Author Topic: Another DSO+DMM - Zeeweii DSO3D12, claimed 120MHz/250MSps (june 2023)  (Read 150097 times)
Offline BillyO
Re: Another DSO+DMM - Zeeweii DSO3D12, claimed 120MHz/250MSps (june 2023)
« Reply #75 on: March 26, 2024, 02:18:10 am »
The SMA connector is designed for at least 12GHz and  50 Ω impedance, so should be OK for this application.
Did you verify that the generator output is 50 ohms?
Bill
Offline Dave_g8
« Reply #76 on: March 29, 2024, 10:04:24 am »
Hi Bill,
I don’t have a DSO3D12, but the AWG output circuit is probably similar to that on the other models.
The DSO154Pro output circuit appears to be as shown below. The nominal output impedance will be closer to 150Ω, this may have been chosen to provide some level of short circuit protection for the driver.
2088503-0
« Last Edit: March 30, 2024, 07:14:34 am by Dave_g8 »
The following users thanked this post: BillyO
Offline Dave_g8
« Reply #77 on: March 29, 2024, 10:05:46 am »
Interesting, there is a recent firmware upgrade for the DSO3D12 which adds a frequency meter and pulse counter.
This appears to be a similar specification to the feature found on the DSO154Pro (HW V1.4). The DSO3D12 seems to have a higher upper frequency limit.
It may be that the feature on the DSO154Pro is also HW/FW dependant, since this seems to be the case for the DSO3D12.
2088509-0
A thread describing the DSO154Pro frequency meter and counter is shown below.
https://www.eevblog.com/forum/testgear/new-toy()-scope-dso154pro-1ch-claimed-40mss/msg5418215/#msg5418215
« Last Edit: March 29, 2024, 10:12:15 am by Dave_g8 »
The following users thanked this post: BillyO, motoge
Offline jarpo
« Reply #78 on: April 04, 2024, 12:51:19 am »
(Attachment Link)
Do you know if this new firmware is also available for hardware version V1.1 and firmware version v1.1.2? ZEEWEII appears to say that it has recently upgraded the DSO3D12 hardware, but does not provide any further information on its website.
Offline Dave_g8
« Reply #79 on: April 04, 2024, 06:53:02 am »
Sorry, I don’t have any further information. The screenshot in the previous message is from one of the files in the firmware download when you click the icon on the website.
Perhaps ask the question via the “contact us” page.
Offline BillyO
« Reply #80 on: April 22, 2024, 06:06:57 pm »
If your current FW version is 3.0.0_III or 3.0.1_III then you have the correct HW version for the new FW.
Bill
Offline BillyO
« Reply #81 on: April 27, 2024, 01:02:24 am »
I just discovered an undocumented feature on this little instrument.
If you go in into the FG via the "Gen" button, you are limited to 5MHz on sine wave, as per the specifications.  However if you go into the full-screen FG via the "Home"   menu (short press the power button) you can get the sine function at 10MHz!!  :-+ :-+
This is with the latest firmware.
I have also verified the new frequency counter is good from 15Hz to 35MHz - well beyond specification.
« Last Edit: April 30, 2024, 07:29:21 pm by BillyO »
Bill
The following users thanked this post: jebem
Offline tunkTopic starter
  • Country: no
Offline wasedadoc
« Reply #83 on: April 30, 2024, 09:13:34 pm »
That undocumented feature is not confined to the latest firmware.  Also present in mine which does not have the frequency counter.
Offline big t
How to check what is my current FW version?
Offline BillyO
From their website which can be found with a simple google search for "Zeeweii" and two clicks of the mouse you get:
Check version: Menu->DMM,and then long press "V(ch1)" button.
 |O
Bill
Offline Evi
  • Country: ru
Did anybody perform successful FW upgrade
Offline Evi
  • Country: ru
Successfully performed brick/unbrick sequence on v1.1.2 with the kind help from Zeeweii support. FW attached.
