@Wombat:
what on the device screen ? "buffer overflow" or "----------- " like no data ?
you have a ADC , old type - 1 opamp, 2nd newer - 2 opamps , witch one toast ?
" could look at the integrator output." - opamp otput pin, should be triangular wave approx +3v from ground as median.
Thanks GigaJoe it just stays on "----------" If i press Auto the auto indicator turns off and then nothing further.
If a random button is held on power up you get a different random upper key function and nothing else.
Funny I didnt even notice as it went back in after the photos, it is the single op amp version that is sick.
Yes I probed the OPA602 output and it sits at about 8.6V with a bit of a pulse coming out.
Its input was just a minor ripple so something is up here.
Pulled C825 and get a constant 16-17mV over a 10M resistor across the voltage range so seems leaky.
With it out I can see a good positive to negative transition here.
I do not have anything good enough on hand for C825 so placed an order including a lot of the OP Amps you guys mentioned.
Want to avoid doing anything to the working ADC so not pulling parts from it.
I have worked my way across the circuit from the left and as far as I can tell all the references and CB logic switching are ok.
The LM339 reference is good and the lower first 2 (a&b) check out however I am sus on it so will replace it.
There is no activity from CBCOMP or ZCOMP
Not much happening on the NE5534 output
The center fet switching circuit has done my head in a bit and do not quite understand it but still sus on the other fets I haven't tested.
I do not want to just replace heaps of stuff as some has been specifically selected.
Is there a circuit for the single op amp version by chance?
