Author Topic: Flir E40 Upgrade & Configuration  (Read 170982 times)
Offline Fraser
Re: Flir E40 Upgrade & Configuration
« Reply #350 on: November 01, 2018, 07:17:19 pm »
Did that camera actually shut down during the firmware update ?
If it did, that is pretty much a worst case scenario that is often highlighted by manufacturers as irrecoverable without a return to the service agent. The reason is that, unlike a controlled firmware installation failure, where the firmware updates can reverse the update if it detects a problem, a power failure during the writing to flash memory basically creates a totally corrupted firmware build with no 'back out' path.
In cases such as this, on embedded computers, if the boot loader remains intact, some clever IT bods install a new firmware image. Sadly I do not think such is so straight forward with the Exx series though. You need to be able to access the operating system and to access that you either need to change the USB mode for FTP communications, or directly access the OS via an RS232 engineering port within the camera. You cannot take someone else's camera firmware and clone it onto your camera as each firmware build is effectively camera specific with file CRC's and unique factory calibration data.
I am sorry to say, I think this will require return to FLIR for a new firmware installation using their production utilities.
Fraser
The following users thanked this post: t.AM
Offline t.AM
  • Country: ua
« Reply #351 on: November 07, 2018, 06:19:30 pm »
To change the resolution I need in
FlashFS/system/appcore.d/config.d/conf.cfg
.caps.config.image.settings.resIR int32 160
.caps.config.image.targetNoise.targetNoiseMk int32 55
to
.caps.config.image.settings.resIR int32 320
.caps.config.image.targetNoise.targetNoiseMk int32 0
Is that all ? or need something else?
after replacing the file, pictures taken with new settings, does not work :"(
Offline miami123
« Reply #352 on: January 18, 2019, 02:29:44 am »
Hi, I bought FLIR e40 from 2014 software version 3.18.0 with MSX. How to make an upgrade to 320x240. Do I have to update the software to version 4.13 first ?? Can anyone give some advice to the E40 with MSX with software 3.18.0
thx
Offline Chanc3
« Reply #353 on: January 18, 2019, 07:29:14 am »
to
Did you read the rest of the guide where you need to regenerate the CRC code?
Offline Chanc3
« Reply #354 on: January 18, 2019, 07:30:02 am »
thx
Read this thread fully. Yes it can be upgraded. No don't update.
The following users thanked this post: cuda12
Offline Pinkus
Re: Flir E40 Macro lens
« Reply #355 on: February 20, 2019, 11:21:43 pm »
In case you are interested, I here added some useful information and a STL file for 3D printing for a Exx macro lens: https://www.eevblog.com/forum/thermal-imaging/znse-lenses-on-ebay/msg2214507/#msg2214507
Offline netpac
« Reply #356 on: February 23, 2019, 10:16:56 am »
Can anybody share
flir_exx_pn645_pn646_v3.12.7_update_pack.zip or flir_exx_pn645_pn646_v3.18.0_update_pack.zip
Please and thank you
Offline Chanc3
« Reply #357 on: February 23, 2019, 10:48:09 am »
Can anybody share
I might have these, will check on Monday when I'm back in the office.
Offline netpac
« Reply #358 on: February 23, 2019, 11:40:05 am »
That would be very helpful. Many Thanks
Offline netpac
« Reply #359 on: February 26, 2019, 10:58:37 am »
@Chanc3
please and thank you.
Offline Chanc3
« Reply #360 on: February 26, 2019, 09:24:48 pm »
Sent you a PM with a link to my stash.
