Author Topic: WinGPIB - Windows GPIB App (multi-purpose)  (Read 180954 times)
Offline IanJTopic starter
  • Country: scotland
  • Full time EE & Youtuber
    • IanJohnston.com
Re: WinGPIB - Windows GPIB App (multi-purpose)
« Reply #725 on: April 15, 2024, 08:02:05 pm »
Hey Ian,
I grabbed your updated version and installed it on the Beelink S12 Mini that I just bought specifically to run WinGPIB etc next to my kit and I'm still getting the issue with it not finding the DLL. The interesting thing is that I just dropped the DLL into the WinGPIB directory on my desktop machine and it works fine.
So I have, what appear to be, 2 identical installs on different machines and yet WinGPIB can find the DLL on one device and not the other.
Any ideas?
TonyG
Which .DLL.......could be one of two.....and where are you placing the file?
Ian.
« Last Edit: April 15, 2024, 08:04:40 pm by IanJ »
Ian Johnston - Original designer of the PDVS2mini || Author of the free WinGPIB app.
Website - www.ianjohnston.com
YT Channel (electronics repairs & projects): www.youtube.com/user/IanScottJohnston, Twitter (X): https://twitter.com/IanSJohnston
Online Tony_G
  • Checkout my old test gear channel (link in sig)
    • TGSoapbox
« Reply #726 on: April 15, 2024, 09:45:12 pm »
Hey Ian,
I believe that it is still the Microchip DLL causing the problem.
To make sure, I just flattened the Beelink machine, reinstalled Win 11 Pro 23H2, installed NI 488.2 and VISA packages and then installed the new V3_161 package that you posted.
The app throws the same exception:
Log Name:      Application
Source:        .NET Runtime
Date:          4/15/2024 2:35:34 PM
Event ID:      1026
Task Category: None
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      TG-BEELINK
Description:
Application: WinGPIB.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileNotFoundException
   at PDVS2_GPIB.Formtest..ctor()
Exception Info: System.InvalidOperationException
   at PDVS2_GPIB.My.MyProject+MyForms.Create__Instance__[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]](System.__Canon)
   at PDVS2_GPIB.My.MyApplication.OnCreateMainForm()
   at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun()
   at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
   at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(System.String[])
   at PDVS2_GPIB.My.MyApplication.Main(System.String[])
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name=".NET Runtime" />
    <EventID Qualifiers="0">1026</EventID>
    <Version>0</Version>
    <Level>2</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2024-04-15T21:35:34.3226693Z" />
    <EventRecordID>2921</EventRecordID>
    <Correlation />
    <Execution ProcessID="13044" ThreadID="0" />
    <Channel>Application</Channel>
    <Computer>TG-BEELINK</Computer>
    <Security />
  </System>
  <EventData>
    <Data>Application: WinGPIB.exe
</Data>
  </EventData>
</Event>
I'm in the process of reinstalling VS so that I can put it under debugger to confirm the DLL it is looking for.
TonyG
Online Tony_G
    • TGSoapbox
« Reply #727 on: April 15, 2024, 10:40:23 pm »
Here is the exception from inside the VS Debugger:
  HResult=0x80131509
  Message=An error occurred creating the form. See Exception.InnerException for details.  The error is: Could not load file or assembly 'MCP2221DLL-M-dotNet4.dll' or one of its dependencies. The specified module could not be found.
  Source=WinGPIB
  StackTrace:
   at PDVS2_GPIB.My.MyProject.MyForms.Create__Instance__[T](T Instance) in PDVS2_GPIB.My\MyProject.cs:line 218
   at PDVS2_GPIB.My.MyApplication.OnCreateMainForm() in PDVS2_GPIB.My\MyApplication.cs:line 39
   at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[] commandLine)
   at PDVS2_GPIB.My.MyApplication.Main(String[] Args) in PDVS2_GPIB.My\MyApplication.cs:line 22
  This exception was originally thrown at this call stack:
Inner Exception 1:
FileNotFoundException: Could not load file or assembly 'MCP2221DLL-M-dotNet4.dll' or one of its dependencies. The specified module could not be found.
