Ok, I got 300MHz upgrade and all options working on my DS2072A which was not able to upgrade to 300MHz. Here is what I did:
1-Install all options, no bandwidth upgrade (NSEH) using rigup or the upgrade utility.
2-Use rigup to get license for NS8N (All options - 56M + 300MHz) and install on scope in any of the methods described in this thread.
The result will be a scope with all options AND 300MHz!!! Success!
By the way, you can't use the upgrade utility to install NS8N since that program always uninstalls all options before installing new ones.
not working for me, NSEH -> License is unavliable....
only NSEQ works for me...
MY God, 229 Pages and counting... I can't believe this thread is still going LOL
It's Alive... Alive.
Ok. to get serious for a second
I have a Rigol DS2072A,
it was loaded with the 2.0 Software from the factory,
it was originally 70 MHz
Now SUCCESSFULLY UPGRADED TO 300MHz
All options Unlocked and 56 Mpt Memory Depth
IF ANYONE NEEDS ANY HELP, I AM HERE TO HELP, and Im happy to do it
So.. Newbies if you have a DS200A
let me know
I know this is a Huge thread, I've gone through it in great detail
NO NEED TO DOWNLOAD ANYTHING
I'll supply it all From a Cloud
if enough people want it
I'll Just upload it for all of you to have access to , For.. Say,.. a Month or so, if you like
However it's easier if you guys just skype me, that's what a few people have been doing
There's 2 Main Issues that Get everyone
1. Make sure that your Scope is Set to COMPUTER for the USB Port,
if it's set to PictBridge and considering that the front USB is PictBridge, Your Scope wont detect
in the computer and you'll be scratching your head as to why
2. Putting the Scope into Firmware Update Mode is a little tricky and takes a correct explanation.
which is where skype comes in.
the answer to issues 1 is go to
UTILITY / IO SETUP / USB DEVICE Make sure the value says COMPUTER
the answer to 2 is
Start with Scope OFF
Now.. before switching it ON
Find the Power Button, DON'T PRESS IT YET, Put your left thumb on the power button
Now, with your Right Thumb find the ORANGE HELP Button, Put your thumb on it
Now.. Press the power button and STRAIGHT AWAY Press the HELP button,
don't wait to see the RIGOL screen
if you see the rigol screen you need to do it quicker
YOU WILL KNOW THAT YOU HAVE DONE IT CORRECTLY IF.......
the button in the top right corner labelled SINGLE Turns Solid Orange
that means the meter is upgrade Mode
Now pop in your USB stick and the CH 1 Button should flash Green
this indicates good communication with the USB Device and you just Wait 2 mins and it's done
if anyone needs any further assistance, Let me know
I'm at
martin@btotechnicalexperts.com.au
be cool guys
Good day!
We received a Rigol DS4014 yesterday. I scanned and read through this huge thread and also found this directory:
http://www.gotroot.ca/rigol/
As I understand, to upgrade to 500MHz I need to use the DS2000A upgrade utility and the DS4000update_00.02.01.00.03.GEL
Can anyone confirm this?
Also want to upgrade my DG4062. How to do this?
Cheers
Sam
So I was wrong. I'm not finding the right info in this thread. Anyone please help?
Link to how to upgrade?
Hopless, but happy
Sam
For the DS4000, you only need MrKrab's firmware at
For the DS4000, you only need MrKrab's firmware at http://www.gotroot.ca/rigol
1. I used MrKrabs firmware on a compatible stick
2. Booted into blackscreen using help button
3. Entered the stick in the USB. Channel 1 didn't blink, but immeadiatly went solid together with run/stop button solid red
After this nothing happens. I hope this helps some of you...
Any help?
Thank you for all replies
did you test the usb stick by saving a screen image to it to make sure the ds4k can see it properly?
on my ds2k, I had to wait a bit before putting the usb stick in, too quick and it did not seem to load. tried again, waited like 30 seconds after the button presses then put it in and it recognised it correctly right away.
The stick works, I saved a png screenshot. I also waited a couple of minutes, still channel one only goes solid without first blinking.
When I used DS4000update_00.02.01.00.03.GEL, the channel 1 LED did blink first and then went solid. After a couple of minutes all lights lit. I restarted and nothing changed in the firmware or TB.
I did use riglol first though. Don't know if thats the wrong order?
In short: DS4000Update.00.02.01.00.03.MrKrabs.GEL on a stick didnt work for me so far...
Cheers
filename has to be DS4000Update.GEL - and nothing else.
DS4014 Upgraded with MrKrabs FirmwareSpecial thanks to MrKrabs and Cybernet for all work and helpfull comments and feedback.
How to Upgrade DS4014 Firmware 00.02.011. Test a USB stick by saving a screenshot on it with the scope
2. Download DS4000Update.00.02.01.00.03.MrKrabs.GEL.zip, rename it DS4000Update.GEL and copy to USB stick
Download the file here:
http://www.gotroot.ca/rigol/3. Turn on scope and quick after power on press HELP couple of times. You boot into a dark screen, only the SINGLE button is red now. Wait for 30-60 seconds
4. Enter the stick. Channel one starts blinking. After couple of minutes all lights turn on. Turn off scope. Remove USB stick and reboot.
Can someone put this as a DS4000_Guide.txt on
http://www.gotroot.ca/rigol/ I searched for about one week for this
Notice the screenshot is set with 5ns/div, but the fall time is 850ps.
I will post some more screenshots soon
FWIW, I had similar issues installing firmware because the scope "didn't like" the USB stick, even though it could otherwise see/write/read to/from it. I tried another USB stick and then it worked. Prolly something in the firmware loader doesn't agree with certain USB interface chips.
