Author Topic: FNIRSI-1013D "100MHz" tablet oscilloscope  (Read 1495456 times)
0 Members and 39 Guests are viewing this topic.
Offline Atlan
  • Country: sk
Re: FNIRSI-1013D "100MHz" tablet oscilloscope
« Reply #2575 on: November 02, 2024, 09:16:54 am »
Want a battery saver?  1. In the menu, there would be a choice after which time the backlight level should be reduced and a setting to which level it should be reduced.
FNIRSI 1013D Always provide a picture or video with the problem where the parameters of the oscilloscope are visible, and a picture of the diagnostic screen with the values.
Firmware is here (or not) https://github.com/Atlan4/Fnirsi1013D/tree/main/Guide%20to%20firmware
The following users thanked this post: facekim, engineer.r152, MHTSOS
Online engineer.r152
  • Country: ru
« Reply #2576 on: November 02, 2024, 10:23:16 am »
Good idea!
Offline Zombie47
  • Country: ru
« Reply #2577 on: November 03, 2024, 10:21:09 pm »
https://youtu.be/6zd22vRKPY4
Why page 2 of DC shift calibration does not work?
Offline Zombie47
  • Country: ru
« Reply #2578 on: November 03, 2024, 10:47:40 pm »
What is this flashing yellow and red graph? Why is it flashing?
https://youtu.be/hsI1iv-U_KU?si=XXZxusg2iz31QKiy
Offline Atlan
  • Country: sk
« Reply #2579 on: November 04, 2024, 09:12:53 am »
1. video is not available
2.exceeding the range of the AD converter
instruction 0.025v
« Last Edit: November 04, 2024, 07:05:30 pm by Atlan »
Offline Atlan
  • Country: sk
« Reply #2580 on: November 04, 2024, 10:09:03 am »
different roll mode, only test, no final solution, try and comment.
Clearing the display and rendering everything takes some time, so I'm not sure if it can even render at 100ms/div
« Last Edit: November 04, 2024, 11:43:47 am by Atlan »
The following users thanked this post: facekim, Russell2024UK
  • Country: ru
« Reply #2581 on: November 04, 2024, 02:00:05 pm »
Special thanks for the saved backlight state! About the new display.
1. Channel 2 is not working
2. The scrolling speed for 100 ms, 200 ms and 500 ms is the same from 1 second
3. It would be good to make this mode turn on separately from the button, either as it was before, or scroll mode.
4. Few points are drawn on the ray, there are no lines that connect them into a solid line.
In conclusion. It turned out very cool! That's what I wanted! It remains to refine a little)
« Last Edit: November 04, 2024, 02:18:39 pm by engineer.r152 »
Offline Atlan
  • Country: sk
« Reply #2582 on: November 04, 2024, 03:01:40 pm »
This style was not used because it takes a lot of time to erase the entire display and redraw it. Therefore, the sampling frequency is rapidly reduced. The question is whether it could be optimized somehow.
  • Country: ru
« Reply #2583 on: November 04, 2024, 06:09:15 pm »
Won't it be possible to organize a fifo type? But even if you do not change anything, this mode can be useful already in this form, only activate it not by default, but as an additional function on the button and if there is not enough power, then do not from 100 msec, but from 1 second.
Offline Zombie47
  • Country: ru
« Reply #2584 on: November 04, 2024, 08:07:40 pm »
instruction 0.025v
Sorry, now available.
Offline Atlan
  • Country: sk
« Reply #2585 on: November 04, 2024, 08:19:01 pm »
Because the dc shift is 0.
Offline Russell2024UK
« Reply #2586 on: November 08, 2024, 09:58:09 am »
Hi Atlan  :) , Regarding our 1013D oscilloscope, could you let me know which firmware version you’d recommend as the most reliable for daily use? Thanks,  :-+ Russell
Offline Atlan
  • Country: sk
« Reply #2587 on: November 08, 2024, 02:51:18 pm »
Firmware 0.025u with userguide 0.025v.
