Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 37217975 times)
d-el, dazz1 and 3286 Guests are viewing this topic.
Offline 0culus
« Reply #74125 on: November 04, 2020, 06:06:02 pm »
Got some new bubble LED goodness on the bench tonight....and it's not a calculator?  :-DD
Cute! A big clock with a f-ing tiny display.
Is it GPS synced?
Is it GPS synced? :-DD :-DD :-DD :-DD
GPS did not exist when the 59309A was designed. It has an input for an external frequency reference and can be set over HPIB so could be synced to GPS given a GPSDO and HPIB controller, but not it's not a GPS clock.
I've always wanted one though.
Yep, this. This clock is a product of the 1970s.  8)
« Reply #74126 on: November 04, 2020, 06:07:21 pm »
The 310 fan base chassis has been cleaned up and repainted. Decided to go with a matte gray finish. Going to let it sit for 24 hours before reassembly.
Med, that looks lovely, what a transformation  :-+
The following users thanked this post: med6753, tonyalbus
« Reply #74127 on: November 04, 2020, 06:20:58 pm »
I would but ebay is completely empty and everything I have works  :(
Huh?
https://www.ebay.co.uk/itm/Solartron-Schlumberger-Model-7150-Digital-Multimeter-With-Power-Lead-and-Manual/184515833221
https://www.ebay.co.uk/itm/Vintage-JVC-7875GB-Television-For-Parts-03-11-JW9/264923745735
https://www.ebay.co.uk/itm/Fluke-28-II-True-RMS-Digital-Multimeter-Good-used-condition/264921038300
https://www.ebay.co.uk/itm/HP-8664A-signal-generator/274557260156
https://www.ebay.co.uk/itm/Nicolet-Pro-60-4-Kanal-Digitaloszilloskop-Transientenschreiber-200MHz/353248067143
https://www.ebay.co.uk/itm/FLUKE-87-true-RMS-Digital-Multimeter-with-backlight-leads-and-shock-BOXED/193734049795
https://www.ebay.co.uk/itm/Fluke-87V-True-RMS-Multimeter/393000057083
https://www.ebay.co.uk/itm/HP-8904A-DC-600kHz-Multifunction-Synthesizer-opt-001-002-003-10/324101294632
https://www.ebay.co.uk/itm/Fluke-8100B-Digital-Multimeter-with-Nixie-Tubes/184486378815
https://www.ebay.co.uk/itm/Advance-Instruments-Digital-Multimeter-DMM2-vintage-rare/293783118443
https://www.ebay.co.uk/itm/HP-3488A-SWITCH-CONTROL-UNIT/383727236913
https://www.ebay.co.uk/itm/Keithley-199-System-DMM-Scanner-1/224131612234
https://www.ebay.co.uk/itm/GENERAL-RADIO-M5G3-3-PHASE-AIRCRAFT-FREQUENCY-VARIAC-8/324312200845
https://www.ebay.co.uk/itm/Hewlett-Packard-3468B-Multimeter/263969499580
https://www.ebay.co.uk/itm/NICOLET-460-DIGITAL-STORAGE-OSCILLOSCOPE-4x200MHz-FFT-L533/284065726288
https://www.ebay.co.uk/itm/AVO-TT169-Transistor-Tester-R4/324282714338
https://www.ebay.co.uk/itm/EKCO-Electronics-M2212A-2/223999143594
That's just an edited down version of my watch list, as there are some things that I don't want you vultures laying your beady little eyes upon.
As for wanting stuff to repair, you could just lend something to Uncle Bumblebutt, I'm sure he could help you out there...
« Reply #74128 on: November 04, 2020, 06:24:12 pm »
Excellent job. Couldn’t be in better hands  :-+
« Reply #74129 on: November 04, 2020, 06:31:08 pm »
Is that actual matte grey, or are you doing it street-rodder style and stopping with the primer...?   ;) If the latter... I've learnt the hard way that it really IS worth the time to give 'er a couple coats of satin clear acrylic.
The first dirty fingerprint you can't get off drives that point home, every. fucking. time.    :-DD
One of those gifts that just keeps on giving... :o
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #74130 on: November 04, 2020, 06:36:41 pm »
Looks great. How do you clean out rust? Any tips?
« Reply #74131 on: November 04, 2020, 06:38:48 pm »
Huh?
As I've recently advised the group; Uncle BumbleButt is available for hire. >:D
Is it just me, or is that thing really bleeding black demon ichor from its guts all over the screen...?
« Last Edit: November 04, 2020, 06:40:58 pm by mnementh »
« Reply #74132 on: November 04, 2020, 06:44:46 pm »
40% Phosphoric acid = Jenolite rust neutraliser.
Avid Rabid Hobbyist
« Reply #74133 on: November 04, 2020, 07:09:15 pm »
I don't buy Lidl tools as a rule. Same as I didn't buy Rolson ones :)
I have no such policy. I have an air ratchet from them that is noisy and wastes air, but, since I've got a 3-phase compressor and ear defenders, it means that the price, ~nothing, actually, is totally acceptable.
It's sooo good to be able to loosen and pre-tighten awkward nuts and bolts on the car by air. The impact wrench I've also got is more or less permanently set to CCW, because it is a nut-fucker par excellence with its 250Nm torque.
I did break a M12 bolt once using just a breaker bar. That was fun.
Looks like whipped cream in the shear surface.  I had a new one; it came with the wheel bearing kit I was replacing.
Offline McBryce
« Reply #74134 on: November 04, 2020, 07:11:41 pm »
Perhaps there aren't that many Americans who can count left?  :popcorn:
Edit: in no way am I suggesting we're any better here. We're not far off rural Alabama in some places.