I have just Posted a Summary of this Huge Post Here and will help anyone who wants a hand upgrading
but.. this tutorial should simply cover it for those just wanting a quick upgrade and are confused
That is well intended, but you may want to tune your writing style just a wee bit.
Just tried to get the new firmware, and says files are gone....guess Rigol didn't like ppl just downloading it. Anybody out there willing to share the files?
Like Codemonkey said: "The following instructions apply, don't hold me responsible if you brick your scope etc etc..."
Links to download the two update files (Bootloader and Firmware update) -> 00.04.00
Be aware that after finishing the update no downgrading is possible.
Start with the Bootloader File and follow the instructions. After successfully finishing the bootloader update
do NOT reboot as instructed. Instead, continue with the Firmware update file.
Bootloader Update (new link):
https://www.dropbox.com/s/nteyndjz17dmcmi/DS1000Z%28Boot%29update.rar
Firmware Update (new link):
https://www.dropbox.com/s/w9x66ghdhagtsaj/DS1000Z%28ARM%29update.rar
Hello.
Update file(bootloader)here is same as RIGOL International(China) Update file(MD5 checksum is same).
I don't why some model has to be done like that.
So my concerns,if we update only official update file(same as 1st file here) as usual,whether the options are remained or not.
The firmware here(2nd one) is a bit small file size.But I think,totally the result might be same.
Anybody only updated first file here?and no problem?
Be very careful with these files!!!! Bricking is very easy!!!!
You need to do is in 2 steps without reboot! if you reboot after the first file your are dead!
PS: there are some differences between serial numbers too! its better to ask for the right one for your serial number... its free... why download this one?
Thanks for info.
But The firmware which I got directly from the marketing department of RIGOL in China is same as the bootloader file here.
I again ask about it to RIGOL.
(I don't test myself,but others use it,and no report their's dead.)
If I get the useful info,I will up here.
As a noob I would just like to ensure I won't end up bricking my newly bought device. This DS1000Z update will work for the DS1074Z, correct?
There is no DS1000Z - that just refers to the series which is DS1074Z, DS1104Z, DS1074Z-S and DS1104Z-S.
Hi all,
Got my MSO2072A in last week, running Software version 00.03.00.01.03
Since I already opened up the scope in anticipation of my JTAG interface,
I can take some pictures of the inside, if anyone's interested.
If I understand the previous 230 pages correctly, the safest way for me to unlock features is to collect a memory dump of the BF, and ask one of the software gurus on this forum to extract the private key from that.
(Since the "patched" firmware is apparently not MSO-aware, I don't feel comfortable downgrading to that)
Here's hoping I'll end up with an unlocked MSO2302A
Best regards,
Marcel
Hi All,
I have recently acquired my DS2072A scope and I am unable to make the upgrade utility work.
For some reason, the boot loader doesn't accept any older versions other than the latest .GEL file (00.03.00.01.03).
Could I ask one of you gurus to make a new modified FW starting from the latest version available?
Or perhaps, if there is another way, could you please point it to me?
Software version: 00.03.00.01.03 (in short, 00.03.00.SP1)
Hardware version: 1.0.2.0.2 (in short, 2.0)
SPU: 04.00.07
WPU: 01.01.03
CCU: 12.29.00
MCU: 00.06
Many thanks!
my DP832 arrived yesterday, firmware 01.09 and only Analyzer and Monitor options are as trial available
also the riglol key generator doesn't work, after entering the generated key it just says "wrong serial number" (I double checked if I entered the correct one)
it seems that it's since v01.09 and so far no working hack?
Same here. I couldn't downgrade the firmware to 01.06 or 01.08.
I have a DSA815-TG with version 00:01:09.
unfortunately I have seen too late that the keygen does not work with this version. Now I have made a downgrade to version 00:01:05, unfortunately the keygen does not work anyway.
Motherboard: 00:03
Radio Frequency: Board: 0:04
Digital Board: 0:04
Firmware: 00:01:05
Boot: 00:01:02
Maybe someone can give me info.
Downgrade Procedere:
From 09 -> 08 with Power & Preset Button
From 08 -> 06 with normal USB
From 06 -> 05 with normal USB
Thank you so much!
roema
roema
roema:
Is it 1. That the Keygen doesn't work (as in, it will not generate a key code)? If this is the case, did you leave an extra space or character (such as a period after the Serial) with the entry for the Serial, or Option?
or, 2. That the DSA815-TG won't accept the Keygen's resultant key code to open the Option(s) for you?
Please reply here to me, or via a PM.
You also may want to post instead to EEVblog 'Spectrum Analyzer - Rigol DSA815', at the following:
https://www.eevblog.com/forum/testgear/spectrum-analyzer-rigol-dsa815/msg473658/#msg473658 Ted572
ted572:
It works!
I have found MY error, i have not changed the AAAA in keygen..
Thanks for your post!
roema
Is it possible to update the first post in the thread to be summary with links? I tried to find the info that I needed, but gave up after about 40 pages...
Anyway, I have a Rigol 2072 (NOT the A version), into which I have installed the keys generated by an older version of riglol. I have two problems:
1) I used what was later determined to be an invalid device option code to generate my keys. I'm not sure if that is the cause of #2.
2) The scope is locking up more frequently than I would like. It tends to happen about once every 2 or 3 times I use it.
So I'd like to uninstall the keys an upgrade the firmware to the latest version that still allows me to install the unlock keys. Can someone please give me instructions or pointers to the right posts to:
1) Uninstall the keys.
2) What latest firmware is safe to use and where to get it (I assume if I ask Rigol, they'll send me the latest version which is probably incompatible)
