Author Topic: Siglent SSA3000X and SSA3000X-Plus Spectrum Analyzers  (Read 1081355 times)
0 Members and 20 Guests are viewing this topic.
Offline Jah2024
Re: Siglent SSA3000X and SSA3000X-Plus Spectrum Analyzers
« Reply #2600 on: June 25, 2025, 09:29:26 am »
[/quote]
Please confirm the firmware version installed.
This is the latest for your SSA3021X Plus:
https://int.siglent.com/upload_file/zip/firmware/Spectrum_analyzer/SSA3000X%20Plus%20V3.2.2.6.3R2.r2-EN.zip
[/quote]
Yes, I have installed the latest firmware
Offline Jah2024
« Reply #2601 on: June 25, 2025, 09:41:42 am »
Just an idea: The live video uses VNC and I assume uses those ports.
Perhaps you have blocked 5800/5900 ports on your firewall or your firewall isolates wifi and ethernet but allows ordinary web traffic. Also sometime VNC needs UDP.
Let double check that. Thanks.
Offline bicycleguy
« Reply #2602 on: June 30, 2025, 08:58:00 pm »
Updated to SVA1000X_V3.2.2.6.3R2.r2 and noticed they renamed some items and added SA as on option.
« Reply #2603 on: July 09, 2025, 07:25:21 am »
In response to a PM from member @kmoonwalker WRT EMI mode in SSA3000X Plus, SSA3000X-R and SVA1000X models, some menu screenshots for his info.
These 3 model series share the same EMI mode structure and measurement types.
Avid Rabid Hobbyist
The following users thanked this post: kmoonwalker
Offline tomud
« Reply #2604 on: July 11, 2025, 02:17:37 am »
I updated my modified SSA to SVA from firmware version SVA1000X_V3.2.2.6.2R5 (a version that contained bugs and has been removed from the Siglent website) to version SVA1000X-V3.2.2.6.3R2.r2.
I have a question for other owners of modified SSA... I'm not sure, but I think it previously displayed the Uboot-OS version as 3.2.2, and after the update it displays Uboot-OS 3.1.2...
Do you also have Uboot-OS version 3.1.2 after the update, or am I just thinking that it was 3.2.2 before ? Does anyone have any idea what the hell is going on here ?  :-//
« Last Edit: July 11, 2025, 02:40:46 am by tomud »
For every complex problem, there is a solution that is simple neat and wrong...
Offline bicycleguy
« Reply #2605 on: July 11, 2025, 04:11:21 am »
I guess my picture two posts above was confusing.  I always take snapshots before and after updates.  I combined them into the picture there.
On the left is the last version 3.3.3.6.0R7 installed on 2024-02-26 and on the right the new 3.2.2.6.3R2.r2 which shows up as 6.3R2 on 2025-07-09.
So to answer your question the latest Boot-OS is 3.2.2 and before that who knows.
Offline tomud
« Reply #2606 on: July 11, 2025, 06:13:07 am »
Well, in my case, after updating to the latest firmware 6.3R2, the Uboot-OS version changed to a lower one, i.e. 3.1.2 ha ha interesting, interesting...  :-//
Although on the earlier firmware 6.2R5 (I'm 90% sure about it) I had Uboot-OS version 3.2.2...
Well, it looks like some miracles are happening here..
Maybe it's related to the bugs that version 6.2R5 had and something like this happens when we update from version 6.2R5 to 6.3R2...
@tautech, @tv84 Maybe you have an idea what could have happened here ?  :-DD
« Last Edit: July 11, 2025, 06:23:15 am by tomud »
« Reply #2607 on: July 11, 2025, 06:48:08 am »
My untouched SVA1032X updated from NIB 6.2R5 to 6.3R2 has 3.2.2 OS.
No idea what's going on under the rug covers.  :-//
Avid Rabid Hobbyist
Offline tomud
« Reply #2608 on: July 11, 2025, 08:21:42 am »
He he...
The device boots up and seems to be working properly (though I haven't measured anything after the update yet – I don't have time for that right now)... So it'll probably remain a mystery what happened here. We'll see what happens after the next updates...  :scared:
Offline tv84
  • Country: pt
« Reply #2609 on: July 11, 2025, 08:43:31 am »
If it's at uboot level, I would say somebody messed up and made the ADS package with an older uboot...  :palm:
Don't remember any motif for doing it explicitly.
Offline tomud
« Reply #2610 on: July 11, 2025, 09:08:45 am »
@tv84
The funniest thing is that other people have the correct version of U Boot-OS i.e. 3.2.2 after this update...
Unless they have changed the update files on their website (www.siglenteu.com) in the meantime.
I downloaded the update yesterday from this link: https://www.siglenteu.com/download/18788/?tmstv=1752224028
MD5 (SVA1000X_V3.2.2.6.3R2.r2.ADS) = a74b31206fcc2946486d3a983a57c9ad
Are you able to unpack this ADS and check what Uboot-OS version it is ?
Added after a while...
I also downloaded ADS from the link provided by @tautech https://int.siglent.com/upload_file/zip/firmware/Spectrum_analyzer/SVA1000X%20V3.2.2.6.3R2.r2-EN.zip
It looks like the same file I downloaded (same md5)... ...so it looks very strange...  :-DD
« Last Edit: July 11, 2025, 09:34:33 am by tomud »
Offline tv84
  • Country: pt
« Reply #2611 on: July 11, 2025, 08:17:43 pm »
These are the 3 U-Boot files inside the ADS. For platforms 15, 32 and 75.
