Author Topic: Siglent SDS2000X Plus  (Read 1746819 times)
0 Members and 94 Guests are viewing this topic.
Offline stafil
Re: Siglent SDS2000X Plus
« Reply #1150 on: May 13, 2020, 07:22:12 am »
Sorry to divert the conversation from Bode Plotting, but is anyone else annoyed by the "Sequence" a.k.a segmented memory mode?
If one configures it to capture X amount of frames, and then receive X+1 frames, it just wipes out the previous memory and starts from scratch.
I would expect it to either stop at X frames and go into History mode, or just use a circular buffer. Not wipe out ALL the old frames.
It should stop after acquiring  X frames.
That's what I was expecting too, but it doesn't:
What happens if you press single instead of run?
Works exactly as expected :clap:
 I am too stupid to be allowed to operate these instruments   :palm:
« Last Edit: May 13, 2020, 05:48:13 pm by stafil »
Offline Elasia
« Reply #1151 on: May 13, 2020, 02:28:38 pm »
I found the culprit for my unit at least on the bode issue
Auto channel gain
Offline thinkfat
    • Matthias' Hackerstübchen
« Reply #1152 on: May 13, 2020, 07:16:10 pm »
Nice. So it's not the settling time of the AWG, it's the settling time of the input switching between ranges.
Online 2N3055
  • Country: hr
« Reply #1153 on: May 13, 2020, 08:15:43 pm »
I mentioned this some time ago, but was told that Frex tried in hold mode and also got error...
So what is right?
Dr. Richard W. Hamming
The following users thanked this post: Elasia
Offline thinkfat
« Reply #1154 on: May 13, 2020, 08:44:40 pm »
So what is right?
Frex should be able to tell. I might have misunderstood what he said.
Online 2N3055
  • Country: hr
« Reply #1155 on: May 13, 2020, 10:03:22 pm »
If you want to unlock 5000X to 1 GHz you need to buy 500MHz ver.
Maybe not anymore...  ;)  Yet to confirm.
That would be VERY nice.. >:D
Indeed. More or less the only thing stopping me from ordering the SDS5034X is that it can't be upgraded to 1GHz. There are some hints (spec wise) that the frontend in the 500MHz model is different though, so even if the SW could be tricked into believing it's the 500MHz model that can be upgraded to 1GHz, I have some reservations that it will reach the full bandwidth. Still.
I'll just leave this picture here...
What pulse gen you used?
Sorry to disappoint you, but  if you are using pulse generator that is faster than 200 ps risetime, this proves that your 350MHz version doesn' have same front end as 1GHz version.
Let me explain. Siglent made 1st version of 1GHz front end (that's the one you have) but it wasn't as good as they wanted it to be. To their credit, they made ver 2 with improved front end (with better bandwidth, but more importantly better linearity and phase across the range). That one should have 400ps risetime..
Dont get me wrong. What you have is one fantastic 750-800 MHz scope... Since you paid for 350 MHz you are winner anyway.
But real 1 GHz version (and officially upgradeable 500 MHz one upgraded to 1GHZ) are even better in upper end.
On the other hand, your should have better bandwidth at 1 mv/div..
Online 0xdeadbeef
« Reply #1156 on: May 13, 2020, 10:08:00 pm »
Looks like Bodnar 40ps. Still, 750MHz doesn't sound so bad to me.
Anyway: does the 1000M or MAXjust work or is additional trickery needed?
Besides: how would this look like with just the 500M option?
« Last Edit: May 13, 2020, 10:12:39 pm by 0xdeadbeef »
Online Martin72
« Reply #1157 on: May 13, 2020, 10:37:11 pm »
It IS the Bodnar, I got it too and know the PCB look.
Online Martin72
« Reply #1158 on: May 13, 2020, 11:01:48 pm »
We´re still talking about the sds2000X+ ?
Offline Elasia
« Reply #1159 on: May 13, 2020, 11:09:30 pm »
They went on a tangent about the 5k series
Online 2N3055
  • Country: hr
« Reply #1160 on: May 13, 2020, 11:16:04 pm »
Sooory, I didn't notice the title... Just answered...
Yes that should be continued in sds5000X topic..
Offline Frex
« Reply #1161 on: May 15, 2020, 04:12:42 pm »
So what is right?
Hello,
I had tested Normal and Vary Level sweep type,  but not Auto/Hold Gain . I will try this also this weekend.
Note that even if it's ok without the auto gain, that stay a bug that need to be solved !
