Author Topic: RIGOL MHO98 and MHO900 Oscilloscope Series  (Read 151188 times)
gf, Ivan7enych and 10 Guests are viewing this topic.
Offline axantas
Re: RIGOL MHO98 and MHO900 Oscilloscope Series
« Reply #150 on: October 14, 2025, 09:04:48 pm »
@Martin72: ask everything, but take into consideration, that there are far more skilled people in this thread, than me. But I will do my best.  ;)
Set the maximum sample rate and memory on the scope, then activate the LA.
Which memory/sample rate is then displayed?
Please provide a screenshot.
Thank you. ;)
If I am told, how to knit the sweater, then almost everything is possible.  :box: scheduled for tomorrow.
Offline Martin72
« Reply #151 on: October 14, 2025, 09:14:55 pm »
Is that so? According to the data sheets, both the DHO900 and MHO98 have the same power supply specification.
Unfortunately, the data sheets only specify the power supply, not the power consumption... Very useful. :P
Be that as it may, according to the data sheets stored at Batronix, the power supply for the DHO900 series has 48W of power, while that for the MHO900 series has 70W.
Offline axantas
« Reply #152 on: October 14, 2025, 09:17:45 pm »
And the MHO98 come with a 100W Power supply drawing 60W idle.
« Last Edit: October 14, 2025, 09:21:23 pm by axantas »
Online 0xdeadbeef
« Reply #153 on: October 14, 2025, 09:46:30 pm »
Actually, the datasheets for the MHO98 and MHO900 (*) I downloaded both specify a 70W "Power", but also a "Power Voltage" of 20V / 5A.
Anyway, I don't doubt that the MH98 draws more current than an DHO900, but the fan is substantially larger, so the fan noise should at least be different.
[EDIT]
(*) Ah, sorry, I thought I downloaded a DHO900 datasheet but downloaded an MHO900 datasheet instead which has the same power supply specification as the MHO98 of course.
Still, these datasheets specify both, 70W ("Power") and 100W ("Power Voltage") for the supply. Not the best datasheets anyway.
« Last Edit: October 14, 2025, 10:07:27 pm by 0xdeadbeef »
Offline Martin72
« Reply #154 on: October 14, 2025, 09:51:02 pm »
I may need to qualify that statement regarding the data sheet.
At least for the MHO series, they (rigol) have specified the power consumption, albeit in a somewhat confusing manner.
The power supply for all MHO900/98 models is specified as 100W (20V, 5A), while the power consumption is specified as 70W.
However, this is not stated explicitly.
Offline axantas
« Reply #155 on: October 15, 2025, 01:15:40 pm »
Thank you. ;)
I played around a bit with the settings there are strange dependencies switching the Mem Depth, but this is it with max values.
Rigol has still to do some work on the firmware.
- The IP-address is not shown - it is connected, but still displays 0:0:0:0:0
- The timezone is fixed to China. Connecting it to the network reverts the manually chosen time. But as I remember, we did have a similar annoyancy with Siglent...
- More probably to discover
The following users thanked this post: egonotto, Martin72
Offline eurofox
    • Music
« Reply #156 on: October 15, 2025, 01:24:59 pm »
My MHO98 just arrived  :popcorn:
It got a special number FF
It less blingbling than on the pictures  :)
WIFI connected, there is a keyboard on the screen, no need for external keyboard
Mouse work but click does not work when touchscreen is deactivated  :palm:
Firmware version 1.0
Somes options are "limit" ,check picture
There is a document to complete to unlock the "limit"
Bluetooth is included
« Last Edit: October 15, 2025, 02:11:14 pm by eurofox »
There's No Future In the Past.
eurofox
Online 2N3055
  • Country: hr
« Reply #157 on: October 15, 2025, 02:06:39 pm »
Yes, there are bugs in all equipment. Siglent, Keysight, R&S. And they get fixed there. With Rigol it is a bit more stochastic. Hope dies last..
Dr. Richard W. Hamming
Offline Sorama
« Reply #158 on: October 15, 2025, 02:09:39 pm »
Haven't they included codes for those 'limit' options?
It looks to me that even those options should be included (for ever).