You can see that it is looking for "MCP2221DLL-M-dotNet4.dll" and here is the directory listing:
C:\Program Files (x86)\IanJ\WinGPIB>DIR
 Volume in drive C has no label.
 Volume Serial Number is 2644-9FDF
 Directory of C:\Program Files (x86)\IanJ\WinGPIB
04/15/2024  03:15 PM    <DIR>          .
04/15/2024  02:35 PM    <DIR>          ..
07/26/2023  11:24 AM            14,707 GPIBchannels.txt
04/25/2023  02:49 PM            60,416 IODevice.dll
05/21/2019  11:58 AM                 0 Log.csv
06/17/2015  02:20 PM            84,992 MCP2221DLL-M-dotNet4.dll
02/04/2024  12:46 PM            63,303 PDVS2_GPIB.exe.config
02/14/2024  03:24 PM           788,480 WinGPIB.exe
01/02/2022  11:33 AM            27,198 WinGPIB.ico
               7 File(s)      1,039,096 bytes
               2 Dir(s)  423,794,827,264 bytes free
So the DLL should be in the search path for a Windows EXE - I'm a bit at a loss for why it fails on this machine but works on my desktop - I could provide Fusion logs but I don't think they're particularly helpful in this case (though I could be missing something)
I think the best way for me to try and debug is via building the solution on this machine - PM Sent for latest source.
TonyG
« Last Edit: April 15, 2024, 10:58:57 pm by Tony_G »
  • Country: scotland
    • IanJohnston.com
« Reply #728 on: April 16, 2024, 06:58:18 am »
Send me an email and I will reply with the source.
PS. I use a separate installer (not VS’s own) to build the .MSI, far easier and better than Microsoft’s effort.
Possible:
1. What .NET Framework version is loaded on the PC? WinGPIB is optimized for 4.X
2. OS version?
3. Environment Labels on PC somehow causing an issue.
4. Antivirus/Firewall.
5. I only have Keysight’s drivers loaded, no other.
Over the years there has been the odd random user who has had installation issues……have usually been able to track it down.
Ian
  • Country: scotland
    • IanJohnston.com
« Reply #729 on: April 16, 2024, 08:25:48 pm »
Hi all,
Been playing with WInGPIB and my Rigol DHO914 Oscilloscope to see if it responds to GPIB commands, which it does.
Uncheck "Enable Polling", all rest as default.
Address = TCPIP::192.168.1.205::inst0::INSTR
Sending config/setup commands (SEND ASYNC):
:CHANnel1:DISPlay OFF      Turn channel 1 off
:CHANnel1:DISPlay ON      Turn channel 1 on
:CHANnel1:SCALe 0.1      Sets the vertical scale of Ch.1 to 0.1 V/div
:CHANnel1:COUPling AC      Sets the coupling mode of Ch.1 to AC
Reading back data (QUERY ASYNC):
:MEASure:STATistic:ITEM? AVERages,VPP,CHANnel1      Queries the average value of Ch.1 peak to peak.
:TRIGger:STATus?               Query the current trigger status, i.e. AUTO will be returned, albeit due to text var it will be displayed in box…….i’ll fix this at next WinGPIB update.
See the DHO800/DHO900 Programming Guide for much more.
Ian.
« Last Edit: April 16, 2024, 10:01:43 pm by IanJ »
  • Country: scotland
    • IanJohnston.com
« Reply #730 on: April 17, 2024, 10:36:14 am »
New version in Post #1 available for download.
WinGPIB_V3_162_full.zip - Fresh install
WinGPIB_V3_162_updated_exe.zip - Updated exe to replace existing
[Virus scanned using BitDefender AntiVirus]
New checkbox added to allow text/non-numerical responses from the device.
