Author Topic: Siglent SSA3000X and SSA3000X-Plus Spectrum Analyzers  (Read 1141059 times)
0 Members and 87 Guests are viewing this topic.
Offline cubitus
Re: Siglent SSA3000X and SSA3000X-Plus Spectrum Analyzers
« Reply #2150 on: January 10, 2023, 11:03:12 am »
I put the firmware SVA1000X_V3.2.2.5.1R1.ADS in a USB stick I remember more the procedure to start flashing the device at startup :palm:
RIGOL DM3068, DG4202, DP832A MSO4014
FLIR E4 SSA3021X Plus
Offline cubitus
« Reply #2151 on: January 10, 2023, 11:41:51 am »
I managed to go through the HTTP interface to upload the firmware it loads it but an installation failed…
Offline Bicurico
  • Country: pt
  • Broadcast Systems & Transport Stream Analysis
    • VMA-Broadcast
« Reply #2152 on: January 10, 2023, 11:46:46 am »
I think that there might be files missing or corrupt.
Can you do a "ls -la" command in the folder where the aladdin executable is (I think it is /usr/bin/siglent or something like that).
Also, please do explain *exactly* what you have done prior to the brick. It must have been caused by something, like an upgrade or so.
Offline cubitus
« Reply #2153 on: January 10, 2023, 11:53:21 am »
/usr/bin/siglent # ls -la
total 13772
drwxrwxrwx    9 1000     1000          1392 Sep 10 20:22 .
drwxrwxrwx    1 1000     232           3204 Jan  1  1970 ..
-rw-------    1 root     root          6972 Jan 10 09:18 .ash_history
-rwxrwxrwx    1 root     root      13856588 Sep 10 20:00 Aladdin
drwxrwxrwx    8 1000     1000           792 Sep 10 20:01 config
-rwxrwxrwx    1 root     root          1078 Sep 10 20:00 config_eth0.sh
drwxrwxrwx    2 1000     1000          1904 Sep 10 20:01 drivers
drwxrwxrwx    3 1000     1000           752 Sep 10 20:01 firmdata0
drwxrwxrwx    2 1000     1000           160 Jan  8  2019 firmdata1
drwxrwxrwx    2 root     root           688 Sep 10 20:00 lib
-rwxrwxrwx    1 root     root         12068 Sep 10 20:00 lighttpd.conf
drwxrwxrwx    2 1000     1000           232 Jan  8  2019 log
-rwxrwxrwx    1 root     root         67085 Sep 10 20:00 php.ini
-rwxrwxrwx    1 root     root          2204 Sep 10 20:23 startup_app.sh
-rwxrwxrwx    1 root     root            77 Sep 10 20:00 startup_ftp.sh
-rwxrwxrwx    1 root     root           482 Sep 10 20:00 startup_vnc.sh
drwxrwxrwx   10 1000     1000          1144 Jan 10 12:38 usr
-rwxrwxrwx    1 root     root           490 Sep 10 20:00 vdma_vnc.sh
-rwxrwxrwx    1 root     root         29337 Sep 10 20:00 vncserver
-rwxrwxrwx    1 root     root         97611 Sep 10 20:00 vsftpd
Before the problem I did absolutely nothing I simply turned on the device and found that it was stuck.
In the command "DMESG" there was this error message what do you think?
[    1.112430] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[    1.120023] nand: WARNING: pl353-nand: the ECC used on your system is too weak compared to the one required by the NAND chip
[    1.131531] Bad block table found at page 131008, version 0x01
[    1.137807] Bad block table found at page 130944, version 0x01
[    1.143935] 12 ofpart partitions found on MTD device pl353-nand
[    1.149785] Creating 12 MTD partitions on "pl353-nand":
« Last Edit: January 10, 2023, 11:55:54 am by cubitus »
Offline tv84
  • Country: pt
« Reply #2154 on: January 10, 2023, 12:11:46 pm »
And the most important file would be to checksum the alladin executable and validate if it's ok.
