Author Topic: Magnova oscilloscope  (Read 427245 times)
0 Members and 44 Guests are viewing this topic.
Offline 2N3055
  • Country: hr
Re: Magnova oscilloscope
« Reply #1225 on: September 25, 2025, 08:56:05 am »
I use a NAS from QNAP to save data and it works flawlessly. You just need to specify an existing directory on the NAS and … no problem 😅
Actually, that is SAMBA to SAMBA and is going to work more seamlessly than SAMBA to Windows.
This is one of the reasons why I try to stay away from Windows anyway 😂
Because Linux emulation of Windows file share protocol sucks, you blame Windows ?
 :-DD
Dr. Richard W. Hamming
Offline Tomki
« Reply #1226 on: September 29, 2025, 01:52:20 pm »
 :-DD
What does smb have to do with Windows, other than that it was developed by IBM and then taken over by Microsoft, like many other things that were also taken over from others by Microsoft (e.g. Apple)  :box:
« Last Edit: September 29, 2025, 02:23:29 pm by Tomki »
Offline Xyphro
« Reply #1227 on: September 30, 2025, 05:34:37 pm »
I received a test-unit from Batronix today. Have to say, that it is an absolutely great device.
PPL can argue about the new approaches, like the connectors that go to the right side or the stand, but I love it. I can route cable underneath the scopes and don't have a cable mess from my 4 probes annoying me. The big screen is great for my eyes which slowly but surely get older :-D
The software is super snappy. Highly responsive, not like my older scopes. Even the touch screen feels like an improvement rather than being a workaround. I worked with a lot of Keysight scopes with touchscreens and there it was always very annoying due to high lag and very poorly thought through UI Design. Or any of the newer Tektronix scopes: Technically great devices with 6 or 8 channels and good noiseless datapath, but very laggy in UI response (well plus issues in e.g. trigger delay).
Could not see anything which I miss so far and I played for several hours continously with it. Will now stress it further during next days while working on my new generation GPIB adapter. And if it continues to go that well I'll certainly buy one with AWG and logic analyzer.
I hope they have good sales with the scopes and continue to develop such nice devices.
Looking for a unique, cheap versatile USB to GPIB adapter with standard USBTMC interface? Build it yourself :-) https://github.com/xyphro/UsbGpib
Too lazy to build one?: https://www.elecrow.com/xyphrolabs-gpibusb.html
Interested in I3C protocol? Check this out: https://github.com/I3CBlaster
The following users thanked this post: Jacon, KungFuJosh, Martin72, Andre77, FloBX, Tomki, hotze
Offline KungFuJosh
  • TEAS is real.
« Reply #1228 on: September 30, 2025, 06:01:57 pm »
Don't worry, there's a LOT in development with this scope, including many more improvements to the UI, windowing, and eventually the web console.
I'm almost done with the driver for TestController which will give you a ton of options for remote control and automation...and they're going to be adding more features to SCPI for that too.
Their next firmware update will (I think) unlock most or all of the AWG functions. After that I should be ready to test the SCPI for that, and release the 1st version of the TestController driver. I'll release some new versions as requested features are added. ;)
Thanks,
Josh
Best Continuity Tester Ever
The following users thanked this post: Geofrey
Offline Xyphro
« Reply #1229 on: September 30, 2025, 06:19:01 pm »
Btw: Do I see right that ethernet based scpi is supporting tcp raw only and no HiSLIP/VXI or so?
As I work on HiSLIP for my GPIB adapter I wonder if that is a limitation, e.g. will service requests be signalled over ethernet efficiently. Not really "Home" with my knowledge on ethernet based T&M here (mostly use USBTMC which I know in&out), so see that as honest question not criticism.
What is testcontroller? A Scope GUI u made?
Offline KungFuJosh
  • TEAS is real.
« Reply #1230 on: September 30, 2025, 06:29:09 pm »
With TestController, yes, raw socket works, and VXI probably? (I know LXI I does for other devices). USBTMC and HiSLIP require universal (OS independent) libraries for Java to support them with TestController.
The GPIB adapters that work with TestController are based on the AR488 project (IIRC the Kofen version is also based on AR488 to some degree), Prologix compatible, or the NI version that works via serial ports.
USBTMC doesn't currently have a good library that works with that, so having serial or ethernet support similar to Prologix as a backup would be a good idea for your device.
Attached is a screenshot with two GPIB adapters I have setup in TestController, along with the list of currently supported GPIB flavors. You could potentially work with HKJ to add specific support for your new GPIB design, but you will still have limitations as stated above.
Back to the topic of the Magnova, there is potential for HiSLIP to be added in the future when the driver libraries become available. HKJ has expressed interest in adding that support as well, if/when it's possible.
Thanks,
Josh
Offline Xyphro
« Reply #1231 on: September 30, 2025, 07:04:24 pm »
Hmm, is there no visa interface existing for Java which would give you all interface types in one go with a common interface and portable?
Offline KungFuJosh
  • TEAS is real.
« Reply #1232 on: September 30, 2025, 09:26:28 pm »
I assume not, but you can ask here: https://www.eevblog.com/forum/testgear/program-that-can-log-from-many-multimeters/
That's HKJ's thread for his project TestController.
