Author Topic: New Rigol DS1054Z oscilloscope  (Read 2721435 times)
0 Members and 197 Guests are viewing this topic.
Offline Howardlong
Re: New Rigol DS1054Z oscilloscope
« Reply #1150 on: March 11, 2015, 10:35:23 pm »
Hi there
Could someone have a look on this short movie I recorded and tell me if my Rigol has an issue or is it only my lack of knowledge?
My trigger source is set to CH2 somewhere around middle point and this is simple PWM from Arduino. CH1 is mosfet output. Everything is good until I enable CH3 (connected to square test output) or CH4 (not connected). Triggering get lost until I shift its level higher (even above actual source signal).
This looks for me like an issue but correct me if I'm wrong.
Thanks
Not sure what I'm doing different. I tried a similar thing (I don't have your PWM stuff, but I did an FM'd square wave instead around 500Hz which looks like your frequency) and similar settings. 5V/div (10x), 500us/div. I couldn't reproduce your problem.
http://youtu.be/lTA_6aCkAao
Offline Marooned
« Reply #1151 on: March 12, 2015, 08:38:58 pm »
Seems like you have not set a proper trigger (trigger is far too low)
You can see on the video that trigger is more or less in the middle (2,70V for logic 5V signal)
Not sure what I'm doing different. I tried a similar thing [...] I couldn't reproduce your problem.
Unfortunately, I had already different settings on my bench but I've recreated it and I think I have all the same (board and dso settings) and.. huh, I'm no longer able to recreate the issue. That is quite strange and pity I didn't debug it more when I had a chance.
Well, maybe posting to EEV adds +10 to electronics skills and I just got level up ;)
Thanks for your input.
Offline cutemonster
« Reply #1152 on: March 14, 2015, 06:55:26 am »
I guess I'm late to the party?  Just ordered one from teequipment and it's backordered.  I hope it's still hackable by then.
Offline JohnnyBerg
« Reply #1153 on: March 14, 2015, 08:41:09 am »
Mine is coming today. Finally!
I will not hack it (for now). Just play with it and compare it's performance to my other stuff.
Offline Dinsdale
    • pretzelogic
« Reply #1154 on: March 14, 2015, 03:35:47 pm »
I've had my scope for a while now. What I need now is a 'scope "cozy". Does someone have a grandmother who wants to do a kickstarter? You know, a nice embroidered, quilted cover with the RIGOL name on it. And a flap over the probe connectors so you can leave your probes connected if you want. Maybe a great-grandmother is required to find the necessary talent.
This can't be happening.
Offline Mark
« Reply #1155 on: March 14, 2015, 04:18:10 pm »
Here's one my grandmother would make if she had the time...
http://www.tequipment.net/Rigol/CARRY-BAG/Cases/
Offline max_torque
    • bitdynamics
« Reply #1156 on: March 14, 2015, 04:18:48 pm »
Hi there
Thanks
There's definitively something odd with the triggering on my 74Z when using multiple channels.  On a few occasions now i've set my scope up with one or two channels enabled, set the tigger, often for signals that come in "pulses" (ie not continuously triggering) and that triggering is lost when either of the other channels are switched on (3 or 4).  Definitely a bug imo.  Haven't got the time right now to figure it out / investigate more unfortunately.......
Offline FRob
« Reply #1157 on: March 15, 2015, 08:22:10 pm »
Can anybody confirm the trigger behavior for me? I semi-recently upgraded my DS1054Z to FW version 00.04.02.SP4 and took some measurements. I began to notice the following behavior:
Trigger in AUTO mode (DC coupled) will trigger for intermittent signals ("T'D" in upper left corner), but the waveform will not actually stay on-screen at all. At work I use Textronics, and in Auto-Mode, non-continuous signals will stay on-screen for some seconds. I think this time is configurable on Textronics, is this time configurable on DS1054Z?
Ex.: I'm watching a 200us signal on 50us timescale. I tried to compensate by setting hold-off to a large value, e.g. 1s. However, this only results in the waveform standing still for one second while the 200us signal that triggered it is already off-screen. Is this the intended behavior? At work I use AUTO mode all the time, yet on DS1054Z it kind of becomes useless for random probing, because it's easy to miss a trigger event when nothing on-screen changes.
EDIT: Forgot to mention: I didn't take many measurements before upgrading to the new FW, so I'm not sure it's related.
« Last Edit: March 15, 2015, 08:24:07 pm by FRob »
Offline Teneyes
« Reply #1158 on: March 16, 2015, 09:49:51 am »
From the User's guide:
"Note: When the horizontal time base is set to 50 ms/div or greater, this Auto trigger mode allows the absence of trigger signal."
Maybe try Normal trigger mode for intermittent pulses
IiIiIiIiIi  --  curiosity killed the cat but, satisfaction brought it back
Offline maj
« Reply #1159 on: March 16, 2015, 09:00:29 pm »
Finally cracked - now to wait impatiently till the end of April!
Offline blackbird
  • Ooohhhh, what does this button do???
« Reply #1160 on: March 17, 2015, 03:13:08 pm »
As of yesterday, I'm also a proud owner of this (Quoting Dave) "Best bang for bucks" DSO.
