I can't watch the video, it keeps saying I should ask the owner for access. Don't you have it publicly accessible?
A photo of the entire PCB from the side where the FPGA and uP and AD converters are located.
Spustite PECO firmware-LEN z baterie, ( nastavte kanaly na AC,50mV, 20MSa/s 5us/div, trigger do stredu obrazovky)chodte do diagnostiky, tam stlacte RESET, ADC comp by sa mali nastavit na 0. DAjte Exit. A ulozte priebeh ako WAVE. Urobte to pri viacerych nastavenia casovej zakladne napr 200KSa, 50MSa, 200MSa/100ns/div. Celkovo 4 wave subory tu nahrajte.
Run PECO firmware - ONLY from battery, (set channels to AC, 50mV, 20MSa/s 5us/div, trigger to the center of the screen) go to diagnostics, press RESET there, ADC comp should be set to 0. EXIT. And save the waveform as WAVE. Do this for multiple timebase settings e.g. 200KSa, 50MSa, 200MSa/100ns/div. Upload a total of 4 wave files here. Thank you
