The area to the left of the pink line is used to control the ref waveforms, the area to the right of the pink line is used to control the trigger. In between is the area to control the ch1 signal position. The touch must not be further than +-30 units (above, below) from the signal axis marked by the marker. You are still controlling it wrong, according to the video. Interestingly, when you want to move the ref waveform, you put your finger over the center of the ref signal, but when you want to move the ch1 signal, you do not do that anymore.