If not, a manual replacement could help. If it is ok then I don't think it's easy to identify the cause.
Offline cubitus
« Reply #2155 on: January 10, 2023, 01:16:01 pm »
the checksum :
/usr/bin/siglent # md5sum Aladdin
29f1dc880f90a2702d0b6d90ee48a1c6  Aladdin
Offline DeDe
« Reply #2156 on: January 10, 2023, 04:21:09 pm »
Oh dear, this looks like a complete mess....
Did the instrument ever work correctly after the SSA->SVA crossflash?
Obviously the versions of the Aladdin applications do not match the kernel object files (.ko) in the drivers/ directory.
At startup, for example, the error "Can't read /usr/bin/siglent/drivers/udc-xilinx.ko ..." appears. This file does not exist (anymore) on my system (firmware 3.2.2.5.1R1).
But this is the same checksum as yours!?
Kernel Version:
/usr/bin/siglent # uname -a
Linux (none) 3.19.2-omg-xilinx-svn35686 #11 SMP PREEMPT Fri Jan 4 15:28:26 CST 2019 armv7l GNU/Linux
Here are my directory listings:
/usr/bin/siglent # ls -ltra
total 13772
drwxrwxrwx    1 65534    254           3204 Jan  1  1970 ..
drwxrwxrwx   10 65534    65534          904 Jan  1  2000 usr
drwxrwxrwx    2 65534    65534          160 May  7  2021 firmdata1
drwxrwxrwx    2 65534    65534          232 May  7  2021 log
-rwxrwxrwx    1 root     root         97611 Dec 30 14:55 vsftpd
-rwxrwxrwx    1 root     root            77 Dec 30 14:55 startup_ftp.sh
-rwxrwxrwx    1 root     root          1078 Dec 30 14:55 config_eth0.sh
-rwxrwxrwx    1 root     root         29337 Dec 30 14:55 vncserver
-rwxrwxrwx    1 root     root           482 Dec 30 14:55 startup_vnc.sh
-rwxrwxrwx    1 root     root         67085 Dec 30 14:55 php.ini
-rwxrwxrwx    1 root     root         12068 Dec 30 14:55 lighttpd.conf
drwxrwxrwx    2 root     root           688 Dec 30 14:55 lib
-rwxrwxrwx    1 root     root      13856588 Dec 30 14:55 Aladdin
-rwxrwxrwx    1 root     root           490 Dec 30 14:55 vdma_vnc.sh
drwxrwxrwx    2 65534    65534         1904 Dec 30 14:56 drivers
drwxrwxrwx    8 65534    65534          704 Dec 30 14:56 config
drwxrwxrwx    3 65534    65534          840 Dec 30 15:08 firmdata0
drwxrwxrwx    9 65534    65534         1392 Jan  4 11:59 .
-rwxrwxrwx    1 root     root          2205 Jan  5 21:05 startup_app.sh
-rw-------    1 root     root          6126 Jan 10 17:06 .ash_history
/usr/bin/siglent # cd drivers/
/usr/bin/siglent/drivers # ls -ltra
total 552
-rwxrwxrwx    1 65534    65534        17192 May  7  2021 usbtmc.ko
-rwxrwxrwx    1 65534    65534        11629 May  7  2021 usbmisc_imx.ko
-rwxrwxrwx    1 65534    65534        45018 May  7  2021 usbhid.ko
-rwxrwxrwx    1 65534    65534       100267 May  7  2021 usb-storage.ko
-rwxrwxrwx    1 65534    65534        15141 May  7  2021 uinput.ko
-rwxrwxrwx    1 65534    65534        10516 May  7  2021 siglentaxidma.ko
-rwxrwxrwx    1 65534    65534         8864 May  7  2021 siglent_vnc.ko
-rwxrwxrwx    1 65534    65534        20202 May  7  2021 mousedev.ko
-rwxrwxrwx    1 65534    65534        60742 May  7  2021 libcomposite.ko
-rwxrwxrwx    1 65534    65534          288 May  7  2021 insmod_before_app.sh
-rwxrwxrwx    1 65534    65534          740 May  7  2021 insmod_after_app.sh
-rwxrwxrwx    1 65534    65534        21193 May  7  2021 gt9xx.ko