It is possible to upload a new version tomorrow, where the overload is fixed so that the signal is red.
« Last Edit: November 09, 2024, 08:11:55 am by Atlan »
Offline Atlan
  • Country: sk
« Reply #2588 on: November 09, 2024, 07:56:03 am »
v0.025x Saving the brightness setting, correction of exceeding the range of the ad converter - the displayed signal course is red. roll mode old version
The following users thanked this post: zildan, tokar, boojum, Khial, Russell2024UK
Offline pcprogrammer
« Reply #2589 on: November 09, 2024, 08:13:14 am »
PC.  Is it possible somewhere in the code to simply turn off the correction function using the value (ADC comp) (why is it done first for adc1(ch1) and then for adc2(ch1). Thanks
A simple turning it off, I don't think so, but I made it like this to get a slightly larger and better centered range. If the compensation is only done on one ADC, like in the original, and the difference between the two ADC's is let say 6, you have to add or subtract 6 to or from one of the ADC's, thus limiting the range from 0 to 249. If you split it in the middle and adjsut both ADC's with only half the value the range becomes 0 to 252. It is not much, but in my eyes better.
Offline Atlan
  • Country: sk
« Reply #2590 on: November 09, 2024, 08:23:01 am »
ok thank you. if the Chinese did not extend the power supply around the uP, fpga, ad converter and so on to the input amplifier... when I extended a separate power supply for each part, the interference is 0-1
« Reply #2591 on: November 09, 2024, 05:51:50 pm »
Yeah, the hardware design is not the best, but we already knew that.
Offline Zombie47
  • Country: ru
« Reply #2592 on: November 17, 2024, 05:51:19 pm »
Unable to measure long term signal
v0.025u
Offline Atlan
  • Country: sk
« Reply #2593 on: November 18, 2024, 05:34:21 am »
Save the wave, and measure there.
Offline Atlan
  • Country: sk
« Reply #2594 on: November 20, 2024, 04:18:08 pm »
https://youtu.be/KK51iftmdVU?si=P0jG_81L_xmlqLu2
I don't know how to get this menu (300mv and others) again. Because the menu doesn't appear anymore.
Resetting calibration does not help.
Now I tried it, everything works like me. I perform a reset through the diagnostic menu, return to the main menu, start the base calibration, after performing the calibration, a request to connect 300mV is displayed and so on.
Offline Cronyx
  • Country: ua
« Reply #2595 on: December 04, 2024, 08:10:11 am »
How to mirror the touchscreen vertically? gt911
« Last Edit: December 04, 2024, 08:27:18 am by Cronyx »
« Reply #2596 on: December 04, 2024, 02:17:51 pm »
It is described here: https://github.com/pecostm32/FNIRSI_1013D_Firmware/blob/main/configuration_file.txt
Make the last byte of the file 0x00 and it should flip the vertical touch.
Offline Atlan
  • Country: sk
« Reply #2597 on: December 04, 2024, 07:30:53 pm »
I recommend doing it through the program loader 1.1.3, because the bits for the botloader are also located in the given space (behind the settings of the touch panel and the rotation of the display)
Offline Atlan
  • Country: sk
« Reply #2598 on: December 05, 2024, 10:08:02 am »
Is it possible to connect a USB serial interface to CH340b based on this? f1c100s_ch340 is it functional? Somehow it doesn't work for me. Where is the baud rate option?
« Reply #2599 on: December 05, 2024, 10:29:25 am »
I wrote that code to test the USB interface in device mode. The f1c100s_ch340_sd_package version was used to test communication with the FPGA. It emulates a CH340 USB device on the host, but not on the device itself, so no serial communication from the F1C100s to some other hardware.
It works for sending and receiving data to and from the F1C100s. If you want to use the F1C100s UART in combination with the code I wrote, you have to extend the code.
The link between the host and the device is baud rate independent, and I did not implement any of the control stuff in the handler on the F1C100s.
So it is just a tool for easy communication with the F1C100s.
