Also this requires more moderate knowledge as its not just enabling option keys and makes it not compatible with future updates without rework
I thought a bit over this phrase and....
You just have to flash the appropriate stock file! No need for further rework.
Your mileage may vary, i suspect so but not trying that one, i like to always have a backout plan
I'd assume you could just change the product type bits in the file and put out a new one
You just have to do a NAND backup of the equipment. With that you're safe.
Yes, but there is even no need for it because the app is already expecting the new Prod_ID! Poetry...
A few hours later, after a very stressful session!
.. and permanent telnet enabled
What are the Options RCV and RTA?
I think RCV is a double for EMI from what i've seen
RTA might be Real Time Analysis, not sure.. i havent chased them down yet
Remaining option_strings:
ALL licenses AMK + EMI + TG + DMA + AMA + CAT
NA licenses DTF + VNA
MA licenses AMA + DMA
I couldn't see any difference when those options were added, only significant change was when VNA was enabled, so any differences may have been hidden until then.
It's a bit off topic, but if tautech was really a nice guy, He would have bought each model from Siglent with detailed teardown.
I am a really nice guy
but like most, I too don't have unlimited funds.
Only on SDS5000X, if it turns out that now the front end is the same on the whole family, it would double sales of this model for Siglent
We'll know soon enough when member supperman gets a recent build SDS5034X and tests it to 1 GHz.
Still 3 unknowns: NA, MA and tALL
MA i think is the old form of AMA
Measurement vs Advanced Measurement
I just bought an SSA3021X Plus
Have you been going to your TEA sessions?
I don't have the level yet for that.
When I will buy new equipment without needing it and without reselling the old ones, I will register
I quit TEA therapy.. i need to get back on the bandwagon lol
Happily blissfully ignorant of TEA only one boat anchor and it will stay that way
Use virtually every piece of TE we have almost daily so no need to enter therapy
Take a look at what I just got at home waiting to bring him back to the lab with his friends
I just don't get it...
Is there something wrong with the SSA3021X Plus ??
(Yes, I just bought one. Now I'm nervous!)
Wrong for my wallet that's all. Don't be nervous
Hallo,
I own a SSA3021X Plus and I wondered what would happen if I just by mistake uploaded the SVA1032 firmware file. Would it work and would the telnet firmware upgrade file for the SSA3021X Plus stil work?
Just wondering.
Hallo,
Just wondering.
"Hallo"! You definitely can't do that by mistake! Nonetheless I have a feeling it will work. But that is one of the current open questions. Any volunteer?
Regarding the telnet FW: the SSA probably will not work, but the SVA one should work...
Hmm,
be assured I have no personal interests and I'm related in no way with the guys selling what I I'll suggest now.
Anyway, I'm pretty sure you will consider, at least for quality reasons, this calibration kits:
https://www.sdr-kits.net/Male-12GHz-KitThey are far better as most I've tested in the past as they are laser calibrated and characterised
one by one with top equipment.
They come for a fraction of buks to their usual commercial counterparts.
My personal experience is... best service, best quality.
That's it.
My 10 cents.
Andreas
Those are good parts, but they are not properly characterised.
But probably good enough for the low freq range of the vnwa based on what I remember of their analysis. And so could be usable for the 1.5GHz SVA. However, the load resistance they provide cant be used for a custom cal kit, but the offsets can.