-rwxrwxrwx    1 65534    65534        11406 May  7  2021 gpib.ko
-rwxrwxrwx    1 65534    65534         9904 May  7  2021 ehci-pci.ko
-rwxrwxrwx    1 65534    65534        56724 May  7  2021 ehci-hcd.ko
-rwxrwxrwx    1 65534    65534         5550 May  7  2021 ci_hdrc_zevio.ko
-rwxrwxrwx    1 65534    65534         6990 May  7  2021 ci_hdrc_usb2.ko
-rwxrwxrwx    1 65534    65534         6588 May  7  2021 ci_hdrc_pci.ko
-rwxrwxrwx    1 65534    65534         6623 May  7  2021 ci_hdrc_msm.ko
-rwxrwxrwx    1 65534    65534        10170 May  7  2021 ci_hdrc_imx.ko
-rwxrwxrwx    1 65534    65534        44456 May  7  2021 ci_hdrc.ko
-rwxrwxrwx    1 65534    65534        22747 May  7  2021 ads7846.ko
-rwxrwxrwx    1 65534    65534          189 May  7  2021 .sh
-rwxrwxrwx    1 root     root         27844 Dec 30 14:55 g_usbtmc.ko
drwxrwxrwx    2 65534    65534         1904 Dec 30 14:56 .
drwxrwxrwx    9 65534    65534         1392 Jan  4 11:59 ..
Offline cubitus
« Reply #2157 on: January 10, 2023, 04:42:15 pm »
After the SSA > SVA cross flash I admit that I did not see big differences in operation because it was pro with all options.
It has worked very well so far the flash was made several months ago.
I am French, I have a little trouble interpreting the instructions that are given on this forum.
Maybe I did something stupid...
Here are my directory listings on my device :
total 13772
drwxrwxrwx   10 1000     1000          1056 Jan 10 14:11 usr
-rw-------    1 root     root          7061 Jan 10 17:28 .ash_history
total 552
-rwxrwxrwx    1 1000     1000         10516 Jan  8  2019 siglentaxidma.ko
-rwxrwxrwx    1 1000     1000         21193 Jan  8  2019 gt9xx.ko
-rwxrwxrwx    1 1000     1000         11406 Jan  8  2019 gpib.ko
-rwxrwxrwx    1 1000     1000          5550 Jan  8  2019 ci_hdrc_zevio.ko
-rwxrwxrwx    1 1000     1000          6588 Jan  8  2019 ci_hdrc_pci.ko
-rwxrwxrwx    1 1000     1000         44456 Jan  8  2019 ci_hdrc.ko
-rwxrwxrwx    1 1000     1000         17192 Jan  8  2019 usbtmc.ko
-rwxrwxrwx    1 1000     1000        100267 Jan  8  2019 usb-storage.ko
-rwxrwxrwx    1 1000     1000         20202 Jan  8  2019 mousedev.ko
-rwxrwxrwx    1 1000     1000           288 Jan  8  2019 insmod_before_app.sh
-rwxrwxrwx    1 1000     1000          6623 Jan  8  2019 ci_hdrc_msm.ko
-rwxrwxrwx    1 1000     1000         11629 Jan  8  2019 usbmisc_imx.ko
-rwxrwxrwx    1 1000     1000          8864 Jan  8  2019 siglent_vnc.ko
-rwxrwxrwx    1 1000     1000           740 Jan  8  2019 insmod_after_app.sh
-rwxrwxrwx    1 1000     1000          9904 Jan  8  2019 ehci-pci.ko
-rwxrwxrwx    1 1000     1000         56724 Jan  8  2019 ehci-hcd.ko
-rwxrwxrwx    1 1000     1000         10170 Jan  8  2019 ci_hdrc_imx.ko
-rwxrwxrwx    1 1000     1000         45018 Jan  8  2019 usbhid.ko
-rwxrwxrwx    1 1000     1000         60742 Jan  8  2019 libcomposite.ko
-rwxrwxrwx    1 1000     1000          6990 Jan  8  2019 ci_hdrc_usb2.ko
-rwxrwxrwx    1 1000     1000         22747 Jan  8  2019 ads7846.ko
-rwxrwxrwx    1 1000     1000           189 Jan  8  2019 .sh
-rwxrwxrwx    1 1000     1000         15141 Oct 18  2019 uinput.ko
-rwxrwxrwx    1 root     root         27844 Sep 10 20:00 g_usbtmc.ko
drwxrwxrwx    2 1000     1000          1904 Sep 10 20:01 .