New Upgrade_Tools_V1.5.8
http://www.isme.fun/?log=blog&id=34
« Last Edit: May 22, 2024, 11:39:16 am by Evi »
The following users thanked this post: Aldo22, asin, valeok
Offline asin
  • Country: by
« Reply #88 on: June 06, 2024, 09:27:36 am »
Has anything changed after the firmware? And were there any pitfalls in the firmware? Thanks!
Offline valeok
  • Country: by
« Reply #89 on: June 22, 2024, 06:29:49 pm »
Прошил dso3d12 3 версией ,получил кирпич.была версия 1.1.2 |O
Offline BillyO
« Reply #90 on: June 22, 2024, 10:04:20 pm »
:palm:
The Zeeweii website says:
If your version is v3.0.0_III/v3.0.1_III, you can upgrade to v3.0.2_III stable version. And for older versions, this firmware is not compatible due to hardware differences.
That's pretty clear.  What were you expecting? :-//
Bill
The following users thanked this post: valeok
Offline Cricri
  • Country: aq
« Reply #91 on: August 05, 2024, 09:59:30 pm »
Quote from: BillyO
I have the same problem and I think his expectation was the same as mine: ordered in 2024 and not too chuffed with being sent old stock model, especially when it locks us out of improved firmware updates. Ordered mine straight from Zeewei Taobao's shop so was defo not expecting old stock.
Offline BillyO
« Reply #92 on: August 05, 2024, 10:06:10 pm »
When in 20204?  I know they were not available for a while as some vendors were out of stock.  Did you complain to them?  I have found them to be very responsive.
Bill
Offline boreack
« Reply #93 on: August 28, 2024, 07:15:52 pm »
Does anyone know what the "CH1_20M" function is for?
It appears in the last firmware "3.0.5-III" and seems to be a 20M bandwidth limit for the selected channel (It's in the same menu than F_Meter. Menu > x1x10 >x1x10) but I don't know why you like to limit the bandwidth.
Do you win something?
Greetings
Offline BillyO
« Reply #94 on: August 28, 2024, 07:24:17 pm »
No prizes.  There is no real requirements for it anymore and it's really just of historical significance.  A lot of products are still ( :-// ) only tested via 20MHz BW, like power supplies.  Back in the day (pre 1970s) engineers demanded that noise and ripple of PS units be checked against high BW for the time (20MHz).  Like a lot of engineering specs, it's hung around like an unwanted relative.  These days testing PS units to only 20MHz is just sweeping dirt under the rug.  IMO anyway.
Yeah, so it's there in nearly every scope for that (long past it's best before date) reason.
Bill
Offline Fungus
« Reply #95 on: September 24, 2024, 05:29:35 am »
It's for use when you're in 1x mode.
Offline BillyO
« Reply #96 on: September 24, 2024, 02:09:43 pm »
For the life of me I cannot see how you took that leap from looking at that video.  The probe itself, in 1X mode, is going to limit your BW to well under 20MHz so why on earth would you need or want to engage 20MHz BW on your scope when using a probe in 1x mode?
Dude, ur jus' makin' stuff up!  :-DD
Bill
Offline Fungus
« Reply #97 on: September 28, 2024, 08:01:03 am »
I was reading the manual and saw that the multimeter is easily calibratable.
Just input a known value and tweak the screen reading to match.
« Last Edit: September 28, 2024, 08:02:39 am by Fungus »
The following users thanked this post: spikey1973, BillyO
Offline BillyO
« Reply #98 on: September 28, 2024, 03:00:01 pm »
Wow, I didn't know that.  Thanks.
Mine measures the same as my SDM3055 anyway but this is good to know.
Bill
The following users thanked this post: Fungus
Offline Fungus
« Reply #99 on: September 28, 2024, 03:39:17 pm »
I think one of these is on my "new toy" waiting list now. It seems ideal for Arduino club.
For somebody on a budget that's just starting with nothing this is amazing value for money.
If you gave a kid one of these and some Arduino stuff you probably wouldn't see them for six months.
