Author Topic: Siglent SDS800X HD 12 bit DSO's  (Read 1208478 times)
0 Members and 38 Guests are viewing this topic.
Offline Martin72
Re: Siglent SDS800X HD 12 bit DSO's coming
« Reply #375 on: February 16, 2024, 09:48:42 pm »
I now own the store, if only you had come up with it earlier. ;)
Offline 2N3055
  • Country: hr
« Reply #376 on: February 16, 2024, 09:57:13 pm »
:-DD
Dr. Richard W. Hamming
Offline mwb1100
« Reply #377 on: February 16, 2024, 10:23:23 pm »
I don't in any way need another oscilloscope - by all rights one should be plenty for me.  But I have 3 (now that I received a used Owon HDS272S).  Last year (?) it was everything I could do to not buy the SDS2104X Plus I really don't need  when Siglent had their promo.  I can tell it'll be the same when the SDS800X comes out - particularly if they have some sort of end of year promo on it - assuming I don't succumb before then.
Offline BreakingOhmsLaw
  • Certified solder fume addict
« Reply #378 on: February 16, 2024, 11:46:11 pm »
I had already pre-ordered an SDS3034X HD from "my" distributor at the beginning of January.
Did you order with a blank check or did they give you a price?
Offline SHF
« Reply #379 on: February 19, 2024, 12:10:00 pm »
Precision is no coincidence
The following users thanked this post: tautech, TheDefpom, Mortymore, orzel
Online tautechTopic starter
« Reply #380 on: February 19, 2024, 12:19:07 pm »
LOL, where in the deep bowels of YT did you find that ?
Shared already privately and needed some corrections WRT issues seen in Digital that couldn't be replicated by others. The Bus issue has been confirmed as a bug so will be addressed in forthcoming FW.
Avid Rabid Hobbyist
Offline orzel
    • Sylphide Consulting
« Reply #381 on: February 19, 2024, 01:08:16 pm »
First time ever i see a French warning behind such a gear  :-+
But it's a big FAIL !  |O  :palm:
"La fusée" has nothing to do with fuses. More like a (space) rocket.  :-DD
« Reply #382 on: February 19, 2024, 07:51:50 pm »
Paging @TheDefpom... What about the upgrade to 200 MHz bandwidth and more memory?  :)
Had a quick look at this before sending it to Defpom.... :-X
Avid Rabid Hobbyist
Offline KungFuJosh
  • TEAS is real.
« Reply #383 on: February 19, 2024, 08:08:09 pm »
I think they already confirmed license ver 1.0 for this.
Best Continuity Tester Ever
Offline KungFuJosh
  • TEAS is real.
« Reply #384 on: February 19, 2024, 08:32:30 pm »
Good point, but I'd guess at least some improvements are available. 😉
Offline Martin72
« Reply #385 on: February 19, 2024, 08:32:55 pm »
When the dealers have listed the devices from February 28, we will see under "Accessories" which options are available for which model.
It was clear quite early on that the 800s (and 1000s AFAIK) are "expandable" with the well-known script.
I think as long as they don't make any major changes, it will remain the case that only the larger models can't be hacked in this way.
Offline Martin72
« Reply #386 on: February 19, 2024, 08:51:03 pm »
« Last Edit: February 19, 2024, 08:54:14 pm by Martin72 »
« Reply #387 on: February 19, 2024, 08:58:35 pm »
Yes, power analysis -- but neither bandwidth nor memory upgrades.  :(
Hmm, my SDS1204X HD now has it.  ;)
Avid Rabid Hobbyist
Offline Martin72
« Reply #388 on: February 19, 2024, 08:59:25 pm »
Well,
Looking in the datsheet of the 1000X-E, there´s no word about bandwith upgrade but we all know it is possible.
Offline BillyO
« Reply #389 on: February 19, 2024, 09:05:15 pm »
Well,
Was just going to mention that.
Rob or Defpom are just going to have to give it a go!!!
Inquiring minds need to know!!!!
Bill
« Reply #390 on: February 19, 2024, 09:15:21 pm »
Again, regarding the SDS814X HD, it would be most helpful if either @tautech or @TheDefpom could just state whether a bandwidth and/or memory upgrade are possible.
As mentioned, I had only a short time to investigate this and not fully.
The remaining Q in my mind is what is possible with the even cheaper 70 MHz SDS804X HD.  :popcorn:
Avid Rabid Hobbyist
Offline orzel
« Reply #391 on: February 19, 2024, 11:59:50 pm »
That's THE very big question !
Offline mwb1100
« Reply #392 on: February 20, 2024, 12:11:52 am »
We will learn how siglent really feels about hacked upgrades.  Hobbiest marketing tool or eating at higher model sales?
Offline Martin72
« Reply #393 on: February 20, 2024, 12:21:06 am »
Measured against their now legitimate claim, this is more of a tolerated annoyance in the lowest end price range up to 3000€.
And that's not just plucked out of the air, to put it kindly.
Offline DaneLaw
« Reply #394 on: February 20, 2024, 01:07:04 am »
Doesn't look like the tear-down from a couple of days ago is posted in any previous posts.
* Its a hidden video, so it won't pop up in a search..
Teardown video has been recorded...
« Last Edit: February 20, 2024, 01:09:34 am by DaneLaw »
The following users thanked this post: TheDefpom
Offline egonotto
« Reply #395 on: February 20, 2024, 01:16:14 am »
Hello,
Is it possible to measure the mains frequency by setting the trigger to line and activating the counter? I can't do it with the Rigol DHO1074.
Best regards
egonotto
Offline BillyO
« Reply #396 on: February 20, 2024, 01:19:03 am »
Really?  Literally any DSO, even a $50 cheapie, should be able to measure mains frequency.
Bill
« Reply #397 on: February 20, 2024, 01:47:37 am »
Hello,
Best regards
egonotto
Yes with prototype SDS1204X HD.
Only available in the always active HW counter displaying our 50 Hz line frequency. (Top right)
I don't expect SDS800X HD to not also show the line frequency but can check this when I get my unit back from Defpom.
Avid Rabid Hobbyist
Offline egonotto
« Reply #398 on: February 20, 2024, 01:59:18 am »
Hello,
The R&S RTA4000 makes it possible. With Agilent DSO6104L and the Rigol DHO1074 I couldn't manage it. Of course it doesn't work with USB devices either.
If I remember correctly, it works with the Rigol DS1054z and the Siglent SDS2104X Plus.
Best regards
egonotto
P.S.: It's strange that it's exactly 50,00000 Hz, I've never measured that here before.
« Last Edit: February 20, 2024, 02:09:05 am by egonotto »
Offline rf-loop
« Reply #399 on: February 20, 2024, 07:11:04 am »
Normal Trig counter (right top screen) naturally counts trig, where ever it come. Select trigger source to AC Line and thats it.
Source can be C1-C4, AC Line, D0 - D15
But special separate Counter function (Freq, Period, Totalizer) source can only be analog input channels C1-C4
EV of course. Cars with smoke exhaust pipes - go to museum.