Offline axantas
« Reply #159 on: October 15, 2025, 02:15:06 pm »
They are not included, but should become included following the registration on that document.
I did it yesterday, but no reaction yet from Rigol - not even a confirmation mail.
Offline eurofox
    • Music
« Reply #160 on: October 15, 2025, 02:19:01 pm »
There is a document to complete, I just did it and send it.
According the document something should come by email, maybe a code to enter in an hidden place or simply a gel file to install ...
Or maybe they wil activate it by internet  :wtf:
« Last Edit: October 15, 2025, 03:41:58 pm by eurofox »
eurofox
Offline tautech
« Reply #161 on: October 15, 2025, 03:12:38 pm »
- The timezone is fixed to China. Connecting it to the network reverts the manually chosen time. But as I remember, we did have had a similar annoyancy with Siglent...
FTFY
SDS2000X Plus got a FW and OS update to fix it.
Never experienced it personally but helped a few to correct it.
Offline axantas
« Reply #162 on: October 15, 2025, 03:51:08 pm »
FTFY
...am I being teached proper English here, tautech ?  ;) :-+
Online 0xdeadbeef
« Reply #163 on: October 15, 2025, 03:59:49 pm »
Quote from: Martin72
The more interesting thing would have been how the sampling rate and memory change when you activate 1,2,3,4 analog channels with and without the LA.
I.e. I suspect the LA will lower the sampling rate and memory just as if an additional analog channel was activated.
Online ststefanov13
  • Country: bg
« Reply #164 on: October 15, 2025, 04:06:42 pm »
Batronix stopped accepting orders for MHO98 and the product disappeared from the product list.
Offline eurofox
    • Music
« Reply #165 on: October 15, 2025, 04:11:48 pm »
Thank you. ;)
eurofox
The following users thanked this post: egonotto, Fungus
Online 0xdeadbeef
« Reply #166 on: October 15, 2025, 04:16:13 pm »
Interesting. So unlike the DHO900, switching on the LA seems to reduce neither the sampling rate nor the memory depth.
This would mean that the LA is independent. Strange though that Rigol doesn't feel the need to specify any of this in their datasheets.
Offline voltsandjolts
« Reply #167 on: October 15, 2025, 04:26:21 pm »
Or a firmware bug is displaying the wrong info :-DD
Online Fungus
« Reply #168 on: October 15, 2025, 04:26:57 pm »
Talk to the people who sold it to you, they're probably supposed to email you the codes.
Online Fungus
« Reply #169 on: October 15, 2025, 04:31:53 pm »
These things are tempting... but I know I don't need one. Must resist...  :scared:
Batronix lists the MHO98 as "no longer available". I guess they sold their entire quota.
Offline eurofox
    • Music
« Reply #170 on: October 15, 2025, 04:43:37 pm »
Still available here https://www.eleshop.nl/rigol-mho98-oscilloscoop-limited-edition.html
It is a shop with very good reputation
Hurry up if you need one  :box:
eurofox
Offline Sorama
« Reply #171 on: October 15, 2025, 04:51:30 pm »
Eleshop does say they won’t guarantee you a delivery.
« Last Edit: October 15, 2025, 05:01:01 pm by Sorama »
Offline axantas
« Reply #172 on: October 15, 2025, 04:55:49 pm »
This is part of the "dependencies" i encountered by switching values like memory depth manually.
But interesting: you can switch on LA without the PLA2216 - something which is not possible on a 924S, where you only get a "not connected" error.
Offline ptluis
  • Country: pt
« Reply #173 on: October 15, 2025, 04:56:45 pm »
61W minimum consumption you'll need a respectable (expensive) powerbank to be able to use it for 3 hours.
But this is a nice strategy to obtain funds 1998x1350€ =  :-DD :-DD :-  :-DD
Fnirsi style, new models instead of fixing the previous ones  :-+
« Last Edit: October 15, 2025, 04:58:39 pm by ptluis »
Offline axantas
« Reply #174 on: October 15, 2025, 05:17:32 pm »
You are right, it draws quite a bit. Question is, do I need to carry it with me for my "outdoor activities" or do I use my XEast (or Fnirsi...) portable with me.
