Hi!
instead of a global 'Down to stack' parameter, please introduce a different one for each stack. At least for the IC-stacks this is mandatory.
Parameter 'Down to ... ' for the IC-trays is 'Down To Front' (see in attachment), it can be configured separately from the feeders
It would be absolutely great if we could use camera 2 to calibrate the feeders.
But the camera2 can be used to configure feeders. For this, there is a "Vision" switch and a "Vision MoveTo" button (see attachment).
In general, setting up feeders is a fairly simple process when you begin to understand its principle. But it takes quite some time for all positions.
At least in my particular machine there is a strange bug: If I use the manual controls to move down nozzle 2, when it reaches the limit it is not stopped by software. Rather (the belt) slips and both nozzle 1 and 2 position will be wrong. Only a complete shutdown of the machine fixes this
This is a lack of hardware - there is only a sensor for the upper position of both nozzles, but there are no sensors for the lower position. However, it is unclear why this sensor does not work when the nozzle is raised after the nozzle's normal position has been disturbed.
My software version is 3.11, machine is TVM802BX.
