You are missing the point.
Really ? Your probe point missed its mark, did it not ?
Actually no it did not. It was well in place and when it was, I tried holding it steady with my left hand while trying to operate the camera with the right hand to take a picture of the scope screen for Zoli. Once I had taken the picture and moved my right arm into place to put the camera back onto the bench... that's when the left arm moved a bit and the probe wandered a little bit and .... SPARK !
Better tools and better techniques save us all immense amounts of grief and time.
Yes I am learning Tautech, I am learning a bit more every day !
As for equipment to get, the list is so long that it's difficult to forecast when such or such particular piece of equipment will get purchased next.
Anyway, I found the problem and the fix is under way. See schematic. One of the two beefy wire-wound 0.3 ohms resistors died open-circuit, well, reads 2Megs or something...
Now after looking at my stock of sub ohm resistors, I came with two solutions, pictured below. Either I put x3 0.1R resistors in series, which would give me the closest to the nominal value... so that's the favoured option... or, put two 0.56R in // , which would give 0.28R, which is less than 10% off the nominal value, which is probably on paar with the tolerance of the original resistor I bet....
However I am not too sure what these two 0.3R do. Are they current shunt that tell the amplifier about over-current condition so it can shut / calm down the output ? If so, I guess the value is not so critical, being 5 or 10% off will I guess trigger the protection a tas later... but just a tad, the amp is unlikely to self destruct eh ?! And even if it did, it would be the user's fault for listening too loud to his music !
Or do they hae another purpose, in which the absolute value maybe is not so critical, but where maybe it would be important for the two resistors to be MATCHED ?
Hmmmm.... I guess in order to avoid all these risks and ifs and buts... I should just go for the 3x0.1R in series option to get back to the nominal value and sleep on both ears tonight.
See ? I am getting good / quick at fixing these driver boards already !
As for the replacement transistors, I think I will go for the 2N5320 / 5322 because they are available easily, though very expensive.
The BC 441 / 461 must be too old, they aren't as easy to find. "Dada" is thinking the same it seems, they sell the 2N not the BC.