Offline Datman
« Reply #1161 on: March 17, 2015, 03:26:20 pm »
Hi, Blackbird
Can you tell us something about the noise on the trace?
Offline dadler
« Reply #1162 on: March 17, 2015, 03:58:03 pm »
These people make nice custom covers, I last got one for my Akai MPK-249 (midi controller):
http://www.digitaldeckcovers.com/
You can just give them dimensions. I think I'll order one and see how it works out. I've almost poked the screen several times with a hot soldering iron (maybe I should be more careful?  :P )
Offline blackbird
« Reply #1163 on: March 17, 2015, 05:50:24 pm »
As I'm a real novice on the scope, I'll first find my way through all the bells and whistles. Maybe you could help me out so I can give you a sensible answer  ;)
Offline Datman
« Reply #1164 on: March 17, 2015, 06:22:58 pm »
You can understand what I'm talking about seeing the screenshots I posted in this topic a few days ago
Offline JohnnyBerg
« Reply #1165 on: March 17, 2015, 06:41:19 pm »
You mean this: ?
Offline Fungus
« Reply #1166 on: March 17, 2015, 06:46:49 pm »
You mean this: ?
Offline JohnnyBerg
« Reply #1167 on: March 17, 2015, 06:55:35 pm »
The 1054Z performing really well with 300 µV noise on 1 mV/div. Better then the analog scopes I own.
This is something I could not do on my other scopes,  is measure the noise of my new "low cost" voltage reference.
Notice that the scale is 3 µV/div !! (there is a 10.000x preamp in front of the scope)
Offline blackbird
« Reply #1168 on: March 17, 2015, 08:08:20 pm »
I do now . :-+ I was thinking to difficult...
Offline JohnnyBerg
« Reply #1169 on: March 17, 2015, 08:27:27 pm »
After watching the video I think @Fungus is referring to the noise in the trace as Dave is explaining in the video. For me, that is not a problem, I am more concerned about the noise in the most sensitive setting.
Offline tautech
« Reply #1170 on: March 17, 2015, 08:45:57 pm »
Hi, Blackbird
http://www.eevblog.com/2014/04/10/eevblog-601-why-digital-oscilloscopes-appear-noisy/
http://www.eevblog.com/2014/04/27/eevblog-610-why-digital-scopes-appear-noisy-part-2/
Other than your connection methods, Dave's videos explains ALL you need to know.  :-+
Avid Rabid Hobbyist
Offline blackbird
« Reply #1171 on: March 17, 2015, 09:40:15 pm »
Ok, I will take a closer look at those videos.  Hopefully I can come back with more useful information ;)
Offline Datman
« Reply #1172 on: March 18, 2015, 09:03:40 am »
I'm not worried about noise at high sensitivity, because it would happen only when I measure very low signals. In these cases I could make a low noise preamp. The problem is that I see the noise every time I use the scope, also measuring a 10Vpp signal!
Please note that a 1/5 division noise is 1/50 scale: 1/50 of 256 (8bit) is about 5/256. 1 LSB (Least Significant Bit) is 1/256; the 2nd LSB is 2/256; the 3rd is 4/256, then noise affects fully the first 2 of 8 bits and sometimes the 3rd!
Offline g8bnr
« Reply #1173 on: March 18, 2015, 12:34:31 pm »
Hi Folks,
I have just recently received my DS1054Z, which I am most pleased with, and the dealer, Telonic, were excellent.
I have been experimenting with the Riglol 'keygen' codes. My unit has the following fitted:-
Software Version        00.04.02 SP4
Board Version             0.1.1
The 'keygen' code DSFR did not work, it came up with an invalid code message!
However, the 'keygen' code DSER worked first time. The only difference between these codes, as far as I can discover, is that DSFR is supposed to activate all options including 500uV/div. The DSER code enables all that DSFR is supposed to do except for the 500u/div option.
Maybe Rigol have removed the 'buggy' 500uV/div option from the latest software/board issue!
Hope that this information is useful to EEVBLOG Forum readers.
73 Dick
Offline ebastler
« Reply #1174 on: March 18, 2015, 12:43:06 pm »
Hi Datman,
In the measurements you had posted here https://www.eevblog.com/forum/testgear/new-rigol-ds1054z-oscilloscope/msg620902/#msg620902, the noise did not look as bad as what you mention now. For example, in the 6th screenshot in that post (500 mV/div), the noise-free, steady yellow line is two pixels wide. Full range is 400 pixels on the screen -- Rigol probably rounds up the line width to 400/256 ~ 2 pixels. The pink and dark blue channel alternate between two levels, which are 2 pixels and presumably 1 LSB apart. Only the light blue (cyan?) channel shows rare excursions to a third level, which is probably 2 LSBs away -- or you could argue it is +-1 LSB from the average.
I would more or less expect to find noise patterns as seen for the pink and dark blue channels, if the input voltage sits just between two ADC input levels. (Although for the special case of 0V input, Rigol could probably do better by getting the auto-calibration right, so that 0V sits smack-dab on the 0x00 output of the ADC... But that would just make it look better cosmetically; for real-world DC signals you would still get the same alternating levels, depending on the actual voltage input.) Hence, that does not concern me at all. The cyan channel might be slightly fishy, but nothing I personally would worry about.
Regards,
Juergen