drwxrwxrwx    9 1000     1000          1392 Sep 10 20:22 ..
Offline DeDe
« Reply #2158 on: January 10, 2023, 05:00:25 pm »
Additional infos:
At first I also see the same warnings in the "dmesg":
[    1.109927] nand: WARNING: pl353-nand: the ECC used on your system is too weak compared to the one required by the NAND chip
[    1.121444] Bad block table found at page 131008, version 0x01
[    1.127734] Bad block table found at page 130944, version 0x01
Experiment: kill -9 the Aladdin process and did a successful restart form terminal:
/usr/bin/siglent # ./Aladdin&
/usr/bin/siglent # log init finished
udhcpc: started, v1.26.0.git
Setting IP address 0.0.0.0 on eth0
udhcpc: sending discover
udhcpc: sending select for 192.168.178.171
udhcpc: lease of 192.168.178.171 obtained, lease time 864000
Setting IP address 192.168.178.171 on eth0
Deleting routers
route: SIOCDELRT: No such process
Adding router 192.168.178.1
Recreating /usr/bin/siglent/usr/etc/resolv.conf
 Adding DNS server 192.168.178.1
rotationAngle:  0 invertx:  false inverty:  false
[INFO] /home/share/yangh/aladdin_no_mod/tag5_1/product_aladdin/business/dp_control/module_business/dp_vna/vector_calibrator.cpp 129 msg:vector_calibrator. load_s11_factory_calibration  success!!!!!!!!!!!!
[INFO] /home/share/yangh/aladdin_no_mod/tag5_1/product_aladdin/business/dp_control/module_business/dp_vna/vector_calibrator.cpp 135 msg:vector_calibrator. load s21 factory calibration ref data success!!!!!!!!!!!!
[INFO] /home/share/yangh/aladdin_no_mod/tag5_1/product_aladdin/business/dp_control/module_business/dp_vna/vector_calibrator.cpp 168 msg:edison:vector_calibrator::set_cali_kit_file_name kitName=User1,gender is 1645,index = 7
Interestingly, the newer Aladdin also includes an "insmod" statement that references files that do not exist:
/usr/bin/siglent # strings Aladdin | grep insmod
insmod /usr/bin/siglent/drivers/g_usbtmc.ko
insmod /usr/bin/siglent/drivers/udc-core.ko;insmod /usr/bin/siglent/drivers/musb_hdrc.ko;insmod /usr/bin/siglent/drivers/ti81xx.ko
insmod /usr/bin/siglent/drivers/libcomposite.ko;insmod /usr/bin/siglent/drivers/udc-xilinx.ko;
insmod
/usr/bin/siglent #
/usr/bin/siglent #
/usr/bin/siglent # ls -la /usr/bin/siglent/drivers/g_usbtmc.ko
-rwxrwxrwx    1 root     root         27844 Dec 30 14:55 /usr/bin/siglent/drivers/g_usbtmc.ko
/usr/bin/siglent # ls -la /usr/bin/siglent/drivers/udc-core.ko
ls: /usr/bin/siglent/drivers/udc-core.ko: No such file or directory
/usr/bin/siglent # ls -la /usr/bin/siglent/drivers/musb_hdrc.ko
ls: /usr/bin/siglent/drivers/musb_hdrc.ko: No such file or directory
/usr/bin/siglent # ls -la /usr/bin/siglent/drivers/ti81xx.ko
ls: /usr/bin/siglent/drivers/ti81xx.ko: No such file or directory
/usr/bin/siglent # ls -la /usr/bin/siglent/drivers/libcomposite.ko
-rwxrwxrwx    1 65534    65534        60742 May  7  2021 /usr/bin/siglent/drivers/libcomposite.ko
/usr/bin/siglent # ls -la /usr/bin/siglent/drivers/udc-xilinx.ko
ls: /usr/bin/siglent/drivers/udc-xilinx.ko: No such file or directory
The files in your drivers/ directory have an older date, but look the same size as mine.
