Author Topic: Magnova oscilloscope  (Read 419926 times)
0 Members and 62 Guests are viewing this topic.
Offline kmoonwalker
Re: Magnova oscilloscope
« Reply #1200 on: September 05, 2025, 10:56:39 pm »
It is due to customs... I often have this with orders of components from UK and does not matter the forwarder - if you are lucky they arrive as planned but often they get stuck in some office dealing with import to EU territory and you may wait 2-5 days... (Once I urgently needed some big capacitors, they sent them same day but they were coming from Switzerland and they got stuck for almost two weeks... we were joking that they were drinking electrolyte or wtf...)
The following users thanked this post: ralphrmartin, jusaca
Offline carl0s
« Reply #1201 on: September 06, 2025, 01:19:50 pm »
Could be, but it's only UPS who give a delivery date and then 'reschedule' it a few days prior, frequently. Others like DHL and FedEx often come earlier than the original date.
Carl
Offline tooki
« Reply #1202 on: September 06, 2025, 02:14:36 pm »
We've been using the ICZI IZEC-A94 active DP/HDMI adapter here and at various events, and it has worked flawlessly with all monitors and beamers so far.
FYI, “Beamer” is a German word (I think Dutch, too?) that is unknown in English. We say “video projector”. (Or just “projector” for short, since other projectors are rarely used anymore!)
The following users thanked this post: nctnico, egonotto
Offline tooki
« Reply #1203 on: September 06, 2025, 02:24:35 pm »
Any conclusions on what kind of 15.6" FHD LCD screen is used in the Magnova.. is it TFT or IPS screentech?
TFT/Thin-Film Transistor
* Pros, cheap with fast response times.
* Cons: Narrow viewing angles, poorer color accuracy, more prone to haze/rainbow effects with cheap screen protectors.
IPS/In-Plane Switching
* Pros: Wide viewing angles, better color consistency/accuracy, quite a bit more resistant to polarization-issues from cheap plastic screen protectors.
* Cons: Often more expensive, a tad slower response times compared to the average TN/TFT panels.
My guess would be that it's an IPS screen, even though TFTs are very common on oscilloscopes.
Just to be crystal clear: IPS displays are also TFT displays.
Some people mistakenly use “TFT” as a synonym for TN and STN types of TFTs, but that is very bad practice, since there are many kinds of TFT LCDs, including TN, STN, PVA, IPS, and more. They are all based on thin-film transistors, because that’s how we make active-matrix LCDs.
The following users thanked this post: jusaca
Offline kmoonwalker
« Reply #1204 on: September 07, 2025, 02:07:55 pm »
TFT marketing on some markets is so strong even nowadays - in the past like 20+ years ago it was a differentiation of cheap screens with passive LCD matrix control from new ones able to control separately single pixel in a row but nowadays it is like advertising some computers on ebay as 10GHz or more CPU speed (yep sellers used to add each core speeds together  :-DD)
Online Martin72
« Reply #1205 on: September 07, 2025, 06:22:09 pm »
I am currently familiarizing myself with the topic of spectrum analyzers, so perfect results are not to be expected yet.
Nevertheless, here are two images, with the AWG as the signal source at 1 MHz and approx. 0 dBm (I have already suggested adding the missing dBm unit to the amplitude settings), plus a 30 dB attenuator at the input of the SA.
Offline 2N3055
  • Country: hr
« Reply #1206 on: September 07, 2025, 07:22:28 pm »
I believe you need to use parameter Ref Offset (2.1.3.7, page 24, manual) to enter 30 dB loss from external atten.
Dr. Richard W. Hamming
The following users thanked this post: tautech, KungFuJosh, Martin72
Online Martin72
« Reply #1207 on: September 07, 2025, 07:59:36 pm »
Yes, that's right, it makes it easier to classify the first image; the distortion values are not affected by this.
« Last Edit: September 07, 2025, 08:20:59 pm by Martin72 »
Online Martin72
« Reply #1208 on: September 07, 2025, 08:20:42 pm »
I have to correct myself, that was wrong.
Thanks for pointing out the 30dB offset.
THD has improved even further as a result (0.01%).
« Reply #1209 on: September 07, 2025, 08:38:49 pm »
Don't disengage Auto Attenuation as it risks the analyzer not protecting itself.
As you change settings with Auto Attenuation engaged you will see the attenuation values change at the top of the screenshot yet the levels remain correct.
This common usage mistake is often responsible for damage to the RF input and is flagged with the blue dot.
Instead when using external attenuation alway use the Ref Offset to correct the level from external attenuators as Sinisa has pointed out.
« Last Edit: September 07, 2025, 08:41:15 pm by tautech »
Avid Rabid Hobbyist
Online Martin72
« Reply #1210 on: September 07, 2025, 09:08:02 pm »
What do you think I did earlier... ;)
For the rest:
I am aware of this, given that with an attenuator of 30dB at the input and a signal of 0dBm, there was nothing to worry about in that regard.
