Here is an example: the first pictures shows the spectrum of Astra 19.2E as seen by the Emitor Satlook Color (which I presume you have).
The next three pictures show the SAME spectrum as seen by the SSA3021X. Notice how far I can "zoom" into the spectrum, revealing the tiniest signals!
Thanks for the info and pics. I have Combolook Color HD S2T2 and Satlook Micro. How fast is the spectrum display (of Astra) on the Siglent? Can you set it to almost realtime with resolution similar to Satlook? Or is it always way above Satlook Color's spectrum performance?
I know EXACTLY why you are asking this question, so let me give you a longer answer, to make it eventually interesting to others.
The Emitor Satlook Digital series of field meters feature indeed a pretty fast realtime spectrum. This comes very handy for aligning a satellite dish, as you can immediatly "see" the satellite (much before a tuner can actually lock onto the satellite) and by the shape of the spectrum you can, with some experience, guess what satellite it is. Hands down, this is the best possible aid to align a satellite dish and fine tune it.
However, the Emitor products don't exactly stand out for precision or full set of measuring features. This is OK at the price they are sold. And again: I still use my Satlook Digital NIT (the one with the black and white CRT) as the primary device to tune my dishes, as it is the least valueable device to be carried to the roof. And the spectrum does what is needed.
BUT: the spectrum that you see, is just a representation of what is really happening (like with any spectrum analyzer) and in this case, the representation was made to be fast with a low resolution.
Cheap Chinese meters take this to a whole new level and actually show extrapolated spectrum frames with random noise inserted, just to show an apparently realtime spectrum! Disconnect the cable and the spectrum lives on for another 3-5 seconds...
When it comes to a dedicated spectrum analyzer, it is not the speed that matters! I had to learn this myself.
Why? Because you can actually set the SWEEP speed to whatever value you like (within some limits)! But, if you set it too fast, the ADC won't have time to actually see anything usefull.
RBW, VBW and SWEEP go hand in hand and depend on the selected parameters.
Think of it like this:
The RBW is like the apperture letting in the signal. The smaller it is, the more detailed a signal you can distinguish.
SWEEP is the speed with which you will run the RBW "window" across the SPAN. Make it too fast and you "didn't have time to properly look into the apperture".
Finally, coming to your question: if I set the SPAN to 1GHz and use a RBW of 1MHz, then yes, the Siglent is as fast or even faster than TV field meters, including the Emitor.
If I want to set the SPAN to 3GHz and use a RBW of 100kHz with a suitable VBW (think of it as a filter to keep the noise level down by averaging the reading of each "RBW window" during sweep), then the refresh rate goes down. However, you will see things otherwise invisible.
Last example: Look at a picture with 800x600 pixels and then at the same picture with 1920x1080 pixels. No question which has more detail. That is what RBW is all about and apart from the Deviser S7000 no other field meter allows to toggle this filter. Some allow to select fast/very fast spectrum or something similar, which means you can select from two predefined RBW values. But the remaining parameters are still preconfigured to show analog or digital TV transponders (again, the Deviser S7000 is an exception and I don't know about the Promax range of products).
I think that the SSA3021X is not an option for you, if you are into dish alignment: remember that the SSA3021X does NOT provide power for LNB or 0/22kHz & 14/18V & DiSEqC support. I am using the Loop Trough port of a satellite receiver to get the satellite spectrum images. Also, the lack of internal battery makes it evident that you cannot use it on the roof.
So again, I didn't buy it to replace any of the field meters, but to learn, experiment, do DXing and to evaluate the quality of the spectrum analysers in modern TV field meters I get to test.
Hope this helps a little.
Regards,
Vitor