Maybe something messed in your config files?
/usr/bin/siglent/firmdata0/NSP_trends_config_info.xml + NSP_sn_bandwidth.xml
/usr/bin/siglent/config/NSP_config_upgrade_info.xml
Offline Bicurico
  • Country: pt
    • VMA-Broadcast
« Reply #2159 on: January 10, 2023, 05:17:20 pm »
the checksum :
This checksum is correct.
Offline tv84
  • Country: pt
« Reply #2160 on: January 10, 2023, 05:28:30 pm »
This is not advisable at all! (Warning for newcomers)
When you go into a crossflash, you should restore the unit as stock before doing any cross change.
Since the app is OK, I suggest restoring the licensing/model files to "non-pro mode".
Offline DeDe
« Reply #2161 on: January 10, 2023, 05:41:57 pm »
Where are the license keys stored?
/usr/bin/siglent/firmdata0/nsp_data_b1?
Offline cubitus
« Reply #2162 on: January 10, 2023, 06:14:24 pm »
Good news, The device has come back to life😊
By relaunching Aladdin from the command line, I had access to the interface for about 3 seconds before blocking.
By trying several times in a row and pressing different buttons (I don't know if it's this or something else) I managed to get the analyzer to work normally.
After turning off the device, the problem reappeared, it got stuck.
I started launching Aladdin again once, once the device was up and running, I went to the system menu and made it a Factory reset.
I also set Power On to Def
I'm keeping my fingers crossed, but so far it seems to be fine. :phew:
Offline cubitus
« Reply #2163 on: January 10, 2023, 06:58:29 pm »
It seems to me when I made the transition from SSA > SVA to have first removed the pro mode to have returned to the original version and then to have done the manipulation, but it goes back a long way.
<?xml version="1.0" encoding="UTF-8"?>
<nsp_trends_info_root>
<device>
<language>english</language>
<pid>0x1301</pid>
<vid>0xf4ec</vid>
<product_type_1>SVA1032X</product_type_1>
<manufacturer>Siglent</manufacturer>
<Support_Touch_Flag>1</Support_Touch_Flag>
<Support_VXI11_Flag>1</Support_VXI11_Flag>
<file_prefix>CP_</file_prefix>
</device>
</nsp_trends_info_root>
<?xml version="1.0"?>
<nsp_system_info_root>
<device>
<system_information>
<serial_number>
<chip>0123456789</chip>
</serial_number>
</system_information>
</device>
<serial_number>SSA3PCEQ5R....</serial_number>
<license>
<_3021>
<lic>pykq4w6najjqb352</lic>
<remain>7680</remain>
</_3021>
<_TG>
<lic>sxnfmn3v2pjqv93z</lic>
</_TG>
<_tEMI>
<lic>v6p76xetfany7s2p</lic>
</_tEMI>
<_tAMK>
<lic>dtf6bh923ns35gze</lic>
</_tAMK>
<_tCAT>
<lic>yrszgcmt36wkp84e</lic>
</_tCAT>
<_tDMA>
<lic>z2cs4mq2fkbcsbxn</lic>
</_tDMA>
<_tAMA>
<lic>3fmu2335p5b3hpja</lic>
</_tAMA>
</license>
<device>
<serial_number>
</serial_number>
</device>
<license>
<_3021>
</_3021>
<_TG>
</_TG>
<_tEMI>
</_tEMI>
<_tAMK>
</_tAMK>
<_tCAT>
</_tCAT>
<_tDMA>
</_tDMA>
<_tAMA>
</_tAMA>
</license>
</nsp_system_info_root>
NSP_config_upgrade_info.xml  I corrected
<nsp_upgrade_info_root>
<device>
<upgrade_static_id>11410</upgrade_static_id>
<upgrade_start_id>11400</upgrade_start_id>
<upgrade_end_id>11499</upgrade_end_id>
</device>
</nsp_upgrade_info_root>
« Last Edit: January 11, 2023, 04:37:08 pm by cubitus »
Offline DeDe
« Reply #2164 on: January 11, 2023, 12:30:46 pm »
NSP_config_upgrade_info.xml should more look like this:
        <device>
        </device>
NSP_trends_config_info.xml looks ok.