Offline netpac
« Reply #361 on: February 28, 2019, 11:31:54 am »
FLIR Exx P/N:645xx / 646xx Firmware List:
ZIP-File:        OS:      App:    Prodkit:
flir_exx_pn645_pn646_v3.0.1_update_pack.zip       17.5.0  4.0.0   4.0.0.1
flir_exx_pn645_pn646_v3.1.1_update_pack.zip       17.5.0  4.0.1   4.0.0.1
flir_exx_pn645_pn646_v3.2.1_update_pack.zip       17.6.2  4.0.2   4.0.0.1
flir_exx_pn645_pn646_v3.3.2_update_pack.zip       17.6.3  4.0.3   4.0.0.2
flir_exx_pn645_pn646_v3.4.2_update_pack.zip       17.6.3  4.0.4   4.0.0.2
flir_exx_pn645_pn646_v3.5.2_update_pack.zip       17.6.4  4.0.4   4.0.0.2
flir_exx_pn645_pn646_v3.6.3_update_pack.zip       17.6.4  4.0.5   4.0.0.3
flir_exx_pn645_pn646_v3.7.4_update_pack.zip       17.6.4  4.0.6   4.0.0.4
flir_exx_pn645_pn646_v3.8A.4_update_pack.zip     17.6.4  4.0.7   4.0.0.4
flir_exx_pn645_pn646_v3.8.4_update_pack.zip       17.6.6  4.0.7   4.0.0.4
flir_exx_pn645_pn646_v3.8.5_update_pack.zip       17.6.6  4.0.7   4.0.0.5
flir_exx_pn645_pn646_v3.8B.5_update_pack.zip     17.6.8  4.0.7   4.0.0.5
flir_exx_pn645_pn646_v3.9.5_update_pack.zip       17.6.8  4.0.8   4.0.0.5
flir_exx_pn645_pn646_v3.10.5_update_pack.zip     17.6.8  4.0.9   4.0.0.5
flir_exx_pn645_pn646_v3.11.6_update_pack.zip     17.6.8  4.0.10  4.0.0.6
flir_exx_pn645_pn646_v3.12.7_update_pack.zip     17.6.8  4.0.11  4.0.0.7
flir_exx_pn645_pn646_v3.12B.7_update_pack.zip   17.6.12 4.0.11  4.0.0.7
flir_exx_pn645_pn646_v3.13.0_update_pack.zip     17.6.10  4.0.12  0 -> no Service Menu
flir_exx_pn645_pn646_v3.13.8_update_pack.zip     17.6.10  4.0.12  4.0.0.8
flir_exx_pn645_pn646_v3.14.0_update_pack.zip     17.6.10  4.0.13  0 -> no Service Menu
flir_exx_pn645_pn646_v3.14.8_update_pack.zip     17.6.10  4.0.13  4.0.0.8
flir_exx_pn645_pn646_v3.14.9_update_pack.zip     17.6.10  4.0.13  4.0.0.9
flir_exx_pn645_pn646_v3.15.0_update_pack.zip     17.6.10  4.0.14  0 -> no Service Menu
flir_exx_pn645_pn646_v3.15.9_update_pack.zip     17.6.10  4.0.14  4.0.0.9
flir_exx_pn645_pn646_v3.15.10_update_pack.zip   17.6.10  4.0.14  4.0.0.10
flir_exx_pn645_pn646_v3.16.0_update_pack.zip     17.6.12  4.0.15  0 -> no Service Menu
flir_exx_pn645_pn646_v3.16.10_update_pack.zip   17.6.12  4.0.15  4.0.0.10
flir_exx_pn645_pn646_v3.16.11_update_pack.zip   17.6.12  4.0.15  4.0.0.11
flir_exx_pn645_pn646_v3.17.0_update_pack.zip     17.6.12  4.0.16  0 -> no Service Menu
flir_exx_pn645_pn646_v3.17.12_update_pack.zip   17.6.12  4.0.16  4.0.0.12
flir_exx_pn645_pn646_v3.18.0_update_pack.zip     17.6.12  4.0.17  0 -> no Service Menu
flir_exx_pn645_pn646_v3.18.12_update_pack.zip   17.6.12  4.0.17  4.0.0.12
flir_exx_pn645_pn646_v4.1.0_update_pack.zip       18.7.0   4.1.0   0 -> no Service Menu
flir_exx_pn645_pn646_v4.1.13_update_pack.zip     18.7.0   4.1.0   4.1.0.13
flir_exx_pn645_pn646_v4.2.0_update_pack.zip       18.7.2   4.1.1   0 -> no Service Menu
flir_exx_pn645_pn646_v4.2.13_update_pack.zip     18.7.2   4.1.1   4.1.0.13
flir_exx_pn645_pn646_v4.3.0_update_pack.zip       18.7.2   4.1.2   0 -> no Service Menu
