Two pieces of equipment turned-up yesterday:
Another F' ed-up arc welder: A Gys Spark 130.
Unbelievable how badly designed these things are: The control PCB is attached to the power IMS through tin soldered binding posts that also serve as electrical interconnect for the high currents.
Users bashing the welder around carelessly will tear the binding posts off the IMS, on this one the IMS is a complete wreck, I've phoned Gys who do replace them (themselves only) but won't sell me a spare. This is going to be quite challenging to repair.
A Metrix MX52 DMM, 35€ posted. Sold as untested.
Sure, when you can't read the display you can't really test the rest...
LCD display on initial test.
Not really readable.
Looking for battery corrosion under the foam.
Luckily this one is clean.
Checking rotary switch contacts with the endo-cam.
The early models were known for loosing the contact fingers.
One side...
And the other side, they are all in place.
They'll get a good spraying, just because a good spraying feels good.
Cleaning ze zebras.
Spraying the interconnect between main and display PCB with contact cleaner eases disassembly.
Re-checking the LCD.
Quick calibration check and readjustment where possible.
There is no easy adjustment for the Amps, needs to be tweaked by swapping resistors.
