Author Topic: Flir E40 Upgrade & Configuration  (Read 171076 times)
Online Zucca
  • EE meid in Itali
Re: Flir E40 Upgrade & Configuration
« Reply #300 on: June 07, 2018, 08:30:53 am »
Welcome Devov to the club, well done!
Z
Offline eKretz
« Reply #301 on: June 07, 2018, 11:49:24 am »
Anybody have a working link to the 2.23 firmware?
Online Zucca
  • EE meid in Itali
« Last Edit: June 07, 2018, 12:16:51 pm by zucca »
Offline eKretz
« Reply #303 on: June 07, 2018, 12:28:03 pm »
Not working for me, some kind of error - says site down. Will try again later.
Offline eKretz
« Reply #304 on: June 07, 2018, 05:53:06 pm »
Still dead. Anyone else?
Offline Jorkah
« Reply #305 on: June 07, 2018, 09:45:41 pm »
I will put it up tomorrow for you if needed.
The following users thanked this post: eKretz
Offline eKretz
« Reply #306 on: June 08, 2018, 12:15:00 am »
Thanks. Will update if I get the other link to work or not.
Offline eKretz
« Reply #307 on: June 08, 2018, 05:22:28 am »
Still no dice on that firmware. The site keeps giving the same error message, have tried it probably 15 times today throughout the day.
Offline eKretz
« Reply #308 on: June 08, 2018, 05:33:57 am »
BTW, saw that someone mentioned testing the 2.27.16 firmware to see if it was okay...did anyone ever give it a go?
Offline Jorkah
Offline eKretz
« Reply #310 on: June 08, 2018, 08:38:17 am »
Thank you much kind sir! I am in your debt.
Offline Jorkah
« Reply #311 on: June 08, 2018, 07:58:39 pm »
Just helping someone like I was helped when I needed it.
Offline ksilabs
« Reply #312 on: July 16, 2018, 05:23:18 am »
Any luck with getting that flir_exx_pn645_pn646_v3.12.7_update_pack.zip update?
I've just bought a new (NOS, still in original packaging and factory sealed) E40 and it came with 3.18.0 firmware so I need those missing files to get the full functionality.
I can host files on my www.ksilabs.com site if needed. It is my own web site, not hosted anywhere, running on my own server farm so no stupid banners/registration/limits/whatever. I can also setup ftp and git servers if needed. The latter, IMHO, is the best way to keep track of all changes and be able to roll back to any point if needed.
All my servers run on Fedora, nothing is hosted anywhere -- I only buy Internet connectivity -- so I have full control over everything.
Offline jumbo
« Reply #313 on: July 22, 2018, 10:31:36 am »
Hello, I have Flir E30bx with serial number 49202XXX.
I made hack like 2-3 years ago, then it was nothing better then this instruction:
https://www.eevblog.com/forum/thermal-imaging/flir-e4-thermal-imaging-camera-teardown/msg561266/#msg561266
I turn on temperatures 0-650st.C
I turn on temperatures 200-1200st.C (but camera shows only >80st.C)
But now I see a lot of work with E30-E60 cameras, great to see it. Maybe I can help some how?
1. - WiFi
I have few question about my model, I tried to change "slbwver" values to turn on wifi, but after update they are going to "*".
I put only random numbers there, because I dont know what values should it be in the box: Part, Revision, Serial for "slbwver"
2. - Range 200-1200st.C
I turn on temperatures 200-1200st.C but there is no RBF. I would like to try to calibrate camera in this range, my friend work in laboratory and there they have "black body"/"calibration owen" in a range to 2000st.C or how I should call it. But they use it for another reason and dont know nothing about Flir cameras. So if somebody can explain me how to calibrate camera only in this one range 200-1200st.C without touching old calibration it will be great.