Thanks,
Josh
Offline KungFuJosh
  • TEAS is real.
« Reply #1233 on: October 01, 2025, 02:39:27 am »
Here are some more very practical use cases.  :box:
The following users thanked this post: Tomki
Offline jusaca
« Reply #1234 on: October 02, 2025, 01:49:46 pm »
We now have a mangova in our lab as well, it's a nice unit and a joy to work with.
One aspect I think is not that great yet is labeling of the time base in zoom mode. In the attached screenshot it is quite annoying to find the timebase. Actually you can not really see it at all, but you have to calculate it from the weird time stamps on the grid.
I would prefer the "Zoom" mode button to not only show the magnification (20.0x), but also the actual time step per division (in this case 5ms). That would make it much more intuitive to see the time scales you are looking at.
Offline KungFuJosh
  • TEAS is real.
« Reply #1235 on: October 02, 2025, 02:20:02 pm »
A lot of labeling needs improvement for sure. Some has been discussed, but that's a good idea too.
Offline jusaca
« Reply #1236 on: October 09, 2025, 08:25:00 am »
I found another thing that is bothering me, but I'm not sure whether this is typical behaviour or a magnova thing:
When using "normal" trigger mode to wait for a trigger event and keep that waveform displayed, the mangova seems to overlay several waveforms if the trigger condition is present for longer than can fit the screen. In the attached screenshot for example I'm now not able to tell the different blue waveforms from ch3 (larger and smaller peaks) apart. I have to explicitly use single shot to get only one single waveform (which can be annoying when wanting to do several single shots in series, you always have to rearm manually).
Is this the behaviour other scopes show as well? Or do other scopes only show a single waveform when using normal trigger mode?
« Last Edit: October 09, 2025, 08:56:41 am by jusaca »
Offline Sorama
« Reply #1237 on: October 09, 2025, 08:30:04 am »
speaking about triggering...
it's maGnova, not maNgova  :horse:
The following users thanked this post: carl0s, jusaca
Offline hotze
« Reply #1238 on: October 09, 2025, 08:46:35 am »
try to activate the history mode
The following users thanked this post: jusaca
Offline jusaca
« Reply #1239 on: October 09, 2025, 08:58:25 am »
Oh yeah, that helps. The history mode is awesome, nice!
Offline nctnico
« Reply #1240 on: October 09, 2025, 12:13:02 pm »
Some other scopes do this as well; I've seen Tektronix scopes do this. Sometimes it is handy to see the previous trace (for comparison) and sometimes it is confusing.
Offline joeqsmith
« Reply #1241 on: October 09, 2025, 01:19:56 pm »
I take it they are now shipping to the USA and Canada
Just checked
The Magnova oscilloscope is not yet available for sale in the United States and Canada.
« Last Edit: October 09, 2025, 01:37:11 pm by joeqsmith »
Offline KungFuJosh
  • TEAS is real.
« Reply #1242 on: October 09, 2025, 02:22:16 pm »
Just checked
As a business customer I was able to purchase it without all the hoops they need to jump through for consumer sales. If you want to purchase it for your business as a business customer, you can contact them to inquire about it.
With the tariff situation and trade issues, I assume consumer sales will take longer.
Thanks,
Josh
Offline KungFuJosh
  • TEAS is real.
« Reply #1243 on: October 09, 2025, 02:27:02 pm »
The Magnova is quite sensitive and I see it pick up things my previous scopes couldn't see at all.
Besides History mode, you might also want to consider the footswitch accessory. It has some nice presets to help in these situations, and I'm sure they'd be open to suggestions for more if you can think of something else.
Thanks,
Josh
Offline rf-messkopf
  • Mario H.
    • Homepage
« Reply #1244 on: October 10, 2025, 11:23:00 am »
Just checked
It took me a while to figure out where that notice was, as it's is only in the English version. Looks like a bug on the website to me.
Offline joeqsmith
« Reply #1245 on: October 10, 2025, 03:39:27 pm »
Just checked
Could be a bug I asked about that early on.   You would think if they were wanting to sell to the USA, they would have posted about it here and corrected the site long ago.
Offline KungFuJosh
  • TEAS is real.
« Reply #1246 on: October 10, 2025, 04:28:19 pm »
It's not a website bug. They're not currently shipping to the US for non-commercial customers. They need additional certification for consumer sales in the US. See my previous reply.
Thanks,
Josh
The following users thanked this post: rf-messkopf
Online Martin72
« Reply #1247 on: October 10, 2025, 04:38:18 pm »
For German-speaking countries, this information regarding the US/Canada is also rather uninteresting.
Offline rf-messkopf
  • Mario H.
    • Homepage
« Reply #1248 on: October 10, 2025, 05:14:41 pm »
Well, you can select shipping destination, business or private customer status and language all separately. So there is inconsistency between the language settings, which can be misleading. Also, when you select business customer the notification that it is unavailable in the US is still there.
I wonder what kind of certification for consumer sales that would be.
« Last Edit: October 10, 2025, 05:16:30 pm by rf-messkopf »
Offline voltsandjolts
« Reply #1249 on: October 10, 2025, 05:21:52 pm »
Maybe if you're a German living in the US, you can buy it ;D