Offline antenna
« Reply #2612 on: July 12, 2025, 01:27:38 am »
I updated my genuine SVA1032x yesterday and mine now says 3.1.2
Offline tomud
« Reply #2613 on: July 12, 2025, 03:24:24 am »
Well, all that remains is for someone who has updated SVA1032 firmware to 6.3R2 and has Uboot-OS version 3.2.2 (e.g. bicycleguy) to provide the MD5 of the ADS file they used to update.
It will be clear whether Siglent has replaced files on websites or whether this is due to another (unknown) reason.
« Last Edit: July 12, 2025, 03:28:33 am by tomud »
Offline tv84
  • Country: pt
« Reply #2614 on: July 12, 2025, 08:37:00 am »
Maybe this is the secret!
Offline tomud
« Reply #2615 on: July 12, 2025, 09:09:46 am »
I also upgraded from 6.2R5 to 6.3R2 and Uboot-OS changed from 3.2.2 to 3.2.1, so I asked here if others had the same problem.
antenna It also has 3.1.2 on the original SVA1032X, so it's not a problem of modified SSA->SVA.
bicyclegu after updating from 6.0R7 to 6.3R2 it has Uboot-OS version 3.2.2
To be honest, I'm a bit confused about what's going on here  :scared:
« Last Edit: July 12, 2025, 09:11:17 am by tomud »
Offline tv84
  • Country: pt
« Reply #2616 on: July 12, 2025, 09:42:50 am »
Aren't you disregarding the ".r2" in the ADS name?
Aren't there 2 files?
SVA1000X_V3.2.2.6.3R2.ADS
Offline tomud
« Reply #2617 on: July 12, 2025, 09:46:34 am »
bicycleguy wrote above that he updated from SVA1000X_V3.2.2.6.3R2.r2 and there is a screenshot showing that he has Uboot-OS 3.2.2
As for the available files, I did not find any other than SVA1000X_V3.2.2.6.3R2.r2.ADS from the SVA1000X-V3.2.2.6.3R2.r2-EN.zip archive
The only thing that comes to my mind is that Siglent has replaced files on its website in the meantime - that's why I provided the md5 to check it.
If they didn't replace these files, I personally have no idea why some people have Uboot-OS 3.1.2 after the update, and others Uboot-OS 3.2.2...
« Last Edit: July 12, 2025, 11:16:55 am by tomud »
Offline dibro
« Reply #2618 on: July 12, 2025, 02:45:51 pm »
If I download SVA1000X Firmware_V3.2.2.6.3R2 form the Siglent site
(https://www.siglenteu.com/service-and-support/firmware-software/spectrum-analyzers/#sva1000x-series)
it gives me SVA1000X Firmware_V3.2.2.6.3R2.r2-EN.zip
It looks like the text on the site was not updated correctly.
Offline bicycleguy
« Reply #2619 on: July 12, 2025, 05:51:18 pm »
The file I used matches @tomud's md5 for my former SSA3021X Plus.  The SVA1000X V3.2.2.6.3R2.r2-EN.zip had only the SVA1000X_V3.2.2.6.3R2.r2.ADS and SVA1000X+Firmware+Revise+History.pdf
Offline kw1
« Reply #2620 on: August 10, 2025, 02:36:05 pm »
New firmware for SSA3000X Plus models
Version: V3.2.2.6.3R2.r2
~21 MB
Release notes
Notice:
This firmware must be upgraded from V3.2.2.4.0 or later. If your analyzer has an earlier version, please update to V3.2.2.4.0 first and then proceed to update to the latest version.
New Functionality:
Add measurement related functions, including:APSK function, Marker Band function, MA Record function and 200 Hz EMI RBW(only SSA3075XPlus).
Add system related functions, including: local oscillator feedthrough self calibration, 10M out frequency accuracy Self-Calibration function and FTP function.
Improvements:
Fixed some known defects.
Can you please explain the new Functions: local oscillator feedthrough self calibration, 10M out frequency accuracy Self-Calibration function
many thx
klaus
The following users thanked this post: minsik
« Reply #2621 on: August 11, 2025, 04:24:05 am »
~21 MB
Release notes
Notice:
New Functionality:
Improvements:
many thx
klaus
Welcome to the forum Klaus
They are for adjustment of the internal oscillator error (aging/drift) to a more exact 10 MHz rather than requiring an external 10 MHz reference for all but the most precise work.
Adjustments will need a accurate counter and use of SCPI commands to the analyzer to make the small adjustments to the internal reference oscillator.
Siglent shared the attached User Self Adjustment that will be added into manual revisions.
Avid Rabid Hobbyist
The following users thanked this post: 807, minsik, james38, bicycleguy, DL4JY, Wrenches of Death, kw1, vsilves, chas28645
Offline qazwsx
  • Country: cn
    • Muning
« Reply #2622 on: August 26, 2025, 01:35:59 am »
Thank you for this information. Is there any way to upgrade the SSA3032X-R to 7.5GHz?
Offline szym273
« Reply #2623 on: September 14, 2025, 01:34:50 pm »
Hello,
I am having trouble updating the software from version V3.2.2.5.1R1 to V3.2.2.6.3R2 after crossflashing from SSA to SVA. During the update process, I get the message: “upgrade fail.” Does anyone know what causes this error? In the attachment, I am attaching a screenshot of the system info window.
Offline Sunlitcomet
« Reply #2624 on: September 17, 2025, 06:04:12 pm »
i did but i was grabbing the ssa file version still instead of the sva file version. I was not paying attention on the download page.