3. - new features
I last time touch my files in the camera in 2014 or 2015, I even dont remember when. Now I see a lot of work on Exx files. Could somebody correct my files or explain me what I should change? I dont whant to change signature like name "E30bx", serial number and other really basic information. I am looking only for better resolution, quality and if its possible MSX. Yes, my camera is actually without MSX. I didn't upload on my camera any extra files, I only changed this files below.
FlashFS\system\appcore.d\config.d
# Generated at 2011-09-16 15:13:31
.caps entry
.caps.config entry
.caps.config.name text "app E30bx_B"
.caps.config.revision text "1.1"
.caps.config.image entry
.caps.config.image.framegrab entry
.caps.config.image.framegrab.fusion entry
.caps.config.image.framegrab.fusion.enabled bool true
.caps.config.image.framegrab.visual entry
.caps.config.image.framegrab.visual.enabled bool true
.caps.config.image.sensor entry
.caps.config.image.sensor.enabled bool true
.caps.config.image.services entry
.caps.config.image.services.store entry
.caps.config.image.services.store.enabled bool true
.caps.config.image.services.store.radiometric entry
.caps.config.image.services.store.radiometric.enabled bool true
.caps.config.image.services.store.incompatible entry
.caps.config.image.services.store.incompatible.enabled bool false
.caps.config.image.services.store.incompatible.level int32 0
.caps.config.image.settings entry
.caps.config.image.settings.enabled bool true
.caps.config.image.settings.downsample bool true
.caps.config.image.settings.resIR int32 320
.caps.config.image.settings.resVIS int32 1600
.caps.config.image.sysimg entry
.caps.config.image.sysimg.alarms entry
.caps.config.image.sysimg.alarms.enabled bool true
.caps.config.image.sysimg.alarms.measfunc entry
.caps.config.image.sysimg.alarms.measfunc.enabled bool true
.caps.config.image.sysimg.alarms.measfunc.maxCount int32 3
.caps.config.image.sysimg.alarms.humidity entry
.caps.config.image.sysimg.alarms.humidity.enabled bool true
.caps.config.image.sysimg.alarms.humidity.maxCount int32 1
.caps.config.image.sysimg.alarms.insulation entry
.caps.config.image.sysimg.alarms.insulation.enabled bool true
.caps.config.image.sysimg.alarms.insulation.maxCount int32 1
.caps.config.image.sysimg.irMarkers entry
.caps.config.image.sysimg.irMarkers.enabled bool false
.caps.config.image.sysimg.irMarkers.spot entry
.caps.config.image.sysimg.irMarkers.spot.enabled bool false
.caps.config.image.sysimg.irMarkers.spot.maxCount int32 0
.caps.config.image.sysimg.irMarkers.arrow entry
.caps.config.image.sysimg.irMarkers.arrow.enabled bool true
.caps.config.image.sysimg.irMarkers.arrow.maxCount int32 0
.caps.config.image.sysimg.irMarkers.box entry
.caps.config.image.sysimg.irMarkers.box.enabled bool false
.caps.config.image.sysimg.irMarkers.box.maxCount int32 0
.caps.config.image.sysimg.measureFuncs entry
.caps.config.image.sysimg.measureFuncs.enabled bool true
.caps.config.image.sysimg.measureFuncs.diff entry
.caps.config.image.sysimg.measureFuncs.diff.enabled bool true
.caps.config.image.sysimg.measureFuncs.diff.maxCount int32 1
.caps.config.image.sysimg.measureFuncs.diff.calcMask int32 65526
.caps.config.image.sysimg.measureFuncs.isotherm entry
.caps.config.image.sysimg.measureFuncs.isotherm.enabled bool true
.caps.config.image.sysimg.measureFuncs.isotherm.calcMask int32 20
.caps.config.image.sysimg.measureFuncs.isotherm.dual bool false