The ones that can't count are also the ones who breed and have 10 kids. We are fucked.  ::)
This has already been documented in a film:
https://archive.org/details/idiocracy_202005    :-DD    :popcorn:
Brilliant film  :-DD :-DD "If you have a bucket that holds 2 gallons and another bucket that holds 5 gallons, how many barrels do you have?"  :-DD :-DD
Depends on whether they are US or imperial gallons. :D
@med6753: Even your grey looks blue!
McBryce.
« Reply #74135 on: November 04, 2020, 07:15:04 pm »
@AVGresponding, well for me and I suspect, much the same for bd139, these are too rich for my blood, we both tend to look for things that we can add value to, these don't seem to fit that bill. If they need anything done to them, by the time the auction finishes, they are likely to end up much higher price and then add in the extra parts etc, any possible margins later on are severely eroded or even disappeared.
« Reply #74136 on: November 04, 2020, 07:21:49 pm »
McBryce.
See my later post, I screwed the quote up and altered the question and thus lost the impact and the punchline of the line in the film, it is not how many barrels do you have, it should be how many buckets  :palm:
« Reply #74137 on: November 04, 2020, 07:28:28 pm »
You're just trying to avoid the c________e word, aren't you?  :)
« Reply #74138 on: November 04, 2020, 07:31:05 pm »
Could be, if I knew what that word is meant to be  :-//
Edit: If that word is cheapskate, then yes, guilty as charged and I'll happily wear that badge with pride  :-DD :-DD
« Last Edit: November 04, 2020, 08:28:32 pm by Specmaster »
Offline tonyalbus
    • My Channel
« Reply #74139 on: November 04, 2020, 07:43:16 pm »
Can you believe this guy... :palm: now he it putting switches in the front of his WB-SG1 BG7TBL and FA-2 BG7TBL.  :-DD
The following users thanked this post: mnementh, Specmaster, bd139, FransW, BILLPOD
« Reply #74140 on: November 04, 2020, 08:00:57 pm »
You're the modern version of that guy who sticks a random toggle switch on the front of a Heathkit which simultaneously irks and puzzles various new owners.
I occasionally do that with a configuration flag in software for a laugh:
# do not change this
float32_correction_factor = 1.000000000001
The following users thanked this post: BU508A, mnementh, tonyalbus
Offline tggzzz
« Reply #74141 on: November 04, 2020, 08:25:56 pm »
If you really want to mindfuck people that think their unit tests are wonderful then there's a neat trick in Java: change the value of Integer(2).
I forget the details, but the implementation of class Integer contains a class java.lang.Integer.IntegerCache. That is an efficiency hack which contains instances of Integer between -128 and 127. Anytime you instantiate an Integer, if it is in the IntegerCache you get a reference to the unique cached version, not a new object. So simply locate the IntegerCache and, say, swap the cached versions of Integer(1) and Integer(2). That should bugger any non-trivial unit test :)
« Last Edit: November 04, 2020, 08:32:26 pm by tggzzz »
« Reply #74142 on: November 04, 2020, 08:28:09 pm »
That's interestingly dangerous. Sounds similar to interning. You could, if you're a sick and twisted individual like me, swap them on DST change as well just to throw people off the problem :)
« Reply #74143 on: November 04, 2020, 08:29:38 pm »
McBryce.
But in all honesty... the way you said it makes about as much sense as politics today, so...
"If you leave on a northbound train traveling at 40MPH... and Senator ArseMonkey leaves on a southbound train traveling at 60MPH... how many Oreo cookies before the second coming of Lord 'elpus...?"
« Reply #74144 on: November 04, 2020, 08:35:07 pm »
McBryce.
You need to watch the film to get the joke... >:D
« Reply #74145 on: November 04, 2020, 08:38:26 pm »
Heh... reminds me of the MAGIC : MORE MAGIC switch from The MIT Folklore Project...  ;D
http://www.catb.org/~esr/jargon/html/magic-story.html
*currently teaching my son to work smarter, not harder*
« Reply #74146 on: November 04, 2020, 08:39:23 pm »
People like you are the reason why all computers should be capability architecture machines.
« Reply #74147 on: November 04, 2020, 08:44:52 pm »
Holy crap that is actually sickening. I made it work (disclaimer: some is copy and paste. I am not a java programmer, usually anyway):
import java.lang.reflect.Field;
public class Main {
  public static void fuckUpTheUniverse() {
     try {
     Class<?> integerCache = Class.forName("java.lang.Integer$IntegerCache");
        Field field = integerCache.getDeclaredField("cache");
        field.setAccessible(true);
        Integer[] cache = (Integer[]) field.get(null);
        for (int i = 0; i < 10; i++)
            cache[128+i] = 9;
     } catch(Exception e) {}
  public static void main(String args[]) {
    fuckUpTheUniverse();
        displayCount(i);
  public static void displayCount(Integer i) {
    System.out.println("item is: " + i);
Output:
item is: 9
item is: 9
item is: 9
item is: 9
item is: 9
item is: 9
item is: 9
item is: 9
item is: 9
item is: 9
 :-DD
Source if you want to play: https://jdoodle.com/ia/3Qw (pick JDK 8 or it complains)
Only happens if it goes through a type boxing operation i.e. the reference to Integer on the function call.
« Last Edit: November 04, 2020, 08:50:46 pm by bd139 »
Offline tggzzz
« Reply #74148 on: November 04, 2020, 08:54:59 pm »
If you look at the classic "Smalltalk: Bits of History Words of Advice", you will see a chapter devoted to Smalltalk on the iAPX432, which is not far off a capability machine.
If you look at the Burroughs computers (which have similar security guarantees), you will find a lot of their security rests on being forbidden from executing a program that wasn't created using the golden system tools.
Offline tggzzz
« Reply #74149 on: November 04, 2020, 08:58:55 pm »
Glad to be of (dis)service.
