I'm about to order new encoders.
After thinking it twice, I'll avoid the mechanical steps in the small encoders, adjusting certain values require a lot of turning, dealing with a ton of clicking will make the experience even worse!
So the idea is keep it just like it is now, but with more steps per turn to make it less painful, and decent quality parts.
The PEC12R-4220 (7mm shaft) series are a direct replacement (As we already know, thanks to
pu6k1n and
vistorik ).
If not being able to source them, the PEC12R-4225 (12mm shaft) will almost fit, the small caps have a depth of 12mm while the large ones have 11.2mm, it would only require trimming a bit off the shaft end.
- Pushbutton + stepped rotation (Sec/div knob): PEC12R-42
20F-S0024 / PEC12R-42
25F-S0024
- Pushbutton + smooth rotation (Small knobs): PEC12R-40
20F-S0024 / PEC12R-40
25F-S0024
- No pushbutton + stepped rotation (V/div knobs): PEC12R-42
20F-N0024 / PEC12R-42
25F-N0024
Also the PEC12R-3x series will also work, it's the same P/N, just replace the 4xxx with 3xxx.
The difference lies in including a bushing.
The shaft offset is 2mm larger in the PEC12R-42
22 and PEC12R-42
30, so the knob sit 2mm away from the base, though still possible with additional modifications to the shaft.
The difference can be seen here:
