Poll
0-2000
7 (17.1%)
2k-4k
5 (12.2%)
4k-8k
15 (36.6%)
8k-16k
8 (19.5%)
6 (14.6%)
Total Members Voted: 38
Author Topic: Handheld meter robustness testing  (Read 1171123 times)
« Reply #2925 on: October 20, 2018, 10:18:50 pm »
I've actually got one of those. It's the "hamfest purchase testing meter". Will watch the video  :-+
Offline malagas_on_fire
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #2926 on: October 20, 2018, 11:57:18 pm »
Lost my bet on the little brymen, my aneng .. Very good for a pocket meter. brymen / amprobe would not let us down. at least didn't hang when battery is  low... Maybe was a bad batch that came to True
Those spark gaps really work. Ahhh 1 M Ohm :P
« Last Edit: October 21, 2018, 12:01:53 am by malagas_on_fire »
Online joeqsmithTopic starter
« Reply #2927 on: October 21, 2018, 12:04:45 am »
The Keysight meter I ran also used spark gaps (GDTs) and it did not do very well in my tests.
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #2928 on: October 27, 2018, 03:42:04 pm »
The Hioki DT 4252 also has a Gas Discharge Tube and performed really well, with added plastic near fuse holder to prevent arcing if i remember correct.
On the Amprobe It was funny to see GDT miniaturized and doing their job. Maybe they were properly tested before going to certification
« Reply #2929 on: October 27, 2018, 04:07:03 pm »
Yes, both that Hioki and the Gossen I have use GDTs and both did very well in my transient tests.    Then we have meters like the UNI-T UT181A that have a fair amount of circuitry including MOVs that fail with that gas grill starter.   The UNI-T is not a cheap meter and you would think that they would get it right but sadly they don't seem to have a good understanding on what it would take to harden a meter.    Odd as there are so many examples out there showing how.
Then again, there are even more examples of weak front ends out there.   Some expensive and some dirt cheap.  Take your pick.
My software for the 181A is in pretty good shape now and I plan to start putting together some sort of demo for it.
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #2930 on: October 27, 2018, 07:13:49 pm »
Well about cheap it depends on which scale / type of the meter fits. The uni-t 181A is very similar to the fluke 287.. and the 287 costs a lot more, it is sluggish on plotting but it meets more safety then. Now the Keysight is not much cheap compared to equivalent meters , lets say fluke 115 / 117, [Edit the poor english, sorry ], the hioki ,brymen BM257s and fails so less value for the money.
The uni-t 181A heavly modified, with the software in labview over bluetooth must be something unique since it hasn't got a program for PC.
Now a different question. Did you perform a transient test after a drop on the aneng's?
« Last Edit: October 27, 2018, 07:32:35 pm by malagas_on_fire »
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #2931 on: October 27, 2018, 09:57:46 pm »
From what I understood from your sequence of videos hardening the UT-61E, it seems to me that both MOVs and GDTs are too slow for the spark produced by the igniter, leaving only the fast transistors/diodes and the severe increase in the input series resistance as the only effective lines of defense.
Taking that into consideration, a choice must be made by the manufacturers given the added resistance has negative consequences for the bandwidth.
Am I missing something?
« Reply #2932 on: October 27, 2018, 10:02:39 pm »
I should have been more clear.  I was not inferring anything about the features, quality or value, only the cost.  For me, cheap is $50 USD and less.   I've stated numerous times that I had never paid more than $50 for a handheld before starting these tests.   These cheap meters were never used for anything beyond basic automotive use in the garage or if I needed something avoid risking my bench meters.  I have always considered them disposable.
That said, when I started running the first $50 meters it was clear that one company stood out, even at that level.
I would not say my UT181A is heavily modified, at least not compared with that KASUNTEST ZT102 or even that analog meter I tested.     Now if we were discussing that UT61E, that's heavily modified!   :-DD  Possibly the first handheld meter ever with an auto back light control.
If you go back and watch that video where I drop test the ANENG and the KASUNTEST, you will find both were damaged long before they were dropped.   I had put them back together to try to get a feel for how they would hold up.  I don't think I ever dropped a working one.
« Reply #2933 on: October 27, 2018, 10:12:17 pm »
Yes, you are missing something!!  You are correct in that the ESD, especially off that gun is VERY fast compared with the other transients I subject these meters to.  We are talking about 15Amps in about 800ps.    Compare that with rise times in the us.
I walked through the problem with the UT61E, showing the measurements I was making and how I made them and how I mitigated the ESD problem.   I did go on to change the design a bit as I continued to push the meter.
« Reply #2934 on: October 27, 2018, 10:38:52 pm »
Just a quick update on my problems with the BM867S. I tried the same set up again and the display was 100% stable this time. I have no explanation of what the issue is. I even set the bench out as close to what I remember I had it set up as and documented in my notebook. Power out was within 5% of original. Frequency spot on.
I will put this one down to quantum bogodynamics as my other half was in last time and isn't this time. She may have high bogon emissions.
Offline rsjsouza
  • Eternally curious
« Reply #2935 on: October 27, 2018, 11:18:04 pm »
Gremlins. Certainly Gremlins.
Offline rsjsouza
  • Eternally curious
« Reply #2936 on: October 27, 2018, 11:19:58 pm »
Uh... What exactly? The speed of the transient? I thought I had it covered on my post...
« Reply #2937 on: October 27, 2018, 11:47:44 pm »
What does the speed, or better yet, let's say the rise time have to do with it?   What was it on the 61E that was damaged and why?
« Reply #2938 on: October 28, 2018, 12:03:33 am »
When I was a kid in my teens, one of my hobbies was amature radio.  I really didn't know a whole lot about anything back then but I had fun calculating my dipoles, hanging them up and then trimming them to the lowest possible SWR.   Our TV set, my scope, signal generator and even my meter was tube based.  So was my radio equipment.  There was a plate load and tune to set the power amplifier.    If the amplifier was not tuned correctly, I would get notice in the mail from some other amature who had heard my call sign on some other band that I wasn't even operating in.   Then I learned what harmonics and distortion are.   :-DD   I think my scope was good to a MHz, if that.
Maybe your system was distorted enough that what you discovered is that the meter is actually sensitive in some other area.  Again, I swept the BM869s to 3GHz at 10V/meter and it was stable.  But you may have exceeded that by a fair amount.  If you run into it again and get a better idea of what is going on, just let me know and I can attempt to test it again over a wider frequency.
Offline Cliff Matthews
    • General Repair and Support
« Reply #2939 on: October 28, 2018, 01:57:45 am »
FWIW, there's a short but entertaining new BM839 review from Marco Reps showing-off ugly soldering on their mezzanine board.
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #2940 on: October 28, 2018, 12:49:17 pm »
Hello And thanks again for the clarification. For 50 "doll" mark it comes to the 101 or the Am510. I believe when you talked about the modifications about the ut61e you also mentioned the uni-t 181A and it sound  was more difficult on one of the videos :
https://youtu.be/cMutvk_6xhY?t=2541
The piezzo grill starter may have low energy but it is a ultra fast spike and the clamps must be prepared for it, if any...
My question about the drop is that my aneng has failed during monituring 230V AC isolated, due to droping from my TV stand to the floor (0.5m height) front facing which result in random mode changing / enter CAL mode when wake up from SEL button.
« Last Edit: October 28, 2018, 01:24:33 pm by malagas_on_fire »
« Reply #2941 on: October 28, 2018, 02:14:37 pm »
If we talk about the changes made to the PCB just for the sake of getting the UT181A and the UT61E to pass me ESD test, then yes there  was a lot more involved in 181A.  As I said in the video the UT61E required a single cut to the PCB was all (again, just for the ESD. NOT for all of the other modifications I made to the meter).  Your original post is not specific to ESD.  It's a general statement about the "heavly modified" UT181A which when compared with the UT61E, is not.
Yes, the gas grill starter is a fairly fast spike with very low energy compared with other transients that I expose these meters to.  I still have a hard time believing that it would damage ANY meter made today.
Your drop test does not explain that cracked transistor.  You may think it was random and had something to do with a calibration mode but I would put my money on the selector switch being in the wrong position and applying a high voltage.
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #2942 on: October 28, 2018, 10:23:12 pm »
The 100mV means 1A on the plot?
The drop was an accident. I was checking the voltage on a SBC (Small Board Computer ) connected to TV, i pulled the leads a little bit and then it dropped in the floorr. The front panel got a scratc but nothing special. I tested the multimeter and it seemed fine. But sometimes in Volt mode and Sleeping, when i press SEL to wake up, sometimes it would go crazy jumping modes on it's one or going to CAL mode. If i press the multimeter it would switch more frequently.
The randomness i was talking is about the modes it would switch and would hang on CAL mode.
Eventually i  still kept using on a AC project and assume that it would only be tripped when in sleep mode, but it behave bad while measuring the AC Volts, then turned off and never came back again. I can open further if there was any damage on the contacts from the rotary switch, but it was all the time in Volts mode.
« Last Edit: October 28, 2018, 10:50:52 pm by malagas_on_fire »
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #2943 on: October 28, 2018, 10:45:22 pm »
Here are some photos of the pads for the rotary switch with some sort of grease, also one trace in the middle is pretty scuffed. This is one year of use...
 Also the lens were scratch from the fall are available.
The spring contacs on the rotary switch are like brand new, without wear.
« Last Edit: October 28, 2018, 10:52:46 pm by malagas_on_fire »
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #2944 on: October 28, 2018, 10:53:13 pm »
The image of the rotary switch...
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #2945 on: October 29, 2018, 11:29:47 am »
Thanks for refreshing the memory. That pulse is hard to capture on current measurement.
The ESD gun looks more harmfull than piezzo grill starter since it approaches the IEC test and again uni-t 61e modified passed that test. Maybe uni-t has corrected that in newer DMM's.
However the Amprobe pm55a, which i bet that would fail on that test, it ran without issues and got beyond the 6kv. By the way did you managed to produced the bug reported by True after the video?
« Reply #2946 on: October 29, 2018, 04:43:05 pm »
I knew a guy who tried to measure the output of an ESD gun directly with a DSO.  It didn't work out so well.   :-DD The standards cover how to make the measurement.
I've yet to have a Brymen product perform poorly against my tests so seeing the pocket meter not having any problems with the newer low voltage generator was not much of a surprise.
I have continued to try other tests with the pocket meter but have yet to see a problem.  True talks about the low battery in all cases.  Maybe they installed LIRs to replace the CRs.   The manual clearly calls out CRs in numerous places but that doesn't mean that True followed the manual.   I don't know if the added voltage from an LIR could damage it or not.   The manual is just clear about what to use, not about what happens when you don't follow the instructions.   :-DD
Maybe one day they will post again and we can get a few more details about what happened with all four of their meters.
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #2947 on: October 29, 2018, 05:55:08 pm »
Wow nice detail on the battery , It's like installing lithium AA instead of the Alkaline or NIMH of this size, but the eevblog BM235 manual  calls out for that situation.
About my meter looks like one of my brothers use it to measure the voltage of the flyswatter and it said it was doing OL all the time and switched to other off position while the thing still on and leads plugged  :palm: . i. , before i ran the 230V ac test... I thought it was the fall but now i have the oportunity to offer one of my old meters, the uni-t 50b, teach more stuff. All bets are off for now.... :-DD
« Reply #2948 on: October 29, 2018, 10:27:57 pm »
I could try installing one and see if there are any long term effects.  If it damages the meter, it doesn't mean that's what happened with all four of True's meters.   It also doesn't mean there is anything wrong with the design.  I wouldn't expect to be able to use a different battery than the manufacture calls for without damage.
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #2949 on: October 30, 2018, 12:33:22 am »
Well there always the chance of flipping the polarity , but four in a row would be a bad play.  :-DD
