Just an update re the new commands, I had been wating for calibrating the 10Mhz internal reference.
" local oscillator feedthrough self calibration, 10M out frequency accuracy Self-Calibration function and FTP function"
SVA1000X-V3.2.2.6.3R2.r2-EN.zip.
So after upgrade (bows head, spent 2 hours trying commands, result said success but nothing happened! Curses not the right bloody FW= idiot me!)
So after loading SVA1000X-V3.2.2.6.3R2.r2-EN its working great as it should do.
Before = it was +227Hz error at 1.4G, very concerning! (must be a fussy bugger maybe!)
1) I set instrument as recommended, thought about the problem, did it my way in the end.
2) SVA1000X with NO external reference. Centre freq set to 1.4G (as high as she will practically go!) Span 1Khz and lower.
3) Input signal generator locked to the Leo Bodnar 10Mhz GPS reference. Output 1.4G (no modulation)
4) Using the web page checked access ok.
5) Gave the SCPI command, yippee its moving. Tried a few values DEBug:HWACcess:FREQ:DAC:OFFSet +840 is perfect.
6) Locked value into place with DEBug:HWACcess:FREQ:DAC:OFFSet:CONFirm.
7) SYSTem:RESTart rebooted and rechecked as spot on.
Now whats the local osc feedthrough adjustment?