NSP_sn_bandwidth.xml doesn't have this "<license/>" block on my instrument:
        <device>
                        <serial_number>
                                <chip>SSA3..........</chip>
                        </serial_number>
        </device>
Finally NSP_system_info.xml:
  <device>
      <serial_number>
      </serial_number>
  </device>
  <Device>
    <Mac>74:5b:....</Mac>
  </Device>
Offline cubitus
« Reply #2165 on: January 11, 2023, 04:40:16 pm »
I had made a small mistake of copying and pasting. :P
The analyzer always works properly,
 :-+  thank you all for your support!   :-+
Signent Europe responded and sent me a procedure for restoring the factory word.
 SSA3X Plus USB recovery
« Last Edit: January 11, 2023, 08:45:35 pm by cubitus »
Offline cubitus
« Reply #2166 on: January 11, 2023, 06:40:21 pm »
Hello,
I redid a manual calibration of the analyzer, it's not too bad I put about fifteen points.
I have the possibility by making an acquisition via Matlab software to recover the 751 points of a curve and to make the difference with a doite.
The correction file is relatively simple to edit, it is simply "frequency", "correction"
How many points do you think I can put in this correction file?
Thank you
Offline cubitus
« Reply #2167 on: January 11, 2023, 07:26:11 pm »
I made a correction file with 76 points it seems to work normally.
Offline Bicurico
  • Country: pt
    • VMA-Broadcast
« Reply #2168 on: January 11, 2023, 08:01:30 pm »
That was the file I was talking about.
I am not sure Siglent is happy that you make it publicly available, though: it could make it harder for others to get the same level of support for other Siglent devices.
Offline cubitus
« Reply #2169 on: January 11, 2023, 08:46:09 pm »
i deleted
Offline DeDe
« Reply #2170 on: January 12, 2023, 01:58:42 pm »
How does the recovery process work? Question just in case...  :)
Offline Bicurico
  • Country: pt
    • VMA-Broadcast
« Reply #2171 on: January 12, 2023, 05:29:19 pm »
Basically you prepare a booting USB and the firmware is loaded upon start from it. You can then use the running FW to flash a regular FW on the device itself, thus restoring whatever is corrupt on the device's FW.
These files exist for the SSA, SSA-P, SSA-R. Probably there is one for the SVA, too. This one would be great, because it would be a one step crossflash... It might be possible to modify the SSA-P recovery for that effect, but I have not looked into it.
The following users thanked this post: DeDe
Offline DL4JY
« Reply #2172 on: January 13, 2023, 07:23:48 pm »
Forgive me, I am bit confused:
After recovering you lost your calibration and you had to redo it ?
cheerio
Offline ganevson
  • Country: bg
« Reply #2173 on: January 14, 2023, 05:31:11 pm »
Hi all
If I disassemble the spectrum analyzer and remove the NAND flash and make a full backup with a programmer, will it be enough if something goes wrong during the cross-flashing?
Offline cubitus
« Reply #2174 on: January 14, 2023, 05:58:15 pm »
It is not a calibration it is just a correction to have a horizontal trace when there is a 50 \$\Omega\$ cap on the entrance
I don't think I've lost the calibration, I hope so :)
