I tested the AL3 firmware with software version 1.00p8. Aside from the diagnostics page, which correctly reports version 2001 with 12,000 samples, it says EF2-L45. You probably forgot something...
I ran a few simple tests, and I'd say it's basically functional. I displayed square and sine waves and the code generated by a remote control to check the sampling depth. I had no problems. However, I noticed that when the acquisition rate switches to 200 MSa/s, the software seems to freeze, as does the acquisition. Basically, it doesn't work. Furthermore, high-speed acquisitions are noisy and jagged. You could probably consider displaying a moving average.
The product could be improved, but I'm still satisfied with the work you've done, and I thank everyone.