flir_exx_pn645_pn646_v4.3.13_update_pack.zip     18.7.2   4.1.2   4.1.0.13
flir_exx_pn645_pn646_v4.4.0_update_pack.zip       18.7.4   4.1.2   0 -> no Service Menu
flir_exx_pn645_pn646_v4.4.13_update_pack.zip     18.7.4   4.1.2   4.1.0.13
flir_exx_pn645_pn646_v4.5.0_update_pack.zip       18.7.6   4.1.3   0 -> no Service Menu
flir_exx_pn645_pn646_v4.5.13_update_pack.zip     18.7.6   4.1.3   4.1.0.13
flir_exx_pn645_pn646_v4.6.0_update_pack.zip       18.7.6   4.1.4   0 -> no Service Menu
flir_exx_pn645_pn646_v4.6.13_update_pack.zip     18.7.6   4.1.4   4.1.0.13
flir_exx_pn645_pn646_v4.7.0_update_pack.zip      18.7.6   4.1.5   0 -> no Service Menu
flir_exx_pn645_pn646_v4.7.14_update_pack.zip    18.7.6   4.1.5   4.1.0.14
flir_exx_pn645_pn646_v4.8.0_update_pack.zip      18.7.6   4.1.6   0 -> no Service Menu
flir_exx_pn645_pn646_v4.8.14_update_pack.zip    18.7.6   4.1.6   4.1.0.14
flir_exx_pn645_pn646_v4.9.0_update_pack.zip      18.7.8   4.1.7   0 -> no Service Menu
flir_exx_pn645_pn646_v4.9.14_update_pack.zip    18.7.8   4.1.7   4.1.0.14
flir_exx_pn645_pn646_v4.10.0_update_pack.zip     18.7.8   4.1.8   0 -> no Service Menu
flir_exx_pn645_pn646_v4.10.14_update_pack.zip   18.7.8   4.1.8   4.1.0.14
flir_exx_pn645_pn646_v4.11.0_update_pack.zip     18.7.8   4.1.9   0 -> no Service Menu
flir_exx_pn645_pn646_v4.11.14_update_pack.zip   18.7.8   4.1.9   4.1.0.14
flir_exx_pn645_pn646_v4.12.0_update_pack.zip     18.7.8   4.1.10  0 -> no Service Menu
flir_exx_pn645_pn646_v4.12.14_update_pack.zip   18.7.8   4.1.10  4.1.0.14
flir_exx_pn645_pn646_v4.13.0_update_pack.zip     18.7.10  4.1.11  0 -> no Service Menu
flir_exx_pn645_pn646_v4.13.14_update_pack.zip   18.7.10  4.1.11  4.1.0.14
Offline eKretz
« Reply #362 on: February 28, 2019, 05:13:03 pm »
Any Chanc3 I could get that link too?  >:D
Offline netpac
« Reply #363 on: February 28, 2019, 06:23:52 pm »
This is only the filelist. If someone has those files - please share. Thank you.
Offline netpac
« Reply #364 on: March 06, 2019, 02:17:39 pm »
I can confirm that a downgrade for Exx PN645 v4.10 to v3.12.7 is (maybe) possible. My camera is working very well after the downgrade from v4.10.0 to 3.12.7 and I have now access to the whole service menu - with 4.10.0 I had some problems with RNDIS and ftp transfer communication and no service menu. I did the following steps:
1. Load the battery from the camera to 100% and connect the external power supply - the upgrade or downgrade tooks around 30 minutes
2. Switch camera to rndis
3. Backup all files with winscp and ftp
4. Copy the new firmware to the sdcard "\StorageCard\FLIRUpdate\"
(E2qtcomb_v3.12.7.fif and eFLIRInstall.exe)
5. start a Telnet session with <telnet 192.168.0.2>
6. from root type <cd \StorageCard\FLIRUpdate>
7. and execute <eFLIRInstall.exe \StorageCard\FLIRUpdate\E2qtcomb_v3.12.7.fif>
8. confirm all with yes
9. when the upgrade is finished restart your camera a second time - there is a second upgrade process
note - it worked for me. But there is no guarantee that it works for you as well.
