Yes, pipe cleaners.
I used them because they're sturdier than cotton swabs, for example, and don't fray.
When you clean the solder joints with alcohol, you're really just dissolving the residue into the alcohol; some residue may still remain after it evaporates, so I like to “dry” the areas afterward.
For example, with pipe cleaners.
We were talking about the Waveform Player, but it's not in the manual, and it wasn't in the DOV version on the Scope either.
I can recommend a small sturdy paint brush and Kim wipes.
Put some IPA and brush so the flux dissolves. Then dab it with the cloth.
Those Kim wipes leave not much fibers so everything is a bit nicer.
Yes, I'm just wondering how you could watch the segmented sequences without this player (before the model change).
Not at all?
So maby there is hardware missing to support the segmented memory fully.
Do we have an ADS800 owner that can test if it's working there ?
Well at least it's working basically.
But when I plug it into the front USB port, absolutely nothing happens, and I can't turn on the Wi-Fi in the settings (error).
What am I supposed to do next? Do I need to do anything else in the settings? Check a box somewhere, or install something?
Or do I have a faulty adapter?
While the normal display essentially overlays different trigger events, segmentation allows you to see the individual trigger events.
While the normal display essentially overlays different trigger events, segmentation allows you to see the individual trigger events.That is not normal. You sure you have no persistency enabled ?
Never seen that before. And makes no sense to 'overlay' multiple triggers except for some dispaly persistence enabled.
What kind of error?
What does this screen look like?
Can someone help me:
I have got WiFi/bluetooth adapter, that mentioned earlier Aldo22, EP-N8568, see photo.
Or do I have a faulty adapter?Which software version are you running ? The original one ?
Then I could imagine the driver for the USB to WIFI is maby not included in android kernel.
Maby OWON has included only for special chip the kernel driver in ADS800 version of firmware.
We could examine the update files or use lsmod and look at /sys/module to see if drivers are included.
They write in one manual:
"Note: If you need to use USB Bluetooth/WiFi module functions, to prevent
module compatibility issues, please purchase these module devices fromour company."
I am running last software version from owon.
I am running last software version from owon.Of course it works in a Windows computer, but not in an Android (Linux) system with limited drivers.
What is the firmware version you are running ? V1.0.1.8.2 ?
Running 'strings' on the wlan.ko included in 1.8.2 firware shows:
"/mnt/fs2/lt_ssd/DS01/nexell_nougat_r2/hardware/realtek/wlan/driver/rtl8723bu"
So I guess the device supported is a RTL8723BU.
And mine is only RTL8723B (without U), which is not the same, probably.
(Wireless mouse in the same front USB works fine, so port is fine I think).
Also mentioned:
alias=usb:v 0BDA p B720
alias=usb:v 7392 p A611
So check if WLAN adapter is 0BDA (Realtek) and PID: B720
The second VID is Edimax (7392). A611 is Edimax EW-7611ULB (Wi-Fi N150 und Bluetooth 4.0 Adapter)
I will try out this
https://www.pollin.de/p/edimax-wlan-bluetooth-usb-stick-ew-7611ulb-742630
Seems ok, but not working. (Picture)
On computer it works JUST in one USB port, in other three USB ports not - so, maybe is it strangely detective, who knows.
Thank you very much.
Thank you very much.That seems like hardware not good. Maby signal on USB weak ? Or maby connector oxydized. Try clean USB with contact cleaner ?
I connected mine via a USB hub.
Maybe that will help?
