants to do with it and how he would use it.
So I can give explanation how to achieve that.
But only binary files are supported. CSV is not because it is large and inefficient. CSV is there to support easy export of data and loading to some software that universally will support CVS.
So short answer is, yes you can load full scope captures back to scope, but only BIN is supported (that is also better way because it is much smaller and faster to load).
Also loaded captures do not get loaded into acquisition channel (CH1 for instance). Those are exclusively dedicated acquisition channels, hardware ones. You load data to Memory channels, and use it from there.
Memory channels are similar in appearance to Ref channels, but they contain full data from capture.
You can copy from live channel or load from disk.
In use Memory channel can be used same as live channel. In math, measurements, decode.....
The following users thanked this post: rf-loop, Performa01, egonotto, KungFuJosh, Martin72
Offline pasha
« Reply #1041 on: October 12, 2024, 09:23:04 pm »
@2N3055
I will transfer the data to the PC and apply various filters.
I want to navigate through this data and make visual analysis with an oscilloscope without needing a PC. As you said, the csv format is universal.
Is the restored data original (for .bin format)?
Offline 2N3055
  • Country: hr
« Reply #1042 on: October 12, 2024, 09:49:49 pm »
@2N3055
Thank you for the answer.
Yes if you save BIN, and load it back to Memory channel, it is full original data.
BIN data is documented. You can load it on PC too if you are making your own program
The following users thanked this post: egonotto, pasha
Offline pasha
« Reply #1043 on: October 12, 2024, 10:09:18 pm »
I have a PC program that I created by reading the CSV format line by line. I have no idea how to read bin format on PC. You can recommend the csv format for this, but this time it creates a mess of two different reference files.
anyway, I will find a way.
thanks for all.
Offline tautech
« Reply #1044 on: October 12, 2024, 11:48:54 pm »
thanks for all.
Because you missed this or it didn't sink in:
Offline egonotto
« Reply #1045 on: October 15, 2024, 12:01:36 am »
Hello,
is it possible that the Siglent SDS3000X HD only zooms at 500 uV/div?
The images of the noise at 500 uV/div, 1 mV/div, 2 mV/div and 5 mV/div make me suspect this. The counts-peak-peak are very similar at 500 uV/div and 1 mV/div.
Best regards
egonotto
« Last Edit: October 15, 2024, 12:08:34 am by egonotto »
Offline Lexy
« Reply #1046 on: November 08, 2024, 08:52:39 pm »
I have a SDS3034X HD with the latest firmware (V1.0.3.9). I was doing some I2C decoding of a OLED display (SSD1306) and noticed that the address was decoded as 0x78, but the address is actually 0x3C:
2429691-0
The trigger is set to trigger on address 0x3C and it does trigger on this, so the trigger system uses the correct number:
2429679-1
When we look at the binary format, we see that there actually is 8 bits in the address, instead of 7 (+R/W bit):
2429683-2
As a reminder of how the address is formatted in I2C:
2429687-3
So the SDS3034X HD inadvertedly takes the complete first 8 bits as address, instead of the first 7!
I've done the same test on a SDS802X HD and here the decoding is correct:
2429695-4
PS.: Is there any way to notify Siglent of this bug? Or can the Siglent people that also read this forum handle it further?
« Last Edit: November 08, 2024, 08:56:03 pm by Lexy »
The following users thanked this post: orzel
Offline Martin72
« Reply #1047 on: November 08, 2024, 09:36:42 pm »
Quote from: Usermanual
Configuration
There is only one item  Include R/W Bit  in the configuration of the I2C decode. When it is disabled,
the address is represented separately from the R/W bit, and when it is enabled, the R/W bit is
represented together with the address.
For example, the address 0x4E: Write: Ack, is displayed as "0x4E (W)" when the R/W bit is not
included and is displayed as "0x9C" when the R/W bit is included
Take a look...
« Last Edit: November 08, 2024, 09:45:34 pm by Martin72 »
The following users thanked this post: kripton2035, bytejammer
Offline Lexy
« Reply #1048 on: November 09, 2024, 08:57:43 am »
 |O, I should had RTFM... Thank Martin for clearing this up :-+
I probably turned the 'Include R/W bit' setting on while messing around with the decoder to see what the possibilities where.
The following users thanked this post: KungFuJosh, Martin72
Offline egonotto
« Reply #1049 on: December 15, 2024, 10:33:29 pm »
Hello,
I wanted to take a look at the noise spectrum. That's why I used FFT. The result surprised me. I don't understand the many spikes.
And I don't understand why you hardly see any change at 200 MHz bandwidth.
Best regards
egonotto
« Last Edit: December 15, 2024, 10:45:09 pm by egonotto »