Offline nikoum
  • Country: gr
« Reply #365 on: May 29, 2019, 03:06:19 pm »
Does anybody know if an upgraded resolution and menu mk1 E40 with 490 serial and sw:2.23.14 can be updated to a newer software version without losing the upgrade. I have read in old posts, years ago that 2.23.14 is the end of the line, but i am wondering if this is still valid
Offline Fraser
« Reply #366 on: May 29, 2019, 03:19:09 pm »
Still valid.
The one more recent Mk1 firmware is a total unknown in terms of its reason for existence. There appears no good reason to install it and plenty to not install it.  Mk2 firmware does not work on a Mk1 platform.
Fraser
Offline nikoum
  • Country: gr
« Reply #367 on: May 29, 2019, 03:31:53 pm »
Thank you Fraser. Do you or someone else know if the add isotherm / above or below function can be modified to include an alarm with beep function such as in add spot, add box and add circle ?
« Last Edit: May 29, 2019, 03:55:58 pm by nikoum »
Offline Fraser
« Reply #368 on: May 29, 2019, 06:34:06 pm »
Sorry, cannot help on that request.
Fraser
Offline Mannyb
« Reply #369 on: June 11, 2019, 06:09:13 pm »
Dear All i'm a newbie and i just purchased a used Flir E40 and i want to upgrade to e60 software
i read almost all the tread and spent several hours but still not sure what to do
below are the information
Model: E40 1.2
Serial: 645XXXXX
Software 5.2.0
can i upgrade this this E60 Software?
kindly advice please
Offline Mannyb
« Reply #370 on: June 12, 2019, 12:14:50 am »
Just a follow up
i managed to run CRC01 and created a file to flash
but there's seems a problem and i can't connect my camera to pc either in USB RNDIS i also tried FileZilla & total commander with no luck
do i have to downgrade the software first?
is there another option to flash the e60 fif file?
i would really appreciate any feedback
Offline cuda12
« Reply #371 on: June 13, 2019, 09:32:06 pm »
connection errors kind of depend on what OS you are using, windows 7 on up and xp made the connection easy windows 10 at first didn't work but recent version connect now. What are you using?
Offline Mannyb
« Reply #372 on: June 14, 2019, 07:17:20 am »
Posted by: netpac
« on: March 07, 2019, 01:17:39 am »
    Insert Quote
Hi Netpac
do still have the the firmware v3.12.7.fif?
would you be able to share as i need it
thanks
Offline Mannyb
« Reply #373 on: June 15, 2019, 06:10:21 am »
Thanks all for the support
after various trial and error with tons of back ups, my Flir E40 1.2 with software 5.2.0 serial 645XXXX, are now 320X240 pixels
Lens are also set 4X instead of 2X
still working to enable some functions especially the insulation warning which is disable on E40
again thank you all, this is a great site
Offline Mannyb
« Reply #374 on: June 17, 2019, 08:55:36 pm »
A simple and easy way to replace the flir Logo is just to edit the bootlogo.bmp itself from \FlashBFS\system and paste your own logo on the same picture, just make sure your logo has the same pixels size and format, so every time you boot up or open your unit your information or logo will appear.
1. create or edit your own logo save it with 320X240 Pixel using paint editor
1. Extract bootlogo.bmp using pft connect,  save somewhere
2. edit the bootlogo.bmp and paste your own logo with the same pixel 320X240
3. put it back using pft connect
4. remove the battery and re-start
