Author Topic: FNIRSI-1013D "100MHz" tablet oscilloscope  (Read 1481073 times)
0 Members and 117 Guests are viewing this topic.
Offline Atlan
  • Country: sk
Re: FNIRSI-1013D "100MHz" tablet oscilloscope
« Reply #1700 on: January 05, 2024, 08:03:27 am »
Tokar: try 0.019d?
Now it is possible to scroll, progress by 2 screens.  350+750+350 display points.  By removing the restriction, it will be possible to move 3000 samples over the entire memory, but I have to find out how the recalculation for display is solved.
Long time is possible, but more change code.
« Last Edit: January 05, 2024, 08:19:44 am by Atlan »
FNIRSI 1013D Always provide a picture or video with the problem where the parameters of the oscilloscope are visible, and a picture of the diagnostic screen with the values.
Firmware is here (or not) https://github.com/Atlan4/Fnirsi1013D/tree/main/Guide%20to%20firmware
The following users thanked this post: tokar, facekim
Offline St_dsk
  • Country: ua
« Reply #1701 on: January 05, 2024, 01:33:43 pm »
First version Fnirsi-1013D( fpga Altera) firmware v.0.019d. The displayed output voltage, in Ch1 and Ch2, depends on the frequency, with a F>4MHz
The following users thanked this post: facekim
Offline Atlan
  • Country: sk
« Reply #1702 on: January 05, 2024, 02:43:21 pm »
Hardware problem, check on original firmware
Offline gadak
  • Country: al
« Reply #1703 on: January 06, 2024, 05:54:37 am »
Hello, I noticed one nuance, when setting the brightness of the display from 0 to 50% there is a squeak inside. Is it like this?
Offline Atlan
  • Country: sk
« Reply #1704 on: January 06, 2024, 07:36:08 am »
Recovery firmware
If something doesn't work. Or it works strangely.
It beeps even on the original firmware, the more discharged the battery, the louder it beeps.
« Last Edit: January 06, 2024, 07:41:19 am by Atlan »
Offline pcprogrammer
« Reply #1705 on: January 06, 2024, 07:41:42 am »
I'm sure you will hear that too with the original firmware. The brightness setting is done with pulse width modulation of the displays background LED driver. The chip used in the device has a max input frequency of 1KHz, and the FPGA outputs ~800Hz for this. The coil used in the boost converter makes this noise.
Offline tokar
  • Country: ru
« Reply #1706 on: January 06, 2024, 11:00:28 pm »
Tokar: try 0.019d?
v0019d Device after calibration, and autoset. Sensitivity 500mv/div. We increase the DC voltage until the limit is reached, press autoset. And, lo and behold, the signal (2.4v 500mv/div) without limitation, expanded to full screen (0:29). Setting time by pressing autoset is ~5s.
We increase the signal to the limit (5v). We press autoset, the range switches to 1v/div. But the limitation remains. Still the same 4.5 cells as reported earlier (#1697). We increase the voltage to 7V, press autoset. The range changes to 2.5v/div, the limit disappears (1:50).
Then I gradually increase the voltage, and at 16V I get a transition to 5v/div (3:39). But the "0" marker is in the center of the screen. I increase the voltage again, checking the status each time by pressing autoset. There is a limitation at 22V, but there is no offset of the “0” marker (5:20). At 31v we get a marker shift, and, as a result, the signal limitation is removed (7:30).
https://youtu.be/2mIM5b9XkMI
« Last Edit: January 07, 2024, 04:31:27 am by tokar »
Offline Atlan
  • Country: sk
« Reply #1707 on: January 07, 2024, 06:36:42 am »
Moving the signal through the entire memory. it is necessary to reduce the sampling rate in the menu if you want to capture a larger time segment.
beta v0.019e
« Last Edit: January 13, 2024, 09:35:36 am by Atlan »
The following users thanked this post: tokar, OneDiy, facekim
Offline _AVP_
  • Country: ua
« Reply #1708 on: January 07, 2024, 12:17:41 pm »
Hi! Looks like a small bug with setting of pin 14 U1 (output from CPU to LCD) - very small amplitude of LCD_D12 (1V and 50Hz distortions from environment). On original FW there is full amplitude 3V. Because of it there is some graphical noise in a middle of screen (lower bit of Red color is distorted, it viewable on ACQ menu).  Maybe this pin it is not programmed as output?
Also because of it startup logo have not quite smooth gradient
« Last Edit: January 07, 2024, 12:22:06 pm by _AVP_ »
The following users thanked this post: Atlan, tokar, facekim
Offline _AVP_
  • Country: ua
« Reply #1709 on: January 07, 2024, 12:25:25 pm »
some pictures. tested this pin with another oscilloscope.
The following users thanked this post: Atlan, facekim
« Reply #1710 on: January 07, 2024, 01:37:36 pm »
Hi _AVP_, welcome to the forum.
Good catch. I did notice something with the display while I did the development, but never looked into it.
And you are absolutely correct that there is a bug. So thanks for mentioning it here.
@Atlan, since you are working on it with new releases, it is easiest if you make the small change. In the function sys_init_display the port configuration register 1 needs not 0x22222227, but 0x22272222. See the code part below. I have not tested it, but it should do the trick. The comment in the source was and is correct, but the actual value was not.  :palm:
void sys_init_display(uint16 xsize, uint16 ysize, uint16 *address)
  int32   time;
  uint32 *ptr = DISPLAY_CONFIG_ADDRESS;
  uint32  checksum = 0;
  uint32  index;
  //Setup the used port D pins for LCD
  *PORTD_CFG0_REG = 0x22222227;   //PD00 is not used for the display
  *PORTD_CFG1_REG = 0x22272222;   //PD12 is not used for the display
  *PORTD_CFG2_REG = 0x00222222;   //Only 22 pins for port D
Offline Atlan
  • Country: sk
« Reply #1711 on: January 07, 2024, 01:50:14 pm »
 :-\  :palm: 0.019f  ??? mistake  :scared:
0.019g is ok  :phew:
I hope that there is no similar error when reading data from fpga.