This mode is generally for use with the QUERY ASYNC button and the checkbox status is not stored in the profiles as it's really only during testing/setup etc you might want to use such a mode.
In the example below I queried my DHO914 Oscilloscope to find out what mode the trigger was in, the response was "AUTO".
Ian.
« Last Edit: April 17, 2024, 10:38:44 am by IanJ »
Offline Rax
« Reply #731 on: April 18, 2024, 11:52:35 pm »
I've been trying to install this and getting stuck at the same step every time (this usually takes place months apart). I run the msi and there's no prgram anywhere on the x86 or the other Program Files folder.
Also, I'm not sure what I need to do with the "Version 3.143 and over requires MCP2221DLL-M-dotNet4.zip which is available in the downloads if you are updating." There's a dll in that zip, and just stating "it's required" gives no indication where the dll needs to be dropped.
This is on a Windows 10 Pro system.
Thank you very much for assisting with this.
Offline coromonadalix
« Reply #732 on: April 19, 2024, 12:33:47 am »
drop the dll in the same folder as wingpib once installed and see if it works ... see answer #727 ??
The  MCP2221 is an USB/I2C bridge .... it must be the scope interface ??   i don't know theses models
some link talking of it  and a setup  who should install it ??
http://www.emar.cz/sw/USB-I2Cman.htm
« Last Edit: April 19, 2024, 12:43:15 am by coromonadalix »
The following users thanked this post: Rax
  • Country: scotland
    • IanJohnston.com
« Reply #733 on: April 19, 2024, 08:34:41 am »
There was a small mistake in POST #1 about the path where WinGPIB is installed. It should read:
C:\Program Files (x86)\IanJ\WinGPIB\
After installation a shortcut is copied to your desktop, but failing that you run WinGPIB.exe to start the app.
The MSI installs both the required .DLL files, you only need to manually place the DLL is you are updating an old WinGPIB installation manually, i.e.
Download MCP2221DLL-M-dotNet4.zip and unzip the .DLL from the file then place it in the WinGPIB installation folder, which is usually:
or
C:\Program Files (x86)\WinGPIB\
.....depending on the age of the original version you are running.
If after full installation you have no such program folder then the install may have failed for you.......did you get an error message?
Ian.
  • Country: scotland
    • IanJohnston.com
« Reply #734 on: April 19, 2024, 11:07:15 am »
WinGPIB_V3_163_full.zip WinGPIB_V3_164_full.zip - Fresh install
WinGPIB_V3_163_updated_exe.zip WinGPIB_V3_164_updated_exe.zip - Updated exe to replace existing
Nothing new added, but a lot of bug fixes, tweaks and changes, as such I have left version 3.62 in Post #1.
PLAYBACK CHART:
- Now more reliably sets the X-scale when opening CSV's, it was buggy depending on data and single versus dual device running.
- There was a bug on the X-scale when opening CSV's which had been logged using a time base of less than 1sec.
DATA LOG/CSV:
- Now you must make your filename, Enable CSV status before hitting RUN on the main Device tab, this is because writing the MetaData for the CSV was unreliable if GPIB Device was already running.
- The Metadata now only appears at the start of the CSV.
- CSV Metadata is now 3 lines of text max only.
- Removed the Export CSV button temporarily for similar reason, doubt it was used much and it just got in the way of other code.
- Added various interlocks related to CSV file contents reset, Enable CSV checkbox etc.
Any issues with 3.164 then let me know here or via PM.
Can't believe I first started developing WinGPIB over 6 years ago!
Ian.
« Last Edit: April 19, 2024, 02:05:30 pm by IanJ »
Offline Rax
« Reply #735 on: April 19, 2024, 02:45:10 pm »
Ian.
Ian,
I got it to work - thanks!
