Author Topic: What did you buy today? Post your latest purchase!  (Read 2855843 times)
Offline DrG
« Reply #10050 on: December 13, 2020, 01:00:33 am »
Only US$50
Need something to do while they count votes.
To follow up and in case anyone else is interested or thinking about android programming. I did get around to starting to play with this. It is pretty junky in the sense that it seems to be a 100% Google monstrosity (took 10 minutes to figure out where setup was to get to a screen for USB debugging).
I installed Android Studio and went through the tutorial here: https://developer.android.com/studio/write/layout-editor#intro I kept getting an error in the final app. I rebuilt it from scratch three times (which was actually a good learning experience) but still could not figure it out. I knew that a reference was off but I did not appreciate what an id is (I still may not). In this regard, I think the the tutorial is either outdated or unclear or wrong. Before building it a fourth time, I searched on the error and found this https://stackoverflow.com/questions/45377621/error-cannot-resolve-symbol-edittext-in-android-studio-myfirstapp-tutorial which was not a turnkey fix but was enough information to successfully complete and run the app.
I spent almost as much time getting a USB driver to run and work on an old Win7 box. Seems like I spin the same wheels every time eventually beating it into working.
The screen is nice. I have yet to root the machine but I only tried once (KingoRoot).
I never did anything with Android programming before so I can only say that if you want to get your feet wet, this worked for me. Not sure I even know enough yet to recommend Android Studio but it does work. Kotlin or Java - dunno, I went with Kotlin so far.
We'll see, next up (at least on the list) is to find some BLE devices.
« Last Edit: December 13, 2020, 01:09:42 am by DrG »
- Invest in science - it pays big dividends. -
The following users thanked this post: Ed.Kloonk, PlainName
Offline gamalot
  • Correct my English
    • Youtube
« Reply #10051 on: December 13, 2020, 04:14:21 am »
Olympus E-M10 Mark IV  :)
Offline Ed.Kloonk
  • Cat video aficionado
« Reply #10052 on: December 13, 2020, 04:29:26 am »
iratus parum formica
Offline TerraHertz
    • It's not really a Blog
« Reply #10053 on: December 13, 2020, 04:52:18 pm »
A pretty good test of whether the USA will have a general truckers strike or not. A couple of HP catalogs, recently departed from Forked River, NJ, on their way by road across the continent to LA.
They are the 1993 and 1996 editions. Gradually building my set. Currently:
Offline IDEngineer
« Reply #10054 on: December 13, 2020, 05:26:03 pm »
Those hardbound HP catalogs were my Christmas list every year as a kid. Santa never came through, sadly.
Offline Ed.Kloonk
« Reply #10055 on: December 13, 2020, 09:49:33 pm »
Should have waited for the following year to call out the drunken old fool. Chuck a tanty and punch him in the balls.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #10056 on: December 14, 2020, 04:41:55 am »
Ahh yes.  Crack catalogs.  May their travels be uneventful.
-Pat
Online Microcheap
« Reply #10057 on: December 14, 2020, 05:34:12 am »
I didn't pay attention and didn't followed the official links so I ended up with a cheap clone TinySA "Spertrum" Analyzer that won't pass self test and don't have the internal shielding. Maybe it was damaged by "static disqharge"  :palm:
And a somewhat better quality tool to make sure my beer is at the right temperature:
« Last Edit: December 14, 2020, 05:36:18 am by Microcheap »
Offline _Wim_
« Reply #10058 on: December 14, 2020, 09:21:42 pm »
Just search fiber laser engraver on YouTube, and I don't see many use this in an enclosure.
FYI, those are marketed in China for use in the open public, for engraving souvenirs on street side markets or tourist destinations.
Sounds scary, but so far no reports stating they have blinded anyone.
Again, I need to stress the fact that those lasers are NOT collimated. They use a technology called f-theta lens, which allows for large area engraving without losing focus.
Essentially, the more the light bends, the longer the focal length is, so effectively at the same vertical distance it is always in focus, regardless what the hypotenuse length is.
However, once the vertical distance changed, it goes out of focus very quickly.
Typically you get ~3mm of travel before the laser loses enough focus and loses capability to do any damage to even organic matters, and for metal engraving, ~1mm, and I will be at least 30cm from it when it runs.
Before the F-theta lens you have a collimated but expanded beam (expanded to protect the galvo mirrors from burning in due to the very high peak powers), and the F-theta lens refocusses the expanded beam exactly at the same height everywhere on the working area of the lens. Due to the very fine focus the peak power / area is enormous, which causes the material to vaporize.
If for example the beam before the f-theta lens has a diameter of 8mm, and the working distance of the F-theta lens is 200mm, then the reflected beam will have again a diameter of 8mm at 200mm reflected distance.  Remember these laser can generate pulses in excess of 10kW, which takes quite a distance for attenuation even if the beam is not very collimated. Laser safety glasses typically of an OD of >6 (attenuation of 1 million) for a good reason!
I can imagine as long as the engraved object is perfectly flat, this probably creates no major issues as the beam is reflected back towards f-theta lens. But if the marked object only slightly refocuses the reflected beam is your direction, I cannot imagine safety is always guaranteed.
Apart from videos on youtube, I have never come across one in industry without a safety cage. Agreed, I have not seen hundreds of laser marking machines in my job, but I have come across at least 25 of many different brands. That why I asked if you are aware of any datasheet from a reputable company that states one of their products can be used without a safety cage.
I would still recommend to be careful, and to use a good quality pair of laser safety glasses for you and anyone nearby.
