Author Topic: FLIR E4 Wifi Resolution and Menu Hack Thread  (Read 444175 times)
Offline tedg
Re: FLIR E4 Wifi Resolution and Menu Hack Thread
« Reply #625 on: March 15, 2018, 01:02:48 am »
Bud,
Thanks for the updated files.   I was able to easily get Basic working on the 3.12.0 via wifi.   I also tested Advanced, but that seemed to break most features:  imageModeMenu was inaccessible/greyed out and the additional visuals (e.g. insulation, humidity, etc) were missing.     I was able to revert back to Basic without any trouble.
The one thing I noticed that was different between your 3.9.0 Advanced and 3.12.0 Advanced deployments was that the 3.12.0 lacked an updated facet.rcc.    I wasn't sure this mattered, but thought I would mention it.
Offline Bud
« Reply #626 on: March 15, 2018, 01:10:31 am »
There is no updated facet.rcc in advanced package. What you experienced had classic symptoms of config file not loading. Try removing the battery for a minute after you load advanced package. Others reported successful update.
Offline tedg
« Reply #627 on: March 15, 2018, 01:47:34 am »
Yeah, just got adv working after trying a second time and doing a few ui mods.
Thanks again!
Offline Sali
  • Country: ru
« Reply #628 on: March 18, 2018, 06:54:31 pm »
brand new camera, 2.0L, 3.9.0
I followed instructions, everything went fine. Everything works great except temp scale(no manual mode, but i was able to bring lock mode back by editing .xml file).
« Last Edit: March 18, 2018, 11:28:17 pm by Sali »
Offline Bud
« Reply #629 on: March 19, 2018, 02:47:54 am »
So tell us what xml file and what you changed, thus may help others down the road.
Offline Sali
  • Country: ru
« Reply #630 on: March 19, 2018, 07:12:11 am »
I simply add one line from old toolbar-config to my camera toolbar-config.xml
In main manu tool bar:
    <ToolBar name="scaleMenu">
      <ToolBar name="scale_auto"/>
      <ToolBar name="scale_scale_manual"/> <----- this line doesn't work for some reason
      <ToolBar name="scale_lock_scale"/>  <----- I add this line and got back lock mode on my camera
    </ToolBar>
 And I also modified measurements menu because other lines seems to be not working
    <ToolBar name="measurementsMenu">
      <ToolBar name="measure_spot_hide"/>
      <ToolBar name="measure_spot_center"/>
      <ToolBar name="measure_spot_max_box"/>
      <ToolBar name="measure_spot_min_box"/>
      <ToolBar name="measure_delta_s"/>
      <ToolBar name="measure_delta_t"/>
    </ToolBar>
By the way there is working manual scale option in picture edit mode...
« Last Edit: March 19, 2018, 07:36:27 am by Sali »
Offline Bud
« Reply #631 on: March 19, 2018, 01:58:00 pm »
scale_lock_scale is not the same as manual scale. Also it was removed on purpose because it did not retain the setting and worse - was screwing up Presets Palettes menu. Carefully test your camera to make sure that line does not cause problems.
Again you are not saying what was not working for you. Please learn to give full context to make your posts useful.
« Last Edit: March 19, 2018, 03:13:25 pm by Bud »
Offline Sali
  • Country: ru
« Reply #632 on: March 19, 2018, 03:52:37 pm »
I didnt say it is the same. I said I add lock mode to my camera menu which had no such mode after hack.
I see no problem with it so far.. But if you help me with manual mode, I'll appreciate it.
« Last Edit: March 19, 2018, 03:54:40 pm by Sali »
Offline Bud
« Reply #633 on: March 19, 2018, 04:13:34 pm »
Not sure where you can look for the manual mode. I'd think there is no reason for it not to work if the firmware  version was the same as dozens  of users had here. You could try to flash 3.12.0 downloaded from Flir web site to eliminate hypotetical possibility of regional subversions of the firmware.
Offline FabLabRUC
« Reply #634 on: March 28, 2018, 01:52:36 pm »
Ok, so I ventured out into the dangerous lands of FLIR hacking. Upgraded our 2.0L 3.5.0 camera to 3.9.0 and tried the basic procedure from page 8. I got as far as step 12, but something very unfortunate must have happened because now the camera boots to a point where it says "Application appcore.exe a serious error and must shut down". It's not something I've seen mentioned before and I'm lost. Is there a way to completely restore an installation of the camera system? Can I force an upgrade? Or is the camera completely bricked?  |O
Offline Bud
« Reply #635 on: March 28, 2018, 02:41:08 pm »
Use the Recovery procedure from page 8 to gain access to the file system, then restore the original files.