Now I'm trying to connect my instruments:
  • Prema 6048 over GPIB (one of xyphro's USBGPIB, which currently works very well with a little custom py)
  • HP 34401A over RS232 (which also works well with TestController)
I am not sure RS232 is really supported - this being a GPIB program - but I found some posts in this thread that seem to indicate it's possible.
The other potential difficulty is that when I setup the Python environment for GBPIB comms with the Prema, I used the R&S libraries, not Keysight's. Would that be a dealbreaker? I couldn't find any mentions in the thread regarding whether R&S libraries work.
  • Country: scotland
    • IanJohnston.com
« Reply #736 on: April 19, 2024, 05:42:48 pm »
Rax,
In WinGPIB press the NOTEPAD GPIBchannels button and it will open a text document with lots of hints, tips & examples for using WinGPIB.
The idea is you can edit that text document with your own tips......but for a kick-off it's all stuff I have gleaned.
R&S is using VISA which is a generic standard adopted by many manufacturers, so you can use it.
You can of course also use RS232 if you want instead of VISA, there are examples in the text document for that.
Ian.
« Last Edit: April 20, 2024, 03:43:19 am by IanJ »
  • Country: scotland
    • IanJohnston.com
« Reply #737 on: April 20, 2024, 10:31:06 am »
WinGPIB_V3_165_full.zip - Fresh install
WinGPIB_V3_165_updated_exe.zip - Updated exe to replace existing
Fixed bug in PlayBack Chart, the X-Axis scale labels were displaying as integers rather than floating point numbers.
Have also lowered the minimum length CSV file to 40 lines (was 160).
Ian.
« Last Edit: April 20, 2024, 10:52:11 am by IanJ »
  • Country: scotland
    • IanJohnston.com
« Reply #738 on: April 20, 2024, 01:40:01 pm »
WinGPIB_V3_166_full.zip - Fresh install
WinGPIB_V3_166_updated_exe.zip - Updated exe to replace existing
Small fix to the PlayBack Chart, the far right hand X-Scale label below the chart is sometimes missing.
I found a fix, but not entirely sure why the problem exists in the first place (thanks MS for the dodgy MS Chart system!).......so have left V3.165 in downloads for now....just incase.
Seems to work fine anyways.
Ian.
« Last Edit: April 20, 2024, 01:42:10 pm by IanJ »
  • Country: scotland
    • IanJohnston.com
« Reply #739 on: April 20, 2024, 05:38:19 pm »
WinGPIB_V3_167_full.zip - Fresh install
WinGPIB_V3_167_updated_exe.zip - Updated exe to replace existing
Small GUI fixes & cleanups on various tabs.
Add extra checks when loading the CSV file into the Playback Chart - check for empty lines and consistency of the data.
Ian.
The following users thanked this post: coromonadalix
Online Tony_G
    • TGSoapbox
« Reply #740 on: April 20, 2024, 07:56:01 pm »
Hey Ian,
I found the issue so I thought I'd share it just in case this ever comes up again.
The MCP2221 Assembly has a dependency itself on the VC++ 2010 Runtime - No idea why the exception wasn't showing the redist file(s) instead of the MCP DLL but installing the VC++ 2010 Redist solved the issue and WinGPIB now runs on that machine.
Thanks for a great app.
TonyG
« Reply #741 on: April 20, 2024, 08:00:59 pm »
you have an all in one package here,  a life saver for me and many apps
https://www.techpowerup.com/download/visual-c-redistributable-runtime-package-all-in-one/
  • Country: scotland
    • IanJohnston.com
« Reply #742 on: April 20, 2024, 08:36:32 pm »
Hey Ian,
TonyG
Thanks, I’ll put it in the installation notes in post #1 for future reference.
Ian
  • Country: scotland
    • IanJohnston.com
« Reply #743 on: April 21, 2024, 09:28:00 am »
WinGPIB_V3_168_full.zip - Fresh install
WinGPIB_V3_168_updated_exe.zip - Updated exe to replace existing
Bug fix on Device 2, an issue with the Max. No. DP's fixed. Thanks to AHOL for reporting this.