Frex
The following users thanked this post: 2N3055, Elasia
Offline Elasia
« Reply #1162 on: May 15, 2020, 04:53:48 pm »
Hello,
Frex
Listen for the relay click.. thats the dead give away
Offline DL2XY
« Reply #1163 on: May 15, 2020, 05:21:22 pm »
Had a short test with external AWG (SDG6000X via USB).
No glitches, even with Auto Gain.
Ran some more tests, 1 out of 12 passes showed 3 glitches.
« Last Edit: May 15, 2020, 07:05:52 pm by DL2XY »
The following users thanked this post: 2N3055, maginnovision
Offline maginnovision
« Reply #1164 on: May 15, 2020, 07:52:47 pm »
Your original post definitely made me think you just didn't run long enough so glad you tried a little longer.
Offline thinkfat
« Reply #1165 on: May 15, 2020, 09:12:38 pm »
So what is right?
Hello,
Frex
Without the auto gain, dynamic range will be reduced by quite some amount.
Offline famalex
  • Country: gr
« Reply #1166 on: May 15, 2020, 10:15:30 pm »
Hi!
I'm sorry to have to change again the discussion, but I have very brief question for experienced and knowledgeable members. I bought SDS2104X Plus from Welectron and am waiting for it to arrive (delayed by the known virus).  Of course, 100 MHz BW is rather good and enough in many cases for an average hobbyist as I am, but sometimes somebody wants something more.  So, I decided to upgrade the BW to 200 MHz in the future. Batronix promotes this option for only €1500 :-DD as “hardware upgrade”. Is there really “hardware” difference between these two models?:-/O  I mean SDS2104 and SDS2204.
Online tautechTopic starter
« Reply #1167 on: May 15, 2020, 10:22:01 pm »
Hi!
No difference and the 100 MHz model has already been found to have ~185 MHz -3dB point so rightly is shipped with 200 MHz probes.
Avid Rabid Hobbyist
The following users thanked this post: famalex
Offline famalex
  • Country: gr
« Reply #1168 on: May 15, 2020, 10:38:40 pm »
Thank you. Your answer is brief and encouraging.
Offline famalex
  • Country: gr
« Reply #1169 on: May 18, 2020, 09:05:59 pm »
New firmware version for SDS2000X Plus 1.3.5R5 is ready.  Coincidentally, my oscilloscope came to me today. Obviously I won't be able to sleep tonight. ;D
Offline TK
« Reply #1170 on: May 18, 2020, 09:15:22 pm »
Is there a good practice to calculate the effective waveform updates per second on the Siglent scopes?  I cannot get anything near the 120,000wfm/s claimed by Siglent marketing.
I tested the minimum timebase, dot mode.  Reference trace in orange is without measurements, yellow trace is with 2-3 basic measurements.  With no measurement there is a 3ms dead time between triggers, with measurement active the dead time increases to 13ms.  I did not capture the frequency but it was something like 1KHz...
Please ignore the wrong scale due to having the probe in 10:1 and using a BNC to BNC cable.
On Keysight 1000X, you just put minimum timebase and you get the published 200,000wfm/s
« Last Edit: May 18, 2020, 09:17:06 pm by TK »
« Reply #1171 on: May 18, 2020, 09:17:21 pm »
New firmware for SDS2000X Plus models
Version V1.3.5R5
29.6 MB
https://int.siglent.com/upload_file/zip/firmware/Oscilloscope/SDS2000X_Plus_1.3.5R5_EN.zip
Release notes
1. Supported to hide analog traces
2. Added function expression information to the math box
3. Optimized AWG DC output accuracy at +/-3V
4. Frequency counter supported to count serial trigger events
5. Fixed several bugs
     a) Incorrect cursor horizontal label for FFT traces
     b) 2-channel 100MHz model cannot be upgraded to 350MHz
     c) FRFR measure invalid from Roll to Stop
     d) Unexpected behaviors when probe attenuation factor is not 1x
     e) Some bugs in PA
Avid Rabid Hobbyist
Online Martin72
« Reply #1172 on: May 18, 2020, 09:23:21 pm »
Good news, can´t await to test it.
Thank god, this (working) week is short... ;D
Offline TK
« Reply #1173 on: May 18, 2020, 09:36:13 pm »
I could not find averaging in the acquisition menu.  In this scope, it seems to be a math function.  Does it mean that you can only average 2 traces out of 4, as math has capacity for only 2 functions?
Online Martin72
« Reply #1174 on: May 18, 2020, 09:38:48 pm »
Therefore I suggest to enhanced the math traces up to four...Shouldn´t be a big problem to realize.
(See my signature, bugs and wishlist)
The following users thanked this post: TK