We can continue this discussion in a thread about spectrum analyzers. :-+
Offline ralphrmartin
    • Me
« Reply #1211 on: September 09, 2025, 07:30:34 pm »
I suggest Batronix change their shipper. UPS originally said they were going to deliver my waveform generator on Tuesday, then Thursday (today) , then tomorrow, now they are syaing next Monday. Its beginning to sound like they have lost it, or at least have no idea where it is.
Full marks to Batronix who have promptly discovered that UPS have indeed lost my unit, and have arranged for another one to be shipped by a differnt shipper.
The following users thanked this post: jusaca, KungFuJosh, Martin72, rf-messkopf
Offline KungFuJosh
  • TEAS is real.
« Reply #1212 on: September 09, 2025, 07:42:43 pm »
UPS strikes again.  :palm:
Best Continuity Tester Ever
Offline carl0s
« Reply #1213 on: September 16, 2025, 07:42:54 pm »
Sorry to hear that. Mine came a further day later than the already rescheduled day.
Lovely piece of kit though :-)
Carl
Offline carl0s
« Reply #1214 on: September 20, 2025, 10:16:32 pm »
Added a little Wi-Fi <-> ethernet pseudo-bridge to mine. Works good, for saving screenshots to SMB and stuff, since I have it set up in a normal part of the house while I explore the excellent demo and training board :)
2663721-0
Carl
Offline KungFuJosh
  • TEAS is real.
« Reply #1215 on: September 21, 2025, 01:17:07 am »
SMB works for you? What OS are you connecting to?
Offline carl0s
« Reply #1216 on: September 21, 2025, 08:26:48 am »
Yes it does. Host/server is windows 11 pro main computer in other room.
With username & password auth.
I'm sure I have possibly altered some windows policy settings in the past though, and maybe made sure I'm not using a Microsoft account on the pc (this also would break RDP you see.. unless they finally fixed that now. I RDP-in all the time over Wireguard from wherever I am working)
Carl
Online jusaca
« Reply #1217 on: September 21, 2025, 09:21:35 am »
Is there some general problem with using SMB to save screenshots from the magnova?
Offline carl0s
« Reply #1218 on: September 21, 2025, 10:29:36 am »
Doesn't seem to be. There is often trouble getting a standalone Windows 10/11 PC to work as an SMB server though, and when the client is Linux or some other embedded non-Windows OS, it can take some tinkering in my experience. Having a local account on the smb server to authenticate against is a good starting point (no good if your only user account is a Microsoft account), then there are dialects to look at, and the Windows firewall of course. SMB-signing isn't an obstacle these days AFAIK.
In my case here, I saved the screenshot locally on the Magnova, then hooked up the Wi-Fi adapter/bridge (after searching for a micro-usb cable for an hour !), then I copy/pasted the file across to the SMB share from the Magnova's GUI. So I suppose you could say I didn't "use SMB to save a screenshot" directly, if there is a difference.
« Last Edit: September 21, 2025, 10:32:24 am by carl0s »
Carl
Offline woody
« Reply #1219 on: September 21, 2025, 11:57:34 am »
I can confirm that saving a screenshot (or any other file for that matter) directly to a share on a Win11 machine works flawlessly.
The only funny thing I encounter is when I save a file to a share, remove the network cable from the scope and then try to save a file again. Instead of giving me the option to save the file locally the scope hangs for a bit after which it shuts down. The same thing happens if I remove the network cable to the PC with the share.
To be complete, no shutdown happens if I unshare the share on the host (and leave the network connections intact). In that case the scope does show the previous share but if I try to save a file to it it gives me a 'The path is invalid' message and goes about its business.
Offline KungFuJosh
  • TEAS is real.
« Reply #1220 on: September 21, 2025, 02:39:22 pm »
There's still a small bug with username and password issues sometimes causing the scope to crash. I'm going to create a user on my PC just for the scope and see if that helps. 🤔
ETA: That worked. I added a simple local account with a single word username, and now I'm connected.
Thanks,
Josh
« Last Edit: September 21, 2025, 02:45:20 pm by KungFuJosh »
The following users thanked this post: carl0s
Offline Tomki
« Reply #1221 on: September 23, 2025, 11:11:13 am »
I use a NAS from QNAP to save data and it works flawlessly. You just need to specify an existing directory on the NAS and … no problem 😅
Offline 2N3055
  • Country: hr
« Reply #1222 on: September 23, 2025, 11:25:31 am »
Actually, that is SAMBA to SAMBA and is going to work more seamlessly than SAMBA to Windows.
The following users thanked this post: nctnico, KungFuJosh, Tomki
Offline KungFuJosh
  • TEAS is real.
« Reply #1223 on: September 24, 2025, 08:31:26 pm »
This made me a lot happier than it should have.  :-DD
ETA: In hindsight, the yellow intensity display version would have made more sense with the Cheese/div setting. 🧀
« Last Edit: September 25, 2025, 09:13:47 pm by KungFuJosh »
Offline Tomki
« Reply #1224 on: September 25, 2025, 08:06:57 am »
This is one of the reasons why I try to stay away from Windows anyway 😂