« Last Edit: March 28, 2018, 10:52:33 pm by Bud »
The following users thanked this post: FabLabRUC
Offline FabLabRUC
« Reply #636 on: March 28, 2018, 11:35:42 pm »
Thanks. With some tinkering, that did the trick. I got the tweak up and running. Amazing difference. Thanks for your excellent work.
One small issue. I can't seem to get the camera out of RNDIS mode and back to basic USB connection. I've tried to "fif" the camera through the FLIRInstallNet app, but to no avail. It keeps connecting as a network device. Any ideas?
Offline Bud
« Reply #637 on: March 29, 2018, 01:35:15 pm »
Which fif you tried?
Offline FabLabRUC
« Reply #638 on: March 30, 2018, 11:02:52 am »
I repeatedly tried the "Permanently remove RNDIS" to no apparent avail, but I guess the real issue was that I didn't cold-boot the camera. After a battery removal the USB was back. Sorry to waste your time. :-)
best
Offline Bud
« Reply #639 on: March 31, 2018, 03:08:38 am »
 Easter is coming and following my earlier promise here is how to activate a little hidden message:
-switch the camera Image Mode to Digital Camera,
-press and hold the Down key for 6 sec.
The following users thanked this post: capt bullshot
Offline rockwell
« Reply #640 on: March 31, 2018, 07:58:45 am »
We can do it ! Yes, we can.
Now I have to try every menu setting for 6 sec. !
Happy Eastern.
The following users thanked this post: Bud
Offline Bud
« Reply #641 on: April 13, 2018, 02:06:45 am »
No new firmware for six months....   :o
Offline David C
« Reply #642 on: April 13, 2018, 02:07:46 am »
What's that about ?
Offline Bud
« Reply #643 on: April 14, 2018, 08:06:48 pm »
3.12 was half baked and seemed to be an intermediate firmware version. I was expecting a new logically complete version. Maybe we will see a major rewrite of the security portion of it.
Offline Fraser
« Reply #644 on: April 14, 2018, 11:22:02 pm »
The Ex series is now quite old. I would not be at all surprised to see a new model released soon that runs Linux, like the new Exx series cameras. FLIR will not waste resources on a near end of life product.
Fraser
Offline Abvelv
« Reply #645 on: April 21, 2018, 11:00:44 am »
I have a E4 with 3.12.0. I downloaded the basic 3.9.0 and advanced 3.12.0. I don't see the cfccfg_v2.py (or cfccfg.py) python script in any of the archives. Could someone please point me to where I can find it?
Offline Platonas
  • Country: cy
« Reply #646 on: May 15, 2018, 10:45:47 am »
Hello Abvelv,
I uploaded the file for you.  I don't remember the link I used to download it. I search the Forum but couldn't find anything.
It is not my file, credits belong to the creator who I thank for his work too.
http://www.mediafire.com/file/nbrba1brtbfsazt/cfccfg_V2.rar
I own the E4 non WiFi HW 2.0L and FW 3.12.0 which I successfully liberated to the Basic at first and then to Advanced package.
I would like to express my Thanks to Bud for his hard work which made this possible.
Thanks a lot BUD!!!
Offline AlbertF
  • Country: cl
« Reply #647 on: May 16, 2018, 04:55:42 am »
Hello Eevblog Community
I have read a lot about the upgrade of E4 Camera
I own a E4 2.0 L 3.12.0 with Wifi.
I would like to ask: Is it possible for a person who doesn't have great knowledge in programming to do this upgrade?
I am only interesting in the Resolution upgrade.
Best Regards
Albert
Offline Platonas
  • Country: cy
« Reply #648 on: May 22, 2018, 12:42:16 pm »
Hello AlbertF,
There is no need to know programming at all, you just follow the instructions as given by Bud.
You must have a basic understanding of Telnet and ftp connections.
Have in mind there is no guaranty that you will not brick your camera if you do something wrong.
Regards
P.
Offline msquared
« Reply #649 on: May 23, 2018, 05:24:25 am »
Just wanted to pass on a quick story and take the opportunity to say...
Thank you, Bud!!!
I recently got my E4 back from Flir repair and found it had firmware 3.12.4 installed.  :scared:
Well upon connecting it to Flir Tools and clicking "upgrade" in the initial pop up window I was prompted to "upgrade" the camera to a newer version. Which just happened to be 3.12.0, the camera auto downgraded itself.  :)
Imagine my surprise and happiness. You can all imagine what happened next.
Thanks again to everyone. Hope this helps if someone runs into a camera with 3.12.4 installed.