.caps.config.image.sysimg.measureFuncs.isotherm.fixScale bool false
.caps.config.image.sysimg.measureFuncs.isotherm.interval bool true
.caps.config.image.sysimg.measureFuncs.isotherm.invInterval bool false
.caps.config.image.sysimg.measureFuncs.isotherm.maxCount int32 1
.caps.config.image.sysimg.measureFuncs.mbox entry
.caps.config.image.sysimg.measureFuncs.mbox.enabled bool true
.caps.config.image.sysimg.measureFuncs.mbox.calcMask int32 1924
.caps.config.image.sysimg.measureFuncs.mbox.maxCount int32 5
.caps.config.image.sysimg.measureFuncs.mcircle entry
.caps.config.image.sysimg.measureFuncs.mcircle.enabled bool false
.caps.config.image.sysimg.measureFuncs.mcircle.calcMask int32 1924
.caps.config.image.sysimg.measureFuncs.mcircle.maxCount int32 0
.caps.config.image.sysimg.measureFuncs.mline entry
.caps.config.image.sysimg.measureFuncs.mline.enabled bool false
.caps.config.image.sysimg.measureFuncs.mline.calcMask int32 1924
.caps.config.image.sysimg.measureFuncs.mline.maxCount int32 0
.caps.config.image.sysimg.measureFuncs.reftemp entry
.caps.config.image.sysimg.measureFuncs.reftemp.enabled bool true
.caps.config.image.sysimg.measureFuncs.reftemp.calcMask int32 1924
.caps.config.image.sysimg.measureFuncs.reftemp.maxCount int32 1
.caps.config.image.sysimg.measureFuncs.script entry
.caps.config.image.sysimg.measureFuncs.script.enabled false
.caps.config.image.sysimg.measureFuncs.script.maxCount int32 0
.caps.config.image.sysimg.measureFuncs.spot entry
.caps.config.image.sysimg.measureFuncs.spot.enabled bool true
.caps.config.image.sysimg.measureFuncs.spot.calcMask int32 514
.caps.config.image.sysimg.measureFuncs.spot.maxCount int32 5
.caps.config.image.sysimg.visualMarkers entry
.caps.config.image.sysimg.visualMarkers.enabled bool true
.caps.config.image.sysimg.visualMarkers.spot entry
.caps.config.image.sysimg.visualMarkers.spot.enabled bool false
.caps.config.image.sysimg.visualMarkers.spot.maxCount int32 0
.caps.config.image.sysimg.visualMarkers.arrow entry
.caps.config.image.sysimg.visualMarkers.arrow.enabled bool false
.caps.config.image.sysimg.visualMarkers.arrow.maxCount int32 0
.caps.config.image.sysimg.visualMarkers.box entry
.caps.config.image.sysimg.visualMarkers.box.enabled bool false
.caps.config.image.sysimg.visualMarkers.box.maxCount int32 0
.caps.config.image.targetNoise entry
.caps.config.image.targetNoise.enabled bool true
.caps.config.image.targetNoise.targetNoiseMk int32 5
.caps.config.image.zoom entry
.caps.config.image.zoom.enabled bool true
.caps.config.image.zoom.maxFactor double 4
.caps.config.system entry
.caps.config.system.focus entry
.caps.config.system.focus.laser entry
.caps.config.system.focus.laser.updateFocus entry
.caps.config.system.focus.laser.updateFocus.enabled bool true
# ID 49202
# CRC01
FlashFS\system\services.d\config.d
# Appservices wlan configuration
.caps entry
.caps.config entry
.caps.config.name text "srvs E30bx_B"
.caps.config.wlan entry
.caps.config.wlan.enabled bool true
.caps.config.bluetooth entry
.caps.config.bluetooth.enabled bool true
# ID 49202
# CRC01
FlashFS\system\ui.d\config.d
# Generated at 2011-09-16 15:13:32
.caps entry
.caps.config entry
.caps.config.name text "GUI E30bx_B"
.caps.config.IIG entry
.caps.config.IIG.enabled bool true
.caps.config.IIG.DC int32 1
.caps.config.IIG.IR int32 1
.caps.config.IIG.canvasSketches int32 0
.caps.config.IIG.IRImageSketch bool false