Also, I have updated the installation notes in Post #1 with some info regarding the MCP2221DLL-M-dotNet4 DLL that is installed with WinGPIB for the MCP2221A/SHT40,41,45 temp sensor functionality. Depending on your Windows installation you may need to install an update to allow WinGPIB to work. Thanks to Tony_G for finding this one.
Ian.
« Last Edit: April 21, 2024, 11:16:47 am by IanJ »
The following users thanked this post: Tony_G, AHOL
  • Country: scotland
    • IanJohnston.com
« Reply #744 on: April 21, 2024, 12:48:16 pm »
WinGPIB_V3_169_full.zip - Fresh install
WinGPIB_V3_169_updated_exe.zip - Updated exe to replace existing
Need help installing, upgrading or moving to a new PC, then see instructions in Post #1
Just a tidy up of the Playback Chart VB code......no real changes.....it was a bit of a mess in terms of readability. Hmmm, it still is....but it's a bit better now.
Ian.
« Last Edit: April 21, 2024, 02:21:59 pm by IanJ »
  • Country: scotland
    • IanJohnston.com
« Reply #745 on: April 21, 2024, 04:50:59 pm »
WinGPIB_V3_170_full.zip - Fresh install
WinGPIB_V3_170_updated_exe.zip - Updated exe to replace existing
Further tidy up:
Desktop shortcut gets a proper icon graphic.
Windows Control Panel Add/Remove Programs entry gets a proper icon graphic.
Completely fresh installs (no existing WinGPIBdata folder) gets the latest GPIBchannels.txt file.
PS. Next on my agenda is to allow the installation .msi file to be able to upgrade an existing installation without having to remove the existing one or to manually replace the .exe, nor will overwrite the data folder.
Ian.
« Last Edit: April 22, 2024, 01:35:41 pm by IanJ »
Online Tony_G
    • TGSoapbox
« Reply #746 on: April 22, 2024, 03:37:48 pm »
Yay - Windows Defender deletion for "Trojan:Win32/Wacatac.B!ml"
TonyG
  • Country: scotland
    • IanJohnston.com
« Reply #747 on: April 22, 2024, 03:45:17 pm »
TonyG
I'll report it......Must be about the 5th false positive in all these years.
Ian.
  • Country: scotland
    • IanJohnston.com
« Reply #748 on: April 22, 2024, 03:59:09 pm »
WinGPIB_V3_171.zip
One .msi installer file now allows fresh installations or upgrades. No need to manually copy the .exe now.
When upgrading it will not overwrite the files in your data folder, C:\Users\[username]\Documents\WinGPIBdata
Ian.
« Last Edit: April 23, 2024, 08:01:00 pm by IanJ »
The following users thanked this post: croma641
  • Country: scotland
    • IanJohnston.com
« Reply #749 on: April 23, 2024, 02:19:02 am »
TonyG
As thought, confirmed as a false positive. Microsoft’s response in full below:
wingpib.exe
Submission ID: aa5bd3c2-2236-4994-ac11-1ab33389e026
Status: Completed
Submitted: Apr 22, 2024 17:07:53
User Opinion: Incorrect detection
Analyst comments:
At this time, the submitted files do not meet our criteria for malware or potentially unwanted applications. The detection has been removed.
Please follow the steps below to clear cached detections and obtain the latest malware definitions.
1. Open command prompt as administrator and change directory to c:\Program Files\Windows Defender
2. Run “MpCmdRun.exe -removedefinitions -dynamicsignatures”
3. Run "MpCmdRun.exe -SignatureUpdate"
Alternatively, the latest definition is available for download here: https://docs.microsoft.com/microsoft-365/security/defender-endpoint/manage-updates-baselines-microsoft-de
« Last Edit: April 23, 2024, 06:40:50 am by IanJ »
