Author Topic: FNIRSI-1013D "100MHz" tablet oscilloscope  (Read 1476352 times)
0 Members and 66 Guests are viewing this topic.
Offline OneDiy
  • Country: th
Re: FNIRSI-1013D "100MHz" tablet oscilloscope
« Reply #3550 on: January 04, 2026, 10:53:14 am »
I tested it and it works great. Thanks for the good firmware
https://www.youtube.com/shorts/_NjynZQ8yhI
Offline Felipe Lacerda
  • Country: br
« Reply #3551 on: January 04, 2026, 08:12:13 pm »
With the new FPGA firmware, how can we recover if the SD card fails?
Offline Atlan
  • Country: sk
« Reply #3552 on: January 05, 2026, 07:15:25 am »
You remove the SD card and insert it into the reader on your PC, or you can simply insert a new card with recorded content via Loader 113 on your PC.
FNIRSI 1013D Always provide a picture or video with the problem where the parameters of the oscilloscope are visible, and a picture of the diagnostic screen with the values.
Firmware is here (or not) https://github.com/Atlan4/Fnirsi1013D/tree/main/Guide%20to%20firmware
Offline Atlan
  • Country: sk
« Reply #3553 on: January 05, 2026, 02:17:10 pm »
So successfully uploaded new firmware to the EF2 fpga.
« Last Edit: March 01, 2026, 10:13:40 am by Atlan »
The following users thanked this post: rozwell
Offline Atlan
  • Country: sk
« Reply #3554 on: January 05, 2026, 02:19:41 pm »
0x1632 for EF2
max memory is 12000
Offline St_dsk
  • Country: ua
« Reply #3555 on: January 05, 2026, 06:09:50 pm »
Is there a firmware version for the Altera EP4CE6E22C8N FPGA?
Offline pcprogrammer
« Reply #3556 on: January 05, 2026, 06:19:16 pm »
The versions from before Atlan started with changing the FPGA configuration do for sure. I believe the latest version can also work with it, but is limited to the 3000 samples and might need some extra configuration.
Offline Atlan
  • Country: sk
« Reply #3557 on: January 05, 2026, 06:56:39 pm »
The dso1.00o firmware is compatible with the standard firmware in the FPGA. Theoretically I can generate firmware for the altera FPGA (but without guarantee and you have to make a backup of the flash spi content for the FPGA - because I don't have such content) Otherwise AL3 and Ep4ce6 are pin compatible, it is even possible to install EP4ce10 and get more sample memory
« Last Edit: January 06, 2026, 07:59:07 am by Atlan »
Offline St_dsk
  • Country: ua
« Reply #3558 on: January 06, 2026, 07:00:36 am »
If firmware for Altera is created, I will check it out.
Offline Atlan
  • Country: sk
« Reply #3559 on: January 08, 2026, 12:21:31 pm »
Try the altera EP4CE6 but  don't what it will do.
« Last Edit: January 09, 2026, 12:29:23 pm by Atlan »
Offline St_dsk
  • Country: ua
« Reply #3560 on: January 09, 2026, 06:47:05 am »
Thanks for the firmware. The firmware works.
One note: the initial display brightness setting in the firmware is 50%. At this setting, the oscilloscope display is completely dark. The image appears at 51-52%.
Offline Atlan
  • Country: sk
« Reply #3561 on: January 09, 2026, 11:30:24 am »
I'll look into it. Use firmware v1. 00o. Max number of samples for EP4CE6 is 12000. (I'll fix the firmware for EP4) Otherwise it is possible to install EP4ce10 which would increase the number of samples. Otherwise you don't have a calibrated oscilloscope, the trigger will not work properly, and the oscilloscope will jam. Read the firmware manual.
« Last Edit: January 09, 2026, 12:11:51 pm by Atlan »
Offline Atlan
  • Country: sk
« Reply #3562 on: January 09, 2026, 12:11:19 pm »
fix brightness for EP4CE6 fpga
« Last Edit: January 09, 2026, 05:33:02 pm by Atlan »
Offline ObsoleteDIY
  • Country: sk
  • Sometimes you can teach an old dog new tricks.
« Reply #3563 on: January 09, 2026, 12:24:19 pm »
Hi Atlan, I tested DSOv1.00o on Fnirsi FW FPGA EF2L. I set the memory depth to 3000. The automatic setting did not work and the device freeze. I rolled back FW DSOv0.27u and the device works correctly. Will my test protocol help you or is it not necessary to test like this? Thanks.
Offline Atlan
  • Country: sk
« Reply #3564 on: January 09, 2026, 12:30:32 pm »
Offline ObsoleteDIY
  • Country: sk
« Reply #3565 on: January 09, 2026, 04:11:53 pm »
Hi, please see the test video at the link below. I tested DSOv1.00o and DSOv0.27u. Attached is a photo with diagnostic information. Did I make a mistake during testing? Thank you
https://drive.google.com/file/d/14s2RdLV3LAq6aBbV9mF-PEtY2PIdCoNK/view?usp=drive_link
https://drive.google.com/file/d/1sVPa8sBwmuCTd4W6FfHXo7Ipf0TLsW0o/view?usp=drive_link
Offline St_dsk
  • Country: ua
« Reply #3566 on: January 09, 2026, 05:04:39 pm »
I tested the new firmware version. The display still dims at 50%. The display brightness at 100% is even lower than it was in the first firmware version.
Offline Atlan
  • Country: sk
Offline Atlan
  • Country: sk
« Reply #3568 on: January 09, 2026, 05:32:19 pm »
My mistake, those are the remnants of the frequency change for dimming so that it doesn't beep. try
Offline engineer.r152
  • Country: ru
« Reply #3569 on: January 09, 2026, 06:07:54 pm »
Good evening! I installed the latest version of the FPGA firmware for AL3 and now the display backlight is practically not working, 100% brightness is visible only when the lights are off, and the bootloader menu is not visible at all, and now I can't roll everything back.
Offline St_dsk
  • Country: ua
« Reply #3570 on: January 09, 2026, 06:17:20 pm »
I'll check on Monday if I get the device working again. It seems the FPGA in my device has stopped configuring.
Offline Atlan
  • Country: sk
« Reply #3571 on: January 09, 2026, 06:24:08 pm »
Does the base level calibration work?
Offline ObsoleteDIY
  • Country: sk
« Reply #3572 on: January 09, 2026, 06:36:08 pm »
it doesn't work...and device freeze
« Last Edit: January 09, 2026, 06:40:31 pm by ObsoleteDIY »
Offline St_dsk
  • Country: ua
« Reply #3573 on: January 09, 2026, 06:41:48 pm »
You can force the backlight to turn on by applying 3.3V to the EN pin of the backlight controller IC. You posted a photo of this IC on page 143. There's a 1kOhm resistor next to the required pin. Apply 3.3V through a current-limiting resistor.
  • Country: ru
« Reply #3574 on: January 09, 2026, 07:28:08 pm »
thank you, I know that, but I would like to fix the adjustment programmatically.
