Author Topic: New Hantek DSO2X1X models?  (Read 366787 times)
Offline DavidAlfa
Re: New Hantek DSO2X1X models?
« Reply #750 on: October 01, 2021, 09:41:50 pm »
I noticed something weird: The smallest X step is 8 ns?
In <100ns modes this is very noticeable. Specially in 2ns, where it jumps 4 divisions!
Is it like that or did I mess something up?
Offline vistorik
« Reply #751 on: October 01, 2021, 09:51:20 pm »
Did you change the Hardware number? 001 means generator present, and will work in any model.
Original "C" models have HW version .000
So you can enable the generator in both ways.
Yes, you are absolutely right. 2C10 with HW .001 has generator. I did not know this. And changing the model number only to 2D15 without changing HW number from .000 to .001 - 2D15 with HW .000 also enable generator. So to enable generator on 2CXX devices  it's enough to change model number to 2D15 or to change HW number to .001. Thanks.
« Last Edit: October 02, 2021, 10:53:54 am by vistorik »
Offline DavidAlfa
« Reply #752 on: October 01, 2021, 09:58:59 pm »
Another weird thing: 55 dots / division at 2ns.
That's 25GSps, something went crazy here!
« Reply #753 on: October 01, 2021, 10:13:58 pm »
Perfectly normal for a Run/Stop capture. Try a Dot mode Single shot if you really want to see what's going on.
« Last Edit: October 01, 2021, 10:41:17 pm by tautech »
Offline DavidAlfa
« Reply #754 on: October 01, 2021, 11:03:28 pm »
That was a single shot...
« Reply #755 on: October 02, 2021, 12:09:22 am »
So what does a capture slow and then zoom in show ?
Here's a couple from a SDS1104X-E.
Offline CTwentyTwo
« Reply #756 on: October 02, 2021, 09:51:46 am »
Hi guys, new to the forum. I'm in the market for an O-scope mainly for NTSC analog video. I wanted to see how the Hantek performs in this regard, displaying a CVBS signal. I want to see how good the resolution is in displaying it for noise issues and such. Thank You in advance.
Offline dixvgd
« Reply #757 on: October 02, 2021, 10:54:15 am »
I think all is ok, except strange shift of waveform to the right from trigger position.
Offline vistorik
« Reply #758 on: October 02, 2021, 11:16:03 am »
When you did not change the model number of your device from 2D10 to 2D15 could you please try to do it using the dso3kb_2D15_conversion.upk and say if there is the auto-reboot problem with black display? Thanks.
Sorry, I would not like to do any experiments with my device now, since I am using it intensively right now and I definitely need it on the weekend  :D
So even the smallest probability of getting problems is not acceptable to me.
I understand. I send you a package dso3kb_reboot.upk which script has only one command - reboot
#!/bin/sh
reboot
This package does nothing - only reboots device. if you find a couple of minutes and run this package I would be very grateful to you.
Offline DavidAlfa
« Reply #759 on: October 02, 2021, 11:43:58 am »
Reboots correctly, as expected.
Offline DavidAlfa
« Reply #760 on: October 02, 2021, 11:45:45 am »
Yeah, mine was like, then at some point something weird happened. As you see it shows 25x more dots.
What about the 8ns steps when moving the Horizontal position? Does yours move in ~1 pixel steps?
Offline vistorik
« Reply #761 on: October 02, 2021, 11:51:44 am »
I would be happy to hear the same from hcp.
Offline hcp
« Reply #762 on: October 02, 2021, 01:53:11 pm »
My device reboots correctly with dso3kb_reboot.upk  :)
Offline vistorik
« Reply #763 on: October 02, 2021, 02:36:54 pm »
Thanks a lot.
Offline dixvgd
« Reply #764 on: October 02, 2021, 08:50:10 pm »
Yes, looks like minimal X step is really equal to 8ns..
Another question: what means"Realtime" and "Equ-time" option in dso2x1x? In many attepmts to use "Equ-Time" I found that it makes.. nothing. :o
Offline DavidAlfa
« Reply #765 on: October 03, 2021, 07:21:17 am »
No idea, I also asked that myself when I got the dso, but the manual doesn't say a word about it.
Offline pcprogrammer
« Reply #766 on: October 03, 2021, 08:42:30 am »
Interesting. Equivalent time sampling would mean phase shifting the sample moment over time to obtain a higher sample rate. Only works on repetitive signals. In this case of the Hantek hardware the question is if the FPGA is capable of making a small enough phase shift to make it worth while. With the max sample rate being 1GHz the phase shift needs to be in the order of 100 pico second range to make it usable. All depends on the PLL's and the speed of the interconnect fabric in the FPGA if this is possible. The external clock is most likely 50MHz, so the PLL has to crank this way up.
Offline DavidAlfa
« Reply #767 on: October 03, 2021, 02:08:06 pm »
In the end I decided to make something with the unused Ethernet port.
Offline DavidAlfa
« Reply #768 on: October 04, 2021, 11:06:46 am »
I tried to run the Phoenix binary from another hantek model (4072C I think).
As expected, lots of errors happened, but it had enough time to wipe my eeprom.
Luckly I had a backup. In any case, I made a new package, "Eeprom backup".
It's similar to Backup builder, packs the required binaries and builds a restore package to make it simple.
Also added compiled i2c-tools and eeprog to the binaries section.
« Last Edit: October 04, 2021, 11:08:51 am by DavidAlfa »
Offline blackbile
  • Country: hu
« Reply #769 on: October 05, 2021, 08:23:00 am »
Signal generator square wave - is it normal ???
Offline ik1zyw
    • My blog
« Reply #770 on: October 05, 2021, 09:44:39 am »
Well, "normal" depends on your measurement setup. Can you show a picture of it, and the specs of the probe?
See this thread I started on that subject https://www.eevblog.com/forum/programming/oscilloscope-bandwidth-simulated-with-octavematlab/. It ended that I understood few important things about DSO and high-frequency measurements (and other about simulations).
Last but not least, I am building a 1 ns rise-time test generator 8) (according to the chip datasheet, an ICS512 that popped out a small drawer). BTW, ideas for a faster DIY rise-time test generator are welcome.
Paolo
Suffering from light form of TEAS.
Offline vistorik
« Reply #771 on: October 08, 2021, 11:40:54 am »
David, I send you FW b101 to update the list. This FW I've got from Hantek platform-tools. Thanks.
« Last Edit: October 08, 2021, 07:52:40 pm by vistorik »
Offline DavidAlfa
« Reply #772 on: October 09, 2021, 09:00:34 am »
bxxx firmwares are the same as 3xxx.
Ex. b000=3000, b101=3101. 3102 will probably show b102.
This must be something related to the fpga itself.
Today I was fighting with the SPI decoder, which decided to not work under any circumstances. Finally,  I found it to only work at 5V/div.
Not really a problem, but HANTEK COULD TELL THAT in their manual so we don't lose hours figuring out how to make it work.
« Last Edit: October 09, 2021, 10:31:26 am by DavidAlfa »
The following users thanked this post: Andrew_Debbie, ars_ha3hz, LZ4TU
Offline vistorik
« Reply #773 on: October 09, 2021, 10:30:45 am »
Yes, 3102 shows b102. Initially b000. Calibration OK.
Offline DavidAlfa
« Reply #774 on: October 09, 2021, 11:08:09 am »
Yep. Clearly, there're 2 FPGA types.
Copied from my FAQ, these are equivalent:
»  2013_A013
»  2015_A015
»  3000_B000
»  3101_B101
»  3102_B102
»  3200_B200
»  3202_B202
The following users thanked this post: eevbstedt