« Last Edit: January 13, 2024, 09:36:04 am by Atlan »
The following users thanked this post: tokar, _AVP_
« Reply #1712 on: January 07, 2024, 02:13:27 pm »
Doubt it, but you never know. I did make more of these copy, paste forget to edit errors.  :-DD
Offline Atlan
  • Country: sk
« Reply #1713 on: January 07, 2024, 02:23:07 pm »
I still can't get over the noise on the AD converter. I tried to use a 10-bit converter and the noise is almost the same... I tried to split the power supply for the analog and digital parts at 8-bit and it didn't help.
« Last Edit: January 07, 2024, 02:25:11 pm by Atlan »
Offline tokar
  • Country: ru
« Reply #1714 on: January 07, 2024, 03:26:20 pm »
Addition to message #1707.
 v0019d.  I provide a complex AC + DC signal.  I press autoset (0:50).  This results in very slow signal processing.  If the DC signal (only) is processed for 5 seconds, then the complex signal is ~ 30-40 seconds.  During processing, the image on the screen freezes, clearly visible by the clock in the upper right corner.  I reduce the AC signal (2:15), press autoset.  The DC signal spans the entire screen, AC goes beyond the screen, but the limitation does not show (3:10).  I increased the AC value (3:25), the line at the top turned red - limitation.  I turned off the AC signal completely and pressed autoset (3:44).  The result is not satisfactory: 2.5v/div, Uin =12v DC, which does not correspond to the span of 8 cells (4:25).  I reduce the DC signal to a minimum - there is no reaction on the screen.  I set it to 0.5v DC, press autoset (5:25), the readings are correct.  I increase the signal to 12V, press the autoset (5:53, 6:01), and at 2.5v/div I get a swing of 4.5 cells and a limit.  I’m watching an unrestricted signal (5v/div) (6:25) - everything is fine.
https://youtu.be/UU2kYDJEzzc
Offline Atlan
  • Country: sk
« Reply #1715 on: January 07, 2024, 04:07:20 pm »
DC mode. Yes, it is far from functional.  It will be necessary to come up with some functional solution.  It's not fun looking at it all the time.  Sometimes you need to rest and find a solution.  Besides, you also have to go to work :D But thanks for the information.  I appreciate it.
Has anyone checked the timestamp of the files?  Does the time and date of file creation or modification match under Linux and Windows?
« Last Edit: January 07, 2024, 04:33:16 pm by Atlan »
« Reply #1716 on: January 07, 2024, 04:47:18 pm »
The ADC's used might well be B stock of a clone of the AD9288 assumed to be used. Maybe they are not even 100MHz parts, but 80MHz or less, and used with overclocking. Further more the whole design is noisy. There is no separation between analog and digital ground. The power supply setup for the analog part is crap. Etc.
It is a nice platform to play with and learn (scope) software development, but that is it.
Offline Atlan
  • Country: sk
« Reply #1717 on: January 07, 2024, 07:21:25 pm »
They put other fpga there, even the pcb has at least 3 versions.  So why not change the power supply and GND?
Offline Atlan
  • Country: sk
« Reply #1718 on: January 08, 2024, 06:40:49 am »
What is the idea of ​​starting the calibration of input dividers?
In practice, it only needs to be done once.  Should the fixed firmware be used to recall this calibration?  Or add an item to the menu for Reset basic settings?
« Reply #1719 on: January 08, 2024, 07:28:27 am »
The calibration on the new firmware is two fold.
  • Set the dc offset to obtain a center reading without as probe connected. (Grounded input would be better)
  • Find the difference between the two ADC's that make up a single channel, so that a equal reading can be made on the interleaved samples.
I tried to make it better then the original, to always have the +3K samples instead of like what the original does. For the 100MSa/s and below they only use a single ADC per channel and read just 1500 samples. Only on the ranges that need 200MSa/s they use the second ADC, and get the extra samples.
The equalization in the original is done on adding or subtracting something on the second ADC data. This reduces more on the total resolution. My version tries to divide it and modifies the data of each ADC with half the difference of the average.
The calibration has nothing to do with accuracy. That is why they called it base line calibration.
Offline Atlan
  • Country: sk
« Reply #1720 on: January 08, 2024, 07:34:25 am »
It's OK.  This is the calibration of the input dividers.  Now 7 constants are fixed in the code.  Otherwise, it would be a completely different calibration by connecting precise voltages and adjusting the conversion constants.
« Reply #1721 on: January 08, 2024, 08:10:10 am »
Ah, yes I remember these. Those values are from the original firmware. Probably not worth spending a lot of time on trying to improve on that.
Offline Atlan
  • Country: sk
« Reply #1722 on: January 08, 2024, 09:02:54 pm »
Menu for calibration of input dividers
The following users thanked this post: zildan, tokar, OneDiy, facekim
Offline tokar
  • Country: ru
« Reply #1723 on: January 09, 2024, 02:34:57 am »
Rational :clap:
Offline OneDiy
  • Country: th
« Reply #1724 on: January 09, 2024, 02:40:55 am »
V0.019g found a problem with display. Tried setting TP and couldn't fix it.