.caps.config.IIG.DCImageSketch bool false
.caps.config.IIG.textAnnotations int32 1
.caps.config.IIG.videos int32 1
.caps.config.IIG.voiceAnnotations int32 1
.caps.config.IIG.objects int32 5
.caps.config.image.enabled bool true
.caps.config.image.adjust entry
.caps.config.image.adjust.enabled bool true
.caps.config.image.adjust.auto bool true
.caps.config.image.adjust.interval bool true
.caps.config.image.adjust.above bool false
.caps.config.image.adjust.below bool false
.caps.config.fusion entry
.caps.config.fusion.enabled bool true
.caps.config.fusion.thermal entry
.caps.config.fusion.thermal.enabled bool true
.caps.config.fusion.thermal.auto bool true
.caps.config.fusion.thermal.interval bool true
.caps.config.fusion.thermal.above bool true
.caps.config.fusion.thermal.below bool true
.caps.config.fusion.PIP entry
.caps.config.fusion.PIP.enabled bool true
.caps.config.fusion.PIP.locked bool false
.caps.config.laser entry
.caps.config.laser.enabled bool true
.caps.config.laser.positionMarker bool true
.caps.config.measure entry
.caps.config.measure.enabled bool true
.caps.config.measure.emissivityTable entry
.caps.config.measure.emissivityTable.enabled bool true
.caps.config.measure.externWindow entry
.caps.config.measure.externWindow.enabled bool true
.caps.config.measure.localObjectParams entry
.caps.config.measure.localObjectParams.enabled bool false
.caps.config.measure.screening entry
.caps.config.measure.screening.enabled bool false
.caps.config.mode entry
.caps.config.mode.enabled bool true
.caps.config.mode.program bool false
.caps.config.mode.panorama bool false
.caps.config.mode.video bool true
.caps.config.mode.radiometricVideo bool false
.caps.config.menu entry
.caps.config.menu.enabled bool true
.caps.config.menu.presets bool false
.caps.config.save entry
.caps.config.save.enabled bool true
.caps.config.save.simultaneous bool true
.caps.config.save.fastShoot bool false
.caps.config.report entry
.caps.config.report.enable bool true
.caps.config.report.createPdf bool true
# ID 49202
# CRC01
Offline ksilabs
« Reply #314 on: July 22, 2018, 08:31:31 pm »
on my PC I found the old FW v3.12.7 for your E40 Late 2013 ( FLIR Exx P/N:645xx / 646xx )
and there are all files for WebGUI inside
[skipped]
as attachment the relevant part (file size limit here is 1mb)
rename to zip
The problem is there is no attachment :(
Do you still have that flir_exx_pn645_pn646_v3.12.7_update_pack.zip archive somewhere? Would you share it so it would've been possible to get fully working service menu in 4.13.0 firmware?
It is NOT just those *.asp web files required for service menu to work; there are also 2 apps one of which is prodapp.exe that those *asp files call to perform their functions and those apps are also missing in 3.18.0 and any newer firmware.
Those *.asp files from 2.x.x firmware would probably mostly work in 4.13.0 but prodapp might not -- 3.x.x and newer versions are Qt-based while 2.x.x used some other toolkit so it might not work in 3.x.x/4.x.x. This is why it is important to get that ENTIRE flir_exx_pn645_pn646_v3.12.7_update_pack.zip to cherrypick ALL required parts.
Does anybody have that update he could share? It doesn't have to be 3.12.7, an earlier 3.x.x version would also work.
Maybe somebody got that attachment somewhere if there was any?
Maybe someone still has a camera with 3.12.7 (or earlier 3.x.x) firmware and can post his /FlashBFS and /FlashFS directories copy?
