Just having a play with this app here.
I have two questions..
Is there a way to change the directory that the cal dump for the 3457A is saved to?
I have 'My Documents' on my D drive and I get an Unhandled Exception until I manually made the required folders on my C drive.
Could not find a part of the path "C:\Users\XXXX\Documents\WinGPIBdata\3457ACalram_date_time.bin"
Also, how does one determine what addresses to copy for a particular instrument? Is there an easy way to determine if I have an early or late type instrument?
I have updated WinGPIB, see the download in Post #1 with a new version V3.174
This version doesn't not discriminate between C: and D: drives etc.
I have NOT tested the installation .msi file so please let me know how you get on.
I the event your D: drive \WinGPIBdata folder isn't created at installation then manually create it, then run the .exe
The .exe runs on my system and finds the C: drive WinGPIBdata folder as normal, so I know my non-discriminatory code is working.
To get the address of your instrument say you are using the Keysight libraries then run the Keysight Connection Expert and scan for instruments and it should appear.
Note that certainly under the Keysight libraries you can setup aliases etc so the exact address folks use can vary, as well as depending on what or how many GPIB gateways are in use.
The detection of addresses is not within the scope of WinGPIB.
Ian.