« Last Edit: December 14, 2020, 09:23:55 pm by _Wim_ »
The following users thanked this post: blueskull, jogri
Offline DrG
« Reply #10059 on: December 15, 2020, 12:18:41 am »
I looked into that as a result of your post. I looked into the genuine TinySA (genuine spelling of spectrum). It's only US$50! This, right? http://www.randl.com/shop/catalog/product_info.php?products_id=75243&osCsid=ha9cd162ojp4v041la6a18bv47
Very cool. I am thinking about it as a holiday gift...for myself...not that I really have a need for one, but still..:)
Offline Ground_Loop
« Reply #10060 on: December 15, 2020, 01:30:14 am »
Got my hands on a fine Starrett tap handle. 1132246-0
There's no point getting old if you don't have stories.
Offline rfclown
« Reply #10061 on: December 15, 2020, 03:46:27 am »
Hard to resist the cheap Chinese stuff. I've got an decent HP counter, but with a crap reference, so I use an external ref. Wanted a second counter for my day job (since my employer has only one counter for many engineers, and no good reference). I was going to build one, but saw this on eBay, and it wasn't worth the time making a better one. The reference alone in this thing is something I get $25 bucks for on eBay, and the counter was $130 shipped from US. It's a BG7TBL FA-2. As received the internal reference was only 0.11 Hz different than one of my rubidiums. Tweeked the adjustment pot to bring it closer.
« Last Edit: December 15, 2020, 03:50:51 am by rfclown »
Offline Gary350z
« Reply #10062 on: December 15, 2020, 12:51:23 pm »
HHIP 4401-1597 Granite Surface Plate for checking flat things. $41 from amazon with free shipping.
Not top of the line, but good enough for me.
Offline Syntax Error
« Reply #10063 on: December 15, 2020, 09:10:15 pm »
Paint the Whole World with a RAINBOW DIP Switch. Or two.
Part No: ERG_SDS-8-023
The following users thanked this post: Ed.Kloonk, mnementh
Offline I wanted a rude username
  • ... but this username is also acceptable.
« Reply #10064 on: December 16, 2020, 03:19:23 am »
Love the fact that the colours match up (presumably intentionally) with those of a standard rainbow ribbon cable.
Offline Ed.Kloonk
« Reply #10065 on: December 16, 2020, 03:44:50 am »
If birds fly...
Offline IDEngineer
« Reply #10066 on: December 16, 2020, 04:56:59 am »
Wow, that's actually a great deal if the accuracy is as claimed. I might have to get a stronger Christmas stocking.
Offline Calambres
    • Piso-Tones
« Reply #10067 on: December 16, 2020, 10:55:07 am »
Just ordered this beauty:
An RPN queen for sure!
The following users thanked this post: TerraHertz, BU508A, bd139
Offline richnormand
« Reply #10068 on: December 16, 2020, 07:16:17 pm »
@Calambres
Drooling...... and envy :)
Still using my HP33E on the bench so I should not complain too much.
RPN rules.
Too bad most engineering graduates I meet have no idea. On the other hand, my calculator does tend to stay on my desk and they are stunned I finish a calc sooner than they do.
My SO has to one with the magnetic cards and that still works too.
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
Offline IDEngineer
« Reply #10069 on: December 16, 2020, 08:47:53 pm »
RPN for the win! I have three HP10 series calculators on my desk, my wife uses 12C's exclusively, and I think I still have my original HP35 and HP55 in a box somewhere.
EDIT: Almost forgot the HP11 emulator on my OnePlus cellphone, too.
Someone once asked to borrow one of my HP calculators. I waited for the inevitable "Where's the equal sign?", then told them it was in the battery compartment. Being one of the original series, its triple-NiCd pack fell right out... depowering the calculator... yet they still searched in the compartment for the equals key. :palm:
RPN everywhere, all the time. Accept no substitutes.
« Last Edit: December 16, 2020, 11:11:44 pm by IDEngineer »
Offline Mr.B
« Reply #10070 on: December 16, 2020, 08:49:29 pm »
The following users thanked this post: kripton2035, Tom45
Offline Gary350z
« Reply #10071 on: December 16, 2020, 09:41:37 pm »
With amazon you get free shipping and FREE RETURN SHIPPING so you can't go wrong.
...and your wife says you got a rock in your Christmas stocking. ;D
Offline Gary350z
« Reply #10072 on: December 16, 2020, 10:26:22 pm »
tinySA spectrum analyzer for $50
I ordered it today from Aliexpress.
Frequency range from 100kHz to 350MHz
Be aware it is small (screen diagonal 2.8"), and has limitations.
Information:
https://tinysa.org/wiki/pmwiki.php?n=Main.HomePage
Only buy from official stores to avoid clones:
https://tinysa.org/wiki/pmwiki.php?n=Main.Buying
« Last Edit: December 16, 2020, 10:35:54 pm by Gary350z »
Offline IDEngineer
« Reply #10073 on: December 16, 2020, 11:08:35 pm »
I could argue that a Granite Surface Plate IS a rock in my Christmas stocking!  :-DD
Offline coppercone2
« Reply #10074 on: December 17, 2020, 08:25:53 am »
yea put some 4000$ pink granite parallels in the stockings from starrett
I got a 4 inch thick pink starrett one could make a good valentines gift or something
I would try but I think the weight limit is like 100lb.
I do think that since I have had it the molding in the house looks off and it slightly annoys me.
the pink is supposed to be a better surface that does not stick so much IIRC.
« Last Edit: December 17, 2020, 08:33:36 am by coppercone2 »