« Last Edit: July 22, 2018, 10:51:42 pm by ksilabs »
Offline eKretz
« Reply #315 on: July 22, 2018, 09:02:45 pm »
1. - WiFi
3. - new features
.caps entry
.caps.config entry
# ID 49202
# CRC01
.caps entry
.caps.config entry
# ID 49202
# CRC01
.caps entry
.caps.config entry
# ID 49202
# CRC01
You already have the resolution upgraded, but I would also switch the intentional noise entry off. Can't help on the wifi, not familiar with those settings, my E40 came with wifi working already. AFAIK any entry you see with a "false" flag can be changed to "true" without hurting anything. That's what I did, just changed them a few at a time and any that didn't work or weren't useful to me I set back to "false" again.
I have been playing with the lens calibration function in the service menu also but haven't got a good black body so I haven't completed the process.
The following users thanked this post: jumbo
Online Zucca
  • EE meid in Itali
« Reply #316 on: July 23, 2018, 06:59:07 am »
1. - WiFi
It is terribly simple: there is a separate board in the Flir Exx which does the radio communication (WIFI and Bluetooth). If in your model there is not that board, no SW hack can help.
Sorry jumbo I don't have the flir_exx_pn645_pn646_v3.12.7_update_pack.zip you are looking for. You colud PM some guys here.
Offline eKretz
« Reply #317 on: July 23, 2018, 11:38:59 am »
Also, I don't think there's any way to enable MSX for the earlier Exx cameras that didn't originally come with it "in-camera" so you can view it on the camera LCD, but you can still use it in FLIR Tools if you want. You'll need to take the image in one of the blended modes, so photos with both the visual and IR cameras are taken. Then you can just click the MSX button on the toolbar in FLIR Tools and it will convert it.
Offline ksilabs
« Reply #318 on: July 29, 2018, 05:12:08 am »
I uploaded the original package flir_exx_pn645_pn646_v3.12.7_update_pack.zip here
durability 30 days
http://www.filedropper.com/flirexxpn645pn646v3127updatepack
and here
http://www.file-upload.net/download-10007428/flir_exx_pn645_pn646_v3.12.7_update_pack.zip.html
You can harmless copy the prodapp.exe and restartapp.bat to your E40 (service mode app, also for Web GUI)
see
https://www.eevblog.com/forum/testgear/flir-e4-thermal-imaging-camera-teardown/msg415480/#msg415480
and here for using rls
https://www.eevblog.com/forum/testgear/flir-e4-thermal-imaging-camera-teardown/msg400024/#msg400024
But a full firmware downgrade is risky.
Good luck!
Does anybody have this archive? Would you share, PLEASE?
Even just prodapp.exe from 3.xx.xx version earlier than 3.18.0 would be VERY VERY helpful.
Guys, PLEASE!, share that archive!!!
I simply can't believe nobody have it somewhere anymore...
Offline ksilabs
« Reply #319 on: July 29, 2018, 05:43:32 am »
Thanks this form and everbody.  I upgrade E40 with 320x240
SN: 645xxxxxx
firmware: 3.12B.7 -> 4.10
Q1:
Everybody know how to login E40 (2014) service menu?
I am try user:flir pwd: 3vlig can not login web service menu.
Q2:
Where to buy lens plastic cover, please see the attach image.
Thanks a lot.
RE: Q1: in the latest firmware they removed the web service menu. I think they completely removed it. I do still have a backup of the previous firmware, so if someone who has greater expertise wants to compare, then let me know.
Do you STILL have a copy of that previous firmware? I am VERY VERY interested in that. PLEASE PLEASE tell you still have it! :)
Offline ksilabs
Offline ksilabs
Offline Chanc3
« Reply #322 on: July 29, 2018, 07:14:35 am »
SN: 645xxxxxx
Q1:
Q2:
Thanks a lot.
I don't have the firmware pack, but all the files from the camera using that version. Happy to send over. Just let me know where to send it, in PM.
Offline ksilabs
« Reply #323 on: July 29, 2018, 08:14:28 am »
PM sent.
Offline Jorkah
« Reply #324 on: August 01, 2018, 07:16:55 am »
I uploaded it again, so it will work for 30 days again.
http://www.filedropper.com/flirexxpn490v22314updatepack
