Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 36621034 times)
0 Members and 1115 Guests are viewing this topic.
« Reply #65450 on: August 04, 2020, 05:18:47 am »
you alsohad those 12” once black and rond andthey produce music  :-DD
Those are back! (And compact cassettes seem to be trying to make a revival.)
omg... dont tell me i need to look in old boxes for my 8 track  :-DD
No, you don't. The record is iconic, and
it has its own fan club based on the inconvenience.
1040442-0
The blog I ripped the image from talks about the "the tea ceremony of playback" and there is something to it.  I've got a Technics SL1000 in full broadcast attire, including a sturdy wheeled cart and the integrated RIAA amp, fader start, and balanced output.
I don't very often play records on it, probably once a week, whereas I listen to Spotify much more frequently. But it is there. Analog-in-being one might say.
The 8-track and the Philips invention the Compact Cassette are irrelevant. They are so completely obsolete. And from having to deal with alleged (mostly dancers) talent and their C-120 (i.e. tape salad prone) "performance-ready" backing tapes, apparently recorded on a boom box through the internal microphone, listening to a plastic record players 3" speaker, all while enjoying the severe modulation artefacts of an AGC worse than that of commercial broadcasters , i hate them. I do.
Offline tonyalbus
    • My Channel
« Reply #65451 on: August 04, 2020, 05:48:50 am »
... guess I'm NOT as metric as I though I was. |O
Yet MORE reason the DFU must die!!!  :-DD
I think wholly imperial for screens' diagonal size, bass loudspeakers, construction nails, and, in the spirit of Larry Haun; "tubafor". I might refer to IEC 60297 enclosures as 19" racks, in passing. I've got UNC, UNF, UNEF, BSP, BSPT, BSF, BA and Whitworth fasteners and associated hardware. They mostly are handled with their native measurement units, but never without a mental envelope calculation involving multiplication or division with 2,54.
The rest is metric. Especially in the kitchen. Fuck ounces and gallons.
in beer i prefer gallons not liters  :-DD :-DD
Offline tggzzz
« Reply #65452 on: August 04, 2020, 06:49:11 am »
Rough and ready conversion:
F = (C x 2) + 30
C = (F - 30)/2
Eg the 38C bd139 posted a few days back 76 + 30  ~= 106F
But don't use them when taking your temperature! 37C is fine, but 104F isn't!
Easiest formulae to remember are based on -40C=-40F
C = (F+40)*5/9-40
F = (C+40)*9/5-40
« Reply #65453 on: August 04, 2020, 07:25:26 am »
F = (C x 2) + 30
C = (F - 30)/2
C = (F+40)*5/9-40
F = (C+40)*9/5-40
40+ years back when NZ went metric is where my rough and ready conversion originated and it's too long ago to remember from whom or where.
Back then when C temps were foisted upon us the quick conversion was to double them and add 30 which is very easily remembered.
Again, double C + 30....it's so simple.....not entirely accurate but it gave us something we could better relate to.
How it's stuck with me all those years, dunno.  :-//
Avid Rabid Hobbyist
« Reply #65454 on: August 04, 2020, 07:30:49 am »
Don't care.  :rant: :-DD
30 degrees to me means wear a jacket, not stripping down to your underwear.  ::)
I let Google do the conversion if I REALLY need to.  :horse:
Offline tonyalbus
    • My Channel
« Reply #65455 on: August 04, 2020, 07:32:42 am »
F = (C x 2) + 30
C = (F - 30)/2
C = (F+40)*5/9-40
F = (C+40)*9/5-40
works for me for rough, thanks.. easy to remember...before this trick i had no qlue how much is F,  other than 100 sounds like a lot ;-)
« Reply #65456 on: August 04, 2020, 07:35:10 am »
On the size item for photos:
Sharpie
It will be handy so you can scribble all over the item if it's for ebay >:D
« Reply #65457 on: August 04, 2020, 07:59:45 am »
Bloody ignorant 'murricans, you are. And blue!  :o
Anyway, I don't remember if I mentioned it before, but I've got an US-built device (an audio matrix) with a web server. The server presents internal temperature in °F, on the wire, and does °C in javascript in the client. I screen scrape the value with curl, and convert it via some awk:
tempmtx=$(curl -s http://xxxx.xxxxxxxxx.xx/nortxe_status.html | \
             awk -F\' '/^xPower/ {
             split($2,values," ");
       printf "%.2f",(5/9)*(values[6]-32);
I was initially suspicious of my code, since:
MariaDB [envi]> SELECT temp FROM readings WHERE temp != 0.00 AND id = 4006 LIMIT 10 ;
| temp  |
| 41.00 |
| 41.00 |
| 41.00 |
| 41.00 |
| 41.00 |
| 41.00 |
| 41.00 |
| 41.00 |
| 41.00 |
| 41.00 |
10 rows in set (0.00 sec)
...but as it turns out, the people at Extron must be reading the internal temperature in °C off the sensor on the board, as an int, converting it to °F (with IIRC 5 digits precision) for HTTP transport, and Javascripting it back to °C in the browser, for display. I see no other sensible explanation to every value being exactly a whole amount of °C...
