@GigaJoe:
Simulation with ADR1399 and AD706 and HP schematics:
RMS noise in nV at +REF10, R=47k, C=3u3
0.1Hz-10Hz 0.1Hz-10kHz
no RC 326 5451
R only 349 5240
RC 188 982I've also tried to block +5REF (powers the entire MCU_ADC module, btw.) and the FLASH ADC_MCU input (fed by 1k off the AD711). Soldered directly at the MCU pins, against ANGND (in schematics wired together with VSS).
The FLASH blocked by 82p C0G, it messed up the reading - tens of uVolts randomly jumping.
The 100nF ceramics at +5REF dropped by aprox 1ppm, and increased a little bit the STD.
The 4n7 foil at +5REF with no drop visible, and STD under investigation, next morning we will see..
The lowest STD was with none capacitor at +5REF.
Could it be the U401-B AD706 is somehow unstable with such large capacitive loads??
The load in original schematics is 100ohm/100nF at +5REF and in parallel 46ohm/100nF at 4053.
@Frank: Way back I replaced the HP399 with one of my lowest noise LM399 and the noise decrease was visible. The issue with that LM399 was it popped couple of times per day (nice 5uV jumps).
PS: nVolts in the above table, of course..