 :palm:
Edit: This was my 666th post, slightly trailing Saskia.
« Last Edit: August 04, 2020, 08:02:36 am by mansaxel »
« Reply #65458 on: August 04, 2020, 08:05:57 am »
Crawled out of bed this morning at 08:55, parked at the desk and find post counts of 666 and awk. Life is good  :-DD
« Reply #65459 on: August 04, 2020, 08:49:06 am »
Appropriate music...
« Reply #65460 on: August 04, 2020, 08:56:08 am »
I'd suggest this one instead:
Offline Brumby
« Reply #65461 on: August 04, 2020, 08:57:59 am »
F = (C x 2) + 30
C = (F - 30)/2
I go with 1.8 and 32 - which is not at all rough
... and remember numbers like 20ºC = 68ºF; 30ºC = 86ºF; 40ºC = 104ºF for quick reference.  Plus, of course 37ºC = 98.6ºF.  It's this list that drives all my "ready reckoner" estimates
Yeah ... not a very good conversion.  It's nearly 6ºF high.
« Reply #65462 on: August 04, 2020, 09:03:37 am »
I assume, med's intention was this scene:
 :-DD
Offline Brumby
« Reply #65463 on: August 04, 2020, 09:08:29 am »
Was she a redhead?
« Reply #65464 on: August 04, 2020, 09:15:07 am »
Was she a redhead?
- Does she look questionable?
- Is she a trouble-maker?
- Does she behave in weird ways?
- Is she scaring you?
I think, this should answer your question. :)
Offline tggzzz
« Reply #65465 on: August 04, 2020, 09:18:36 am »
The irritating thing is that the decades in the Fahrenheit scale do correspond to different clothing and behaviour. So does Celcius, of course, but not as intuitively.
« Reply #65466 on: August 04, 2020, 09:23:03 am »
Does anyone know any techniques for cleaning up crusty HP metal parts i.e. the frames around the front of the instruments?
I assume they are anodised but I may be incorrect.
Offline Saskia
« Reply #65467 on: August 04, 2020, 09:29:47 am »
Ultrasonic ?
Sandblasting ?
CO2 blasting ?
In other news I won a tape deck on ebay.
The following users thanked this post: BU508A, med6753, mnementh, Specmaster, bd139
« Reply #65468 on: August 04, 2020, 09:32:04 am »
I did consider getting someone to sandblast and re-anodise it but was quoted £50 a go  :(
« Reply #65469 on: August 04, 2020, 09:33:49 am »
To me it is 100% intuitive. But I'm always dressing for a wide spectrum of temperatures by layering. This means I can go from -5 C° to +25 C° without changing what I carry (except moving things in and out of my backpack, adding/removing beanie and gloves, et c.), since you never know when you're stuck in a server room for an entire day.
Offline Saskia
« Reply #65470 on: August 04, 2020, 09:35:10 am »
CO2 blast and laser engrave. or laser rust remove. But that's probably overdoing it.
The following users thanked this post: Zucca, mnementh, bd139
« Reply #65471 on: August 04, 2020, 09:36:56 am »
Cleaning: How about some of these?
« Reply #65472 on: August 04, 2020, 09:37:48 am »
In my case, the bioprene layer is covering this.  :-DD
Offline Zucca
  • EE meid in Itali
« Reply #65473 on: August 04, 2020, 09:59:56 am »
Oh I didn not know that, see here.
The process is called sublimation and is the act of changing the state of metal to a gas form, skipping the liquid phase. This is achieved using high frequency bursts of micro-plasma which - when combined with extremely high thermal pressure and shockwaves - can be set to a certain depth to skim away a surface of rust. So the device can be set to burn away pretty much any material that is layered over metal, be it paint, filler or dreaded rust
So I guess and green laser from a cd burner will not work...  :-/O
« Reply #65474 on: August 04, 2020, 10:11:58 am »
Ultrasonic ?
Sandblasting ?
CO2 blasting ?
That is on complicated mechanism to work on for sure  :-DD
